This section lists some common pitfalls and how to solve them, as well as providing guidance on optimizing your Virtual Studio workflow.
General
Depending on your tracking system, a zero point is required. This marks a special location in your studio defining the start- or reference point. The design of your set (Viz Scene) and the calibration relays on this location; therefore, clearly mark it.
Make sure you use correct units during your set design. This makes it much more easier to match your set later on.
The Studio Manager is mainly used to configure and setup your virtual set. During production this application is not needed and should be closed. Only Tracking Hub needs to be running.
Syncing
As a general rule: Every single component in your setup needs to be synced correctly. This includes any router, camera, Viz Engine, keyer etc.
Tracking
Tracking Networks
It is recommended to use a dedicated network to transport your tracking data.
Make sure no firewalls, load balancers or similar can have any negative impact on the transport of your tracking data.
Receive Timing tool
The receive timing tool is used to debug the timing of incoming packages on Viz Engine. It communicates using UDP packets with the CVIODataExchgVizIo3.dll, which is responsible for receiving tracking data on the Viz Engine side. It can be used, when there is the suspicion that the network is not able to transport the tracking data to Viz Engine.
The tool can be activated by pressing CTRL + R or starting the tool from the Tools > Receive Timing menu.
The dialog is built up of four sections.
Engine / Camera
The user can select an engine in the dropdown box and enter the port where the engine receives the tracking data.
The user must select the camera and the client delay which is usually set to 1. Pressing Connect starts the UDP sender.
Base Settings
At least Base Debug must be selected to get an output on Viz Engine. As soon as Base Debug is enabled, the console outputs:
That means, at least that buffer violations are logged.
A queue violation happens, for example, when you switch off the camera service on the studio manager. In normal operation, this is a serious problem and creates a jitter in the tracking output of Viz Engine.
It can also happen that the tracking hub runs too fast (for example, NTSC instead of PAL). In that case, tracking packages must be deleted, which also causes jitters, as packets get lost.
RunID Debug enables timecode debugging. To use this feature, Viz Engine and Tracking Hub machines must be synchronized.
Log to File forces the engine to write the results to a text file. Otherwise, the output is written to the console.
Timing Settings
Three significant values can be measured and displayed.
Viz Request Diff Time
This is the time which passes between two engine requests for tracking data. If this time is irregular, it can be and indicator that Viz Engine is not running real time or a ring buffer is active. The log line looks like this:
The line starts with the actual time, followed by the string “CamVDIF” and the camera number starting with 0. After the camera number follows the running packet id and the difference time in seconds. For PAL, this time should always be around 20ms.
The following screenshot shows a sequence of difference times which mark an error.
The renderer was requesting too much tracking packages. This can happen when loading scenes or switching from On Air to edit mode.
Data Rec Diff Time
This is the time which passes between two packages for the defined camera are received on the UDP port.
The line starts with the actual time, followed by the string “CamRCTD” and the camera number starting with 0. After the camera number follows the running packet id and the difference time between two packages in seconds. For PAL, this time should always be around 20ms.
The screenshot above shows as an example, a Tracking Hub running at 60hz and a Viz Engine running at 50hz. After six packets, the queue runs over and Viz Engine must cut a package.
Unstable difference timing indicates that there might be a problem with the transport of packages via network, or an unsynchronized Tracking Hub.
Sync to Rec Diff Time
This is the time between Viz Engine's request for camera data and the receive time of the next camera package via network.
The line starts with the actual time, followed by the string “CamSYDF” and the camera number starting with 0. After the camera number follows the running packet id and the difference time between a sync and the receive time of the next package.
The sequence above shows the difference time when Tracking Hub is running NTSC and Viz Engine is running PAL. This is an extreme example. Usually the drift is much slower and moves over a long period of time.
Usually the log is activated, switched off and switched on after one hour. The difference time should always be stable.
If this time is drifting, it is an indicator for an incorrectly synchronized Viz Engine or Tracking Hub. If this time is too close to 0 or the field border it can be adjusted with the send time in Tracking Hub.
Limits
All debug times can be limited to a specific range so that only spikes will be printed out. This makes it possible to debug and watch the behavior over a long period of time.
Start/Stop section
Press the Start button to send the selected options to Viz Engine and start debugging. Pressing Stop ends the debugging.
Lenses
Every Lens file is unique. It is highly recommended to calibrate each lens on the mounted final camera rig. Even if you have an existing lens file available, it might not be sufficient to use this one for another lens of the same type.
Delay
To get a precise match between real live video and the Viz Engine rendering, the tracking data has to be delayed properly to react within the same field. This can be done for each parameter individually or, in most cases, is handled with the Overall Delay on the camera rig node.
Adjusting the delay can be easily achieved by making quick changes in camera movement to see if the tracked graphic starts before the video signal or if its stops after it. Best practice here is to start with a high delay and decrease it slowly until both layers match perfectly while panning the camera left and right. Once this fits, check the other parameters. In some cases, zoom and focus need a different delay which is added or subtracted from the overall delay by adjusting the specific delay of these parameters separately.
NDI
Requirements and Limitations
It is not recommended to have more than one active NDI tracker, due to the increased load on the system. Adding multiple NDI trackers can lead to insufficient GPU resources and an unstable tracking result. GPU recommendation for NDI embedded tracking are NVIDIA RTX 4000 cards or newer. NDI cameras and Tracking Hub should run on a dedicated network to prevent package loss.
The network bandwidth needs to fit your needs. It is highly recommended to use a dedicated network for the NDI transport.
Only tested and certified PTZ cameras are supported. See Supported NDI Cameras.
Make sure no other applications connect to your NDI source. This also includes NDI Studio Monitor, for example.
To use NDI in your Virtual Studio, make sure the following conditions are fulfilled:
In the Viz Engine Settings, all video boards must be deactivated and NDI must be selected.
As the Sync source settings are not available after switching to NDI. In the configuration file under the section Genlock, Genlock must be set to
2.
Chroma Keying
Make sure your lighting conditions are the best ones you can achieve. Optimal chroma keying results depend strongly on the good quality of both cyc and homogeneous light.
Remote Connection
It is not recommended to use Windows Remote Desktop for remote connection to any Studio Manager Client as the Windows Basic Adaper can interfere with the GPU settings leading to Studio Manager no being able to start properly.
