Viz Vectar Plus Release Notes
Version 1.3 | Published November 18, 2022 ©
Viz Vectar Plus 1.3.0.
Release Date: 2022-11-18
These are the release notes for Viz Vectar Plus version 1.3.0. This document contains a list of references to fixed issues regarding the user-visible changes that have been made to the software since release 1.2.1.
See https://www.vizrt.com/products/viz-vectar-plus for more details.
Improvements
Added Viz Engine Version 5.0.0
Support for CEF HTML/Web Buffers to bring in live websites, graphics or text into your productions.
Added the ability to delegate Mix 5-8 on the 4-stripe Control Surface.
Improved the way we handle audio when exporting using the M4V format.
Improved the NewTek Ethernet PTZ Control protocol in the Input Config window.
Multi-Select Mode button now has a macro shortcut associated with it (ddr#_multi_select_toggle).
If a macro and a macro folder have the same name, toggling one will no longer toggle both.
Known Issues
Caller audio distortion (clicks) heard from certain live call connect applications (Discord, WhatsApp, Facetime and Zoom).
Bug Fixes
Fixed an issue with the VU meter API data.
Fixed an issue where the buffer Layer Presets did not always match the thumbnails in the Title Presets tab.
Fixed an issue where the "dsk#_new_input_sel" macro did not function correctly.
Fixed a memory leak issue in some portrait aspect ratio sessions.
Fixed an issue where Arabic text was not formatted correctly when loaded into the Automation Teleprompter.
Fixed an issue where flickering could occur on quadlink output in specific circumstances.
Fixed an issue where the Unload option in the Buffer context menu was always greyed out.
Fixed an issue where the LCC camera options could be removed if NDI Tools was installed on a TriCaster.
Fixed an issue where a ShuttleXpress controller could stop functioning under specific circumstances.
Fixed an issue where Autoplay would not automatically transition a DDR off when playback completed.
Fixed an issue where an NDI PTZ camera source routed through an NDI router might not register as a PTZ camera.
Fixed an issue where the macro_is_enabled_byname shortcut was not working.
Fixed an issue where an invalid Update button was presented in the Administrator Mode menu.
Installation and Update
Installation: Refer to the Viz Vectar Plus User Guide, section Setup.
Update: Download the installer from the Vizrt FTP server. The installer performs the update.
Documentation
Latest documentation for Viz Vectar Plus is available at the Vizrt Documentation Center:
A User Guide is available from the installed application home page, by navigating to Help > Documentation > Live.
Support
