Vizrt iNEWS Command Plug-in Administrator Guide
Version 3.0 | Published January 26, 2021 ©
Preview
A preview channel can be configured in the Viz Pilot profile configuration (Tools > Profile Configuration).
Only one external preview can be configured per profile.
If autocue is enabled in Avid MediaCentral® | Command (Avid MediaCentral® | Command > Tools > System Settings > Playout > Autocue) then the Avid system automatically queues the next item in the playlist.
If autocue is not enabled, the user of Avid MediaCentral® | Command is manually cuing items, and one preview channel is enough even though multiple playout channels are available.
Note: Viz Trio can also be used to configure a preview Viz Engine. See the Output section in the Viz Trio User Guide for more information about this procedure.
