Viz Now Release Notes
Version 1.2 | Published May 07, 2024 ©
Viz Now 1.2.5
Release Date: 2024-05-06
These are the release notes for Viz Now version 1.2.5. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.2.4.
-     To access Viz Now, navigate to https://now.vizrt.com.
Main Features
-     New App: Comprimato Live Transcoder. -     Can be configured to receive numerous streams and convert them to NDI.
Improvements
-     Improved the SEO of the Viz Now for search engines.
-     TriCaster Now: -     Credits logging has been improved.
-     Auto-shutdown feature now supports email.
Viz Now 1.2.4
Release Date: 2024-04-09
These are the release notes for Viz Now version 1.2.4. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.2.3.
Main Features
-     Tags -     Tags added to a Space will be applied to all resources deployed by Viz Now.
-     Organization admins can define tags that can be applied to Spaces, both with selectable options or customizable text.
-     Organization admins can define mandatory tags that must be applied to Spaces.
-     Organization admins can define tags that will be applied to all Spaces.
Breaking Changes
-     Existing tags on existing spaces will be removed and Spaces created before 1.2.4. will not apply tags in AWS.
-     Templates will no longer have any predefined tags.
Fixed Issues
-     New g4 and g5 instances running Windows OS will now mostly use NVIDIA driver 538.15.
 Release Notes, supported GPUs and other documentation can be found at: https://docs.nvidia.com/datacenter/tesla/index.html
-     New instances running Windows OS will now use the NICE DCV server 2023.1.16388 Dec2023.
 Release notes can be found at: https://docs.aws.amazon.com/dcv/latest/adminguide/doc-history-release-notes.html#dcv-2023-1-16388Note: It is recommended to also upgrade your NICE DCV client to the latest version: https://www.nice-dcv.com/latest.html
Viz Now 1.2.3
Release Date: 2024-01-23
These are the release notes for Viz Now version 1.2.3. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.2.2.
Main Features
-     It is now possible for the Organization Admin and Editors to have multiple VPC Peering between their Viz Now spaces and\or other AWS VPCs either on the same AWS account or cross accounts (see updated documentation). -     New editor control to easily manage VPC Peerings.
Breaking Changes
-     Existing VPC Peerings will now use the new UI interface
Fixed Issues
-     Using the latest Chromium browser caused issues when switching the instance type of an App.
-     Issue with Allowed IPs when using special characters was fixed.
Improvements
-     After feedback from users, the downloadable .dcv file will no longer by default use all available screens when launching. The user has to do this themselves in the NICE DCV Settings menu.
-     It is now possible to add a value to the tags that are configured for each space.
Viz Now 1.2.2
Release Date: 2023-11-24
These are the release notes for Viz Now version 1.2.2. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.2.1.
Main Features
-     TriCaster® Now is now available as a subscription.
Breaking Changes
-     Any existing Space continues to work as expected after the update.
Fixed Issues
-     NDI Bridge can be configured works in join mode on the NDI App running in Cloud.
-     Fixed issue with NICE DCV server in some rare cases not working after bringing App online after being offline.
Improvements
-     Showing private IP
-     Improved performance
Viz Now 1.2.1
Release Date: 2023-11-03
These are the release notes for Viz Now version 1.2.1. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.2.0.
Breaking Changes
Fixed issues
-     When the admin is adding more than one user sometimes the operation fails. Workaround is to add one user at the time. Temporarily fixed by limiting to adding two users at a time.
Improvements
-     Security has been enhanced.
Viz Now 1.2.0
Release Date: 2023-10-23
These are the release notes for Viz Now version 1.2.0. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since the Viz Now 1.1.0.
Breaking Changes
 The new NDI Bridge requires also an update of the client application. It is not backwards compatible.
Fixed issues
-     Several deployment issues were solved.
Improvements
-     All apps were updated. -     Windows server 2022
-     NVIDIA drivers 528.89
-     NICE DCV 23.0
-     Updated Apps to latest version -     TriCaster® Vectar 1.4.0
-     Viz Artist\Viz Engine 5.1
-     Viz Graphic Hub 3.9.1
-     NDI Tools 5.6 (including NDI Bridge)
-     Viz Media Sequencer 5.5
System Requirements
-     Internet browser
-     AWS Account
-     NICE DCV client - NICE DCV | Download (nice-dcv.com)
Documentation
Latest versions of documentation:
-     Viz Now User Guide
-     Viz Now Administrator Guide
is available at available on the Vizrt Documentation Center and at the Vizrt FTP.
Support
