This section details how to configure Viz Virtual Studio.
  1. Click Open to select a previously saved studio configuration, or New Configuration to start an empty one. Save As stores the configuration you are working on under a new name.
    Set the Frequency frame rate. Available options are:
    • 50 Hz
    • 60 Hz
    • 59.94 Hz
    • 29.97 Hz
    • 30 Hz
    • 25 Hz
    • 24 Hz
    Set the Synchronization base:
    • Free Run: Does not synchronize. Tracking Hub runs using its own time base, corresponding with the configured frequency. This option should not be used in production environments.
    • AV-Card: Synchronizes using an installed Plura card. Note that the PCL-PCI L card can only read timecode and cannot be used for synchronization — see Important Checklist Before Installation.
    • VizEngine: Synchronizes with a Viz Engine running on the same computer.
    • NDI: Synchronizes on an NDI stream. See Embedded NDI+ Tracking Data.
  2. Go to Configure Topology.
