This section shows how to integrate a Viz World Client with Viz Pilot Edge.
Note: Viz World maps can be used in graphic templates if the scene contains the ControlWoC plug-in. In Template Builder this is imported as a Map field type. Note that ControlMap is not supported in this workflow.
Requirements
  • A connection to a Viz World Server is required to select maps.
  • A local Viz World Client installation is required to edit maps.
Note: For more information about the Viz World Client and Server, and scene design, see the Viz World User Guide and the Plug-ins User Guide, respectively.
Viz Pilot Server Settings
  1. Install Viz Engine.
Info: The Map Plug-in must be explicitly selected to install with Viz Engine.
  1. Install the Viz World Client. It is recommended to install the bundled installer that includes both the 32-bit and 64-bit versions. The Viz Pilot Edge workflow often includes Viz Pilot, which requires a 32-bit installation.
    1. Make sure the Microsoft Visual C++ 2010 Redistributable Package (x64) is installed, otherwise the Viz World Client installer does not run.
    2. Download the Viz World Client and run the installer.
  2. Modify Viz Config.
    1. Run Viz Config.
    2. Select Maps.
    3. Set the Map Server to Active.
    4. Type in the maps server name in Server.
    5. Click Save and close the Viz Config window.
    6. Run the Viz Config again.
    7. Select Maps. A list of .tpl files is shown in the Available section.
    8. Select the desired files to add them to the Project.
    9. Click Save and close the Viz Config window.
    10. Restart Viz Engine.
      Important: Remember to restart Viz Engine.
  3. Pilot Data Server Configuration.
    1. Run the Pilot Data Server in a browser: http://dataserver.example:8177.
    2. Click Settings.
    3. In the Parameters tab add the maps server name in shared_curious_server.
Workstation Settings
  2. Viz World Client Configuration
    1. Run C:\Program Files\vizrt\Common\Maps\MapsClient.Service.exe.
Note: This step is important, but you do not get any explicit feedback once it is completed. You must complete this step in order to launch the Maps Editor from Vizrt's web applications.
You must re-run MapsClient.Service.exe every time you either: 1) Restart your PC or 2) Update the Viz World Client.
b. If you want to open the Maps Editor from outside Vizrt's web applications, you must launch C:\Program Files\Vizrt\Common\Maps\MapsClient.exe and specify the maps server name as the server in the Login dialog.
