1   What the Data Inspector is for
The Data Inspector shows tracking data as curves, so you can see what the system is actually delivering instead of inferring it from the picture. It answers questions such as: is the camera data smooth or does it jitter, does a value jump, does the delay setting fit, and does what leaves the TrackingHub match what the tracker sends in.
It has two modes:
·         Post data mode plots a recording from disk. Use it to examine a take after the fact and to export it, including as FBX for a 3D application.
·         Live mode plots the data arriving right now, as a rolling window. Use it while setting up, or while hunting a problem on the floor.
Note   Live mode replaces the former Data Flow Inspector window. That separate tool is gone; everything it did is now part of the Data Inspector.
1.1  Opening it
In StudioManager, choose Tools → Data Inspector. The window opens on the post data view.
2   Post data mode
2.1  Loading a recording
Choose File → Load and pick a .VPD recording. Recordings live under C:\ProgramData\vizrt\VizTH\Post by default.
The progress bar in the status bar fills while the file is read, and Packages then shows how many packets the recording holds.
2.2  Choosing what to see
The two menus at the top list what the recording contains:
·         Channels – the individual parameter channels.
·         Camera Channels – the camera recordings, grouped per camera, with one entry per value: pan, tilt, position, lens and so on.
Each entry is a toggle: tick it to add its curve to the plot, untick it to remove it.
2.3  Reading the plot
Control
What it does
Show Points
Marks every individual sample with a triangle. Use it to see whether a curve really has one sample per frame, or whether packets are missing.
Frequency
The capture rate of the recording: 59.94, 60 or 50. It sets the time base of the horizontal axis, so pick the rate the system was running at.
Mouse wheel
Zooms. Dragging pans the view.
Reset Zoom
Restores the default scaling of all charts. A middle-mouse double click does the same.
2.4  Exporting
Export to PDF writes the plot as you currently see it.
Export to File opens the Export Data dialog. Pick what to export – Cameras Only, All Data or Selected – and then a format.
Format
Contents
XML
The selected channels with their values and timecodes.
CSV
One row per packet, for a spreadsheet or your own analysis. Decimal points are always "." regardless of the Windows region setting, so the file opens the same way everywhere.
FBX
The camera recordings as an animated 3D camera, for Blender, Maya, 3ds Max and similar. Only camera channels are exported.
2.5  FBX export options
Three settings appear once you choose FBX:
·         FBX channels – tick the cameras that should go into the file. This is an explicit choice because video wall, TC camera and NDI services record under the same CameraN names as the real camera services and cannot be told apart from the recording alone.
·         FBX source unit – the length unit the recording is in. StudioManager works in centimetres, which is the default; choose metres only if the recorded positions are in metres.
·         Axis mapping – collapsed and inactive by default. It lets you invert or re-assign individual axes before export, for recordings that already carry a swapped or inverted axis, so an old take can still be exported without re-recording it. Reset to recorded order returns it to the untouched state.
Tip   A correctly configured rig needs no axis mapping. If you find yourself changing it for every export, the rig configuration is what should be fixed.
The exported camera carries animated position, rotation and focal length, and the animation is as long as the recording.
3   Live mode
3.1  Switching it on
Tick Live at the bottom left. The post plot is replaced by two charts and a toolbar.
Live mode needs a connection to the TrackingHub. Without one the tick is refused with a message and the checkbox springs back.
Note   While live mode is on, the channel menus and Export to File are greyed out. They work on a loaded file, which live mode does not have.
3.2  The two charts
·         Upper chart – the value itself, as a window of the last few hundred packets that scrolls along as data arrives.
·         Lower chart – the tangent, that is the change from one packet to the next. A clean movement gives a smooth tangent; a spike in the tangent is a step in the data that the picture will show as a jolt.
Show Tangents hides and restores the lower chart. Both charts always share the same horizontal range, so a spike in the tangent sits directly under the sample that caused it.
3.3  Choosing what to plot
Control
What it does
Rig
The camera rig whose output you want to see.
Target IP
Where the TrackingHub sends the stream. Leave it at 127.0.0.1 when StudioManager and the hub are on the same machine; enter this machine’s address when the hub runs elsewhere.
