Version 2.2 | Published September 14, 2023 ©
Tuning the System
The Graphics Plugin is a fairly complex product that involves several applications communicating over a network. These applications need to be individually robust and the communication between them need to be equally robust.
The first step of any installation is to see that everything works fine; hence, the plugin will in most cases work out of the box. After everything is working, the next step is to configure it to work reliably in the work environment in which it will be used, which can be challenging.
