Installation Folders
The default installations folders are
C:\Program Files\vizrt\VizTH
C:\Program Files\vizrt\Studio Manager
Files which are created or can be modified are located in %ProgramData%\vizrt\VizTH. Tracking Hub creates the following subfolders when it starts, so they are present on every installation:
Folder | Contents |
Cfg\ | Studio configurations. Each configuration has its own subfolder, holding the cyc, video wall and router XML files that belong to it. |
Lattices\ | Rig definitions, one XML file per rig, named |
Lensfiles\ | Lens files. A Lensfile rig references a file in this folder by name. This is the folder the Lens File Editor reads and writes. |
Lutfiles\ | Look-up tables used for color correction. |
Post\ | Recorded tracking data written and read back by the Post system. |
Targetcalibration\ | Reserved for target calibration data. |
Templates\ | Studio templates, one XML file per template. |
XMLTracker\ | XML protocol descriptions used by the XML Tracking protocol. |
The root of %ProgramData%\vizrt\VizTH itself holds:
VizTH.conf— the main configuration file. If it is missing, Tracking Hub writes a new one with default settings on the next start.Crash dump files.
Debug log files (
VizTH_send*.log,VizTH_rcv*.log,VizTH_timing*.log) when the corresponding logging is switched on.
A second location, %LOCALAPPDATA%\vizrt\VizTH, holds the startup configuration. It is created on startup in the same way.
Temporary files are located at: %TMP%\vizrt\VizEngine, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\VizEngine. This folder is referenced as <viz temp folder> throughout this User Guide.
