This section is the working reference for everyday use of Smart Panel: managing your panels, shaping the canvas, placing and configuring panel items, binding buttons to commands, and using a finished panel on air. It assumes you have followed Get Started at least once and have a working connection to Viz Mosart.
Managing Panels
All panels live on the Mosart Web Apps server, so anyone who can reach the Smart Panel URL sees the same list and works on the same panels. The landing page (/smartpanel) is the entry point for panel management. It is headed Your panels.
Smart Panel also ships with a small library of read-only preset panels. Presets are not listed on the landing page and cannot be edited in place: they are offered as starting points under Use a preset in the Create new panel dialog. Anything you create from one is a normal, editable panel, and the preset itself stays untouched.
From the landing page you can:
Create a panel. Click New to open the Create new panel dialog. Choose Blank panel to start from an empty canvas, or one of the panels under Use a preset to begin with a ready-made layout. Give it a Name and click Create; Smart Panel opens it in the editor. The New button is shown only to a user who can edit panels.
Find a panel. The Search panels... field above the cards filters the list by name, which is what you reach for once a site has more panels than fit on a screen.
Open a panel. Click its card. If you have edit rights it opens in the editor at
/smartpanel/<panel>/edit; if you can only view panels it opens straight in display mode.Open a panel to run it. Choose Display mode from the card's options menu, or navigate to
/smartpanel/<panel>without/edit.Hand a panel to an operator. Use the Copy link button on the card. The link opens the panel in display mode. It carries no key, so it can be shared; on a site without OIDC sign-in, a device that has not been paired asks for a pairing code the first time.
Duplicate a panel. Choose Duplicate Panel from the card's options menu, or from the more-options menu inside the editor.
Rename a panel. Open it in the editor and click the panel name in the app bar.
Delete a panel. Choose Delete Panel from the card's options menu, or from the editor's more-options menu. Deletion is permanent and removes the panel for everyone, so confirm before deleting a panel that may be in use.
Info: Panel names do not have to be unique. Two panels may share a name, so if your team relies on names to tell panels apart, agree on a convention.
Note: If you try to leave the editor with unsaved work, Smart Panel asks what to do rather than discarding it silently. Save before you navigate away if you want to keep the changes.
The Editor
The editor has an app bar across the top and three working areas below it:
The Components palette on the left, holding the item types you can place.
The canvas in the middle, which is the panel itself, with the page bar above it: a tab for each page of the panel, and on the right the panel's aspect ratio and the number of components on the page shown.
The Layers list on the left under the palette, and the Properties pane on the right, which has a Component tab for the selected item and a Panel tab for the whole panel.
Both side panes can be resized by dragging their inner edge, so you can give the canvas more room while working on a dense panel, or widen the properties pane when configuring an item with many settings.
The app bar
The app bar carries the panel name, which you click to rename, and:
An Edit and Preview switch. Preview shows the panel as an operator would see it without leaving the editor, which is the quickest way to check spacing and legibility. A user who can only view panels never sees this switch: the editor is not open to them, and an edit link takes them to display mode instead.
Save, which is available only while the panel has unsaved changes. There is no Discard button in the app bar. If you try to leave the editor with unsaved work, a Save changes dialog offers Save, Discard and Cancel.
NDI Stream, which publishes this panel as an NDI source and stops it again.
Two icon buttons next to the connection chip: Copy link, which copies the display-mode link to the clipboard, and a play button, which opens this panel in display mode in a new tab. The play button is the quickest way to see the panel exactly as the operator will.
A more-options menu holding Duplicate Panel, Copy Link and Delete Panel, with Audio Countdowns added at the top only on a panel that uses audio. Duplicate Panel is unavailable while the panel has unsaved changes, and says so in a tooltip; Delete Panel is unavailable on a read-only preset.
The ? help menu, and an Offline chip whenever Viz Mosart is unreachable.
