Graphics Plugin (NLE)
Graphics Plugin supports Viz Pilot Edge. Viz Pilot Edge can be opened from Graphics Plugin, and the same interface is available in your craft editing system. In this workflow, Viz Pilot Edge only handles graphics.
Viz Pilot News
ActiveX-based templates used in Viz Pilot News cannot be migrated to HTML-based templates used in Viz Pilot Edge, because the technologies are incompatible. However, a simplified editor for these templates is available in Viz Pilot Edge. To use customized versions of the templates, you must recreate templates individually over time. Vizrt provides tools to assist with this process, see Migrating from Pilot News.
Template Builder
Template Builder is a tool to create and customize templates for Viz Pilot Edge. You can use TypeScript to customize templates (see below), or use Custom HTML Panels to load advanced self-hosted JavaScript and HTML UI to the template.
  • Template Scripting section of the Template Builder User Guide.
