Version 2.4 | Published April 02, 2024 ©
Fine-tuning the System
Graphics Plugin is a complex product that involves several applications communicating over a network. These applications and the communication between them needs to be robust. Once everything is working after the installation, you can configure the system to work reliably in the environment in which it will be used.
