Viz Plug-in Release Notes
Version 5.1 | Published February 01, 2024 ©
Viz Plug-ins 5.1.1
Release Date: 2023-10-31
These are the release notes for Viz Plug-ins version 5.1.1. This document describes the user-visible changes that have been made to the software since release 5.1.0.
Viz Plug-ins 5.1.0
Release Date: 2023-08-30
These are the release notes for Viz Plug-ins version 5.1.0. This document describes the user-visible changes that have been made to the software since release 5.0.1.
Information: Viz Weather plug-ins are not yet included and need to be installed separately by installing the latest released Viz Weather Version.
This document includes the Release Information for:
  • Viz Basic Plug-ins
  • Viz Extensions Plug-ins
  • DataPool Plug-ins
  • Socialize Plug-ins
  • PixelFX Plug-ins
  • Maps Plug-ins
Installer Notes
The installation wizard guides you through the installation process. Make sure to close any running Viz application prior to the installation. In order to run Viz Artist or Viz Engine independent of a database server, you need to install the Viz Graphic Hub database software locally.
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
  • The basic plug-ins are installed by default, all other plug-in packages are optional.
  • Softclip comes in 32-bit (default) and 64-bit versions. To use the 64-bit version, replace the file Softclip.vip in \plugins with the one from the subfolder %ProgramFiles%\VizEngine\plugin\disabled.
Upgrade Notes
  • The path for the DataPool related files has been set to %\ProgramData%\vizrt\VizEngine\DataPool.
Changes
  • The User Interface of the following plug-ins have been ported to native QT style:
    • CFxPlusPlus
    • Dexter
    • ImageFx
    • pxGradient
    • pxLensRays
    • pxRecolor
    • RFxSmoke
    • TFXPlusPlus
    • Wave
  • Chromium libraries for the Brower plug-in have been upgraded to 108.0.5359.125.
Known Issues
  • RTT Shaders consume about 300-400 MB of RAM once they are initialized. If you do not use them or if you don't own a license, it is recommended to disable the plug-ins in the configuration panel in section Plugins (VIZENG-10224).
  • Softclip: Lagarith Codecs are playing slower on Windows Server Operating Systems. This issue can be solved by enabling Use Multithreading option in Lagarith codec configuration.
Basic Plug-ins Known Issues
  • On Dual channel setups Browser Plug-in causes performance impacts on second or higher instance.
Socialize Plug-ins Known Issues
  • Viz Engine can't access mapped network shares on Windows 10 for security reasons. If media files are stored on a network share, please be sure to enable Network Linking in Viz Configuration (Local Settings).
  • Trio 3.x and Viz Artist (UI) do not have full Unicode support yet (e.g. not all Emojis can be set by these control applications).
  • VLC plug-in requires some additional steps:
Maps Plug-ins Known Issues
  • When freezing a Map including Pyramids in CWMClient, Hop scenes no longer work (VIZPL-45).
Supported Hardware and Software
This software has been tested to run on:
  • Windows 10 (LTSC 1809), Windows 10 LTSC 21H2
  • Windows 11
  • Windows Server 2019
  • Windows Server 2022
Note: Only English language Operating System(s) are supported.
Build Information
Platform Toolset: Visual Studio 2019 (v142)
Windows SDK Version: 10.0.14393.0
Documentation
Documentation for both Viz Engine and Viz Artist are available at the Vizrt Documentation Center:
Support
