Viz Multiplay User Guide
Version 3.0 | Published October 23, 2020 ©
System Overview
Viz Multiplay
Is compatible with graphics from Viz Trio and Viz Template Wizard. Shows from Viz Trio are available in Viz Multiplay.
Can access and use templates and elements in a Pilot Data Server.
Is hosted on a URL on the Media Sequencer. Any number of clients can connect to the same Media Sequencer, which provides the scheduling for playout.
Uses Viz Engines for playout:
The video wall feature allows up to four DisplayPort outputs with UHD resolution from a single GPU in a Viz Engine. With Datapath Fx4 display controllers, the number of outputs can be increased to match numerous screens and panels of different shapes and orientations.
Also supports Standard SDI-based playout.
Can access media assets stored in Viz One and Media Service.
Can open MOS playlists.
Note: It's recommended to check the performance of scenes when using complex configurations.