Parameter
Which value to plot – pan, tilt, roll, the three positions, zoom, focus, field of view and the lens values.
3.4  Processed and raw data
Two curves can be shown at the same time, and the difference between them is the point of the exercise:
·         Processed (orange) is the finished value the TrackingHub sends to the render engine, after the rig calculation, the lens file and all offsets and delays.
·         Raw (green) is the value the tracker delivers, before that calculation. It is drawn against its own axis on the right, because it is in the tracker’s own units – usually counts, not degrees or centimetres.
Comparing the two tells you where a problem sits. If the raw curve is clean and the processed one is not, the cause is in the configuration. If both are equally bad, the tracker or the cabling is.
Switch them on and off with Show Processed Data and Show Raw Data.
3.5  Where the raw curve comes from
When you switch the raw curve on, a Raw source: label appears and names the tracker axis being read, for example Raw source: ts1_pan. The same name appears in the chart legend.
The Data Inspector works this out from the rig itself, by looking up which tracker axis the rig reads for the parameter you selected. That matters, because a rig may well be wired across: a rig can take its Y position from the tracker axis named "posz". Following the rig gets this right where guessing by name would not.
Some values have no tracker axis at all, because they are calculated rather than measured – field of view, the lens distortion values K1 and K2, and the scale factors. For those the label says so, instead of pairing the curve with something unrelated.
3.6  Finding jumps
A sample is marked with a red circle when the change between two samples differs from the previous one by more than Threshold. That is a quick way to spot a dropout or a spike without staring at the curve.
The label states the unit of whatever you are plotting: Threshold [°] for the rotations and the field of view, Threshold [cm] for the positions, and plain Threshold for the values that have no unit.
Important   The same number is applied to the raw curve as well, but raw values are in tracker counts. With 32768 counts per degree, a threshold that is sensible for the processed curve is exceeded by the raw curve almost always. Judge the raw markers with that in mind.
3.7  Freezing the picture
Press Pause to freeze both curves so you can study a detail. While frozen you can zoom with the wheel, drag the view and pull a zoom rectangle; both charts move together. Resume starts the curves again and returns the view to the scrolling window.
Zooming is available only while paused. On a running plot a manual zoom would switch the automatic scaling off, and the curve would walk out of view while the chart appeared to be stuck.
Note   Data keeps arriving during a pause, and a running recording is not affected. What the pause suppresses is the drawing: the packets from that period do not enter the curves and are not scanned for jumps.
3.8  Recording a sequence
  1. Set Rec to the length you want, between 10 and 60 seconds.
  1. Press Record Sequence. The status shows Recording... and a red countdown runs down.
  1. When it finishes, a save dialog offers a CSV file. The default location is C:\ProgramData\Vizrt\StudioManager\ and the name is TF_<date>_<time>.csv.
The file holds one row per packet with all values of the camera package – rotations, positions, zoom, focus, field of view, centre shift, the lens values and the timestamp.
The length is derived from the Frequency setting in the status bar, so ten seconds really are ten seconds at 50, 59.94 and 60 Hz alike.
Controlling the Data-plot
Action
Shortcut
Pan
Right mouse button,
ALT + Left mouse button,
UP/DOWN/LEFT/RIGHT ARROW keys, CTRL + ARROW keys for fine pan
Zoom
Mouse wheel,
CTRL + Mouse wheel for fine zoom
Zoom in
Mouse extra button 1,
+ (Plus), PAGE UP, CTRL + + (Plus)/PAGE UP for fine zoom in
Zoom out
Mouse extra button 2,
- (Minus), PAGE DOWN, CTRL + - (Minus)/PAGE DOWN for fine zoom out
Zoom by rectangle
CTRL + Right mouse button,
Middle mouse button,
CTRL + ALT + Left mouse button
Reset
CTRL + Right mouse button double-click,
Middle mouse button double-click,
CTRL + ALT + Left mouse button double-click
Reset axes
A, HOME
Copy bitmap
CTRL + C
Tracker
Left mouse button,
SHIFT + Left mouse button for points only tracker,
CTRL + Left mouse button for free tracker (show mouse coordinates basically),
