Viz Pilot Edge User Guide
Version 1.2 | Published May 02, 2018 ©
Keyboard Shortcuts
The most important keyboard shortcuts in Viz Pilot Edge are the ones used in the timeline editor. They allow the user to navigate and make edits within the video clip.
Keyboard shortcut information is available clicking the
button in the timeline editor.
The following keyboard shortcuts are available:
Action |
Shortcut |
Keyboard shortcuts information |
Shift +K |
Play/pause |
Space or Ctrl + Space |
Loop video |
R |
Delete on selection |
Backspace or Delete |
Mute |
M |
Select previous item |
Select next item |
Move 1 frame back |
, (comma) |
Move 1 frame forward |
. (period) |
Play backward - press multiple times to increase speed |
J |
Pause |
K |
Play forward - press multiple times to increase speed |
L |
Mark In point |
I |
Mark Out point |
O |
Go to In point |
Shift + I |
Go to Out point |
Shift + O |
Clear In/Out points |
Shift + C |
Play backward at 0.5x speed |
Alt + J |
Play forward at 0.5x speed |
Alt + L |
Move selected item left by 1s |
Ctrl + ← |
Move selected item right by 1s |
Ctrl + → |
Move selected item left by 10s |
Ctrl + Shift + ← |
Move selected item right by 10s |
Ctrl + Shift + → |
Move 10 frames forward |
Grow selected item by 1s |
Ctrl + Alt + → |
Shrink selected item by 1s |
Ctrl + Alt + ← |
Grow selected item by 10s |
Ctrl + Alt + Shift + → |
Shrink selected item by 10s |
Ctrl + Alt + Shift + ← |
Zoom timeline |
Shift + scroll |
Move timeline |
H + drag |
A Log Window displaying Messages, Warnings and Errors becomes available using shortcut: Alt + 1.
