Version 2.3 | Published September 14, 2023 ©
Windows-based NLE Systems
The Configuration Tool and a NLE version of Viz Trio are also installed when you install Graphics Plugin for Windows-based NLE systems. Viz Trio is an advanced character generator used to produce content to use with a Windows-based NLE system. Viz Trio requires a Viz Engine and a Media Sequencer, see the illustration in Hardware Requirements.
Typical Viz Trio Setup
NLE machines
NLE system
Graphics Plugin (includes bundled Viz Trio)
Media Sequencer
Viz Engine
Graphic Hub with graphic scenes
Optional: Datapool plugins for Viz Engine
Although Viz Pilot and Viz Pilot Edge can also be used as the graphics editor for NLE systems, they are not bundled with the installation, and require a Viz Engine and a Viz Pilot database. The Viz Pilot database (Oracle 10g) is where templates, template data elements and associated data are stored.
Typical Viz Pilot Setup
NLE machines
NLE system
Viz Pilot/Viz Pilot Edge
Graphics Plugin
Viz Pilot database installation
Oracle 10g
Viz Engine
Note: Viz Engine and Media Sequencer both run on Windows versions 7 or newer. Viz Engine 3.7 and later do not support Windows XP. Although it's recommended to run Media Sequencer on a separate machine, Media Sequencer can run on the Viz Engine machine in small production environments.
Installation
When installing Graphics Plugin for EDIUS, Adobe or Avid on Windows, the Configuration Tool and the NLE version of Viz Trio are also installed.
Notes
The installer requires a Windows user with administrator privileges.
Adobe Premiere Pro must be installed on the workstation before installing Graphics Plugin for Adobe.
Separate installers apply for 32-bit and 64-bit NLE systems. The 32-bit installer should be used together with Media Composer 5/NewsCutter 9 (or older); the 64-bit installer with Media Composer 6/NewsCutter 10.
Configuration
A Configuration Tool is installed with Graphics Plugin. See the Graphics Plugin User Guide on how to access the Configuration Tool in Adobe, Avid and Edius, and the Configuration Tool section for settings.
