![](assets/images/logos/VizTickerLogo.png)
Viz Ticker Release Notes
Version 4.1 | Published February 02, 2024 ©
Viz Ticker 4.1.0
Release Date: 2024-01-22
These are the release notes for Viz Ticker version 4.1.0. This document describes the user-visible changes that have been done to the software since release 4.0.0.
Fixed Issues
Using a presentation template should no longer prevent unicode characters from being properly stored to message description (TICK-1888).
Web Client now stores Path instead of UUID for control geom and images, no longer breaking compatibility with desktop Client (TICK-1894, TICK-1895).
A flipping-scrolling carousel now properly sets message run counter as a flipping carousel does (TICK-1897).
A message moved inside a feed now properly retains their message take count (TICK-1806).
The generated description for elements using presentation template and containing material/geom/image no longer shows full Graphics Hub path (TICK-1154).
GPI configuration panel now only shows configuration lines for handler selected (TICK-1437).
Unexpected failure to parse individual messages by Ticker Feed could result in failure instead of error-messages to be logged out (TICK-1890).
Improvements
Ticker-feed now initiates the first polling after startup immediately instead of waiting a full interval (TICK-235).
Installation and Upgrading
The previous version of Viz Ticker Client must be uninstalled before the new one is installed.
Viz Ticker Client 4.1.0 only works towards a setup generated, or upgraded, by Viz Ticker Wizard 4.1.0.
Known Issues and Limitations
Most changes that are made using Viz Ticker Wizard/System-Tool while Viz Ticker Client is running are not reflected in Viz Ticker Client until it is restarted. Furthermore, some changes might cause Viz Ticker Client to crash. It is recommended to terminate Viz Ticker Client before making changes in Viz Ticker Wizard/System-Tool.
Viz Ticker Client allows loading data that has been exported from a previous version without giving any warning. However, this causes the data in Viz Ticker system to be incorrect. To upgrade data from previous versions, please use the upgrade functionality provided by Viz Ticker Wizard/System-Tool.
Viz Ticker Client allows the user to open, view and edit messages controlled by Viz Ticker Feed. However, there is no point changing the data manually as the messages are overwritten on the next Viz Ticker Feed update. Furthermore, Start/End time may show incorrectly in the UI when setting the begin/end elements in the Viz Ticker Feed source XML since the UI can only be used to visualize certain begin/end combinations.
In the rundown of a carousel, it is possible to set a message to play-out next on a particular output channel. When using Set as Next the Ticker System should be ON for the chosen Output Channel. Otherwise, the Set as Next is ignored when the carousel is later switched on (TICK-22).
System Requirements
Viz Ticker system consists of:
Viz Ticker Client
Viz Ticker Web Client
Viz Ticker Wizard
Viz Ticker Feed
Viz Ticker Service
The Viz Ticker system requires the following minimal software versions in order to operate:
Microsoft .NET Framework 4.6.1 or later
Media Sequencer 2.0 or later. Please avoid using Media Sequencer 3.1.0 because of a known issue with the background scene reference in that version.
Viz Engine 3.9 or later.
Graphic Hub 2.3.1 or later
Graphic Hub REST 1.1 or later. Graphic Hub REST 2.0 (or later) is required for the VTW image search functionality.
Note: Graphic Hub REST is only required if message templates are using tab-fields pointing to Graphic Hub resources or if using the VTW image search functionality with Graphic Hub as search provider storage.
Viz Ticker software is 32-bit. It can run on both 32-bit and 64-bit versions of Windows.
Operating systems that have reached their end-of-life cycle and are no longer officially supported by their manufacturers, are not supported for use with Viz Ticker.
System Requirements for Viz Ticker OneBox
The Viz Ticker OneBox system requires the following versions of Viz Engine:
3.14.5 or above on the 3.x release line, or
4.3.0 or above on the 4.x release line
If Viz Ticker OneBox is not enabled, see the requirements above.
Documentation
Documentation for Viz Ticker is available at the Vizrt Documentation Center:
Support
Previous Versions
In accordance with the Vizrt Global Support Handbook section Software Lifecycle, support for older versions of Viz Ticker ends 24 months after a subsequent minor or major version is released.
Viz Ticker version 4.0 support ends 2026-01-22. At the date of this release, Viz Ticker versions earlier than 4.0 are no longer supported.
