Viz Pilot Edge User Guide
Version 2.0 | Published May 07, 2021 ©
Other Workflows
Graphics Plugin (NLE)
The Graphics Plugin also supports fill in form technology. Viz Pilot Edge can be opened from the Graphics Plugin, and the same interface is available in your craft editing system. Viz Pilot Edge is only available for handling graphics in this workflow.
Viz Pilot News
ActiveX-based templates used in Viz Pilot News cannot be migrated to HTML-based templates used in Viz Pilot Edge, since the technologies are incompatible. You need to recreate templates one-by-one over a period of time. Vizrt has tools for assisting you in this process, see Migrating from Pilot News.
Template Builder
Template Builder (bundled with the Pilot Data Server) is a tool for creating complex templates. You can get the same functions as Viz Pilot News templates have by applying separate javascript code stored on any web server. This requires re-coding of the templates.