Info: the panel actions menu, click-to-rename, Save and NDI Stream all appear only for a user who can edit panels. A viewer does not reach the editor at all: opening a panel, or following an edit link, takes them to display mode, which has no app bar.
Tip: Press K at any time for the keyboard shortcut list. See Keyboard Shortcuts at the end of this page.
Panel properties
With no item selected, the right pane opens on its Panel tab. These settings apply to the canvas and govern the whole panel, in the groups Panel, Grid settings, Page navigation (on a panel with several pages), Component presets and Ready check. Selecting an item switches the pane to the Component tab, and you can open Panel again at any time.
Property | What it controls |
Fill (Panel group) | The color behind all items. Pick something that contrasts with your item colors and is comfortable to look at for a long show. |
Rows and Columns (Grid settings) | How finely the canvas is divided. Items snap to cells. Increase the counts for fine-grained panels, decrease them for chunky touch buttons. |
Aspect ratio (Grid settings) | The shape of the canvas. Pick one of the presets, choose Custom and enter your own width and height, or choose None to stretch to fit the browser window. Match this to your target screen so the panel looks right on air. |
Page navigation | The page buttons of a panel with several pages. See Pages below. |
Padding (Component presets) | The padding of every item that does not set its own. |
Small (S), Medium (M) and Large (L) (Component presets) | Three named text sizes, defined once here in pixels. Items then refer to them as S, M or L instead of carrying their own pixel values. Changing a preset updates every item that uses it. |
Ready check | What the running panel says about whether its components will work, and what its Ready sheet may do before the show. See Ready check under Running a Panel On Air. |
Working with Items
Panel items are the building blocks of a panel. They all behave the same way on the canvas, whatever their type.
Adding an item. Drag an item type from the palette onto the panel, or click the item type and then click where you want it. Either way, a label with the item type's icon and name follows the pointer until you reach the canvas. Over the canvas, the cells the new item will take are outlined instead, centred on the pointer as far as the grid allows, and inside the section under it where there is one. When you click first, the item waits until you place it. To cancel, press Escape, click the item type again, or click outside the canvas and the palette. Once placed, its settings appear in the Properties pane.
Selecting an item. Click it on the canvas, or its entry in the Layers list. The selected item shows its handles and its properties populate the pane.
Moving and resizing. Drag the item body to move it, and a corner or edge handle to resize it. Items snap to the grid, and while you drag, the cells the item will snap to are outlined beneath it. With an item selected you can also nudge it with the arrow keys and resize it with Shift and the arrow keys.
Copying an item. Use Ctrl+C and Ctrl+V (Cmd on a Mac), or the Duplicate action in the Layers list. To drop a copy where you want it, drag the item and hold Alt (Option on a Mac) as you let go: the copy lands there and the original stays where it was.
Deleting an item. Select it and press Delete or Backspace, use the Delete action in the Layers list, or drag it onto Drop to delete, which appears at the bottom of the canvas while you move an item. The message that follows offers Undo.
The Layers list. Every placed item appears in this searchable list, in the left column under the palette. Use it when items overlap and you need to reach one underneath another, when the panel is busy and you want to jump straight to something by name, or simply to confirm what is on the panel. Drag a row by its handle to change the stacking order. A section's row names the variant it shows, and lists that variant's components under it, which the row can fold away. Each row has an options menu with Copy, Duplicate, Bring to front, Send to back, the moves to other pages and into or out of sections, and Delete, and the list header has one with Copy all, Paste and Clear all.
Tip: Give each item a descriptive name by double-clicking its name at the top of the Component tab (for example Take button, Story countdown). The name appears in Layers, and naming as you go pays off quickly as the panel grows.
Item properties
The Component tab is the same for every type from top to bottom: a header, Position and size, a group named after the item's type with the settings only that type has, and Appearance. A Button, a Live item and a web page add an Interaction group for what a press does.
The header carries the item's name, which is the name used in Layers. Double-click it, or use the Rename button, to rename the item; Enter keeps the name and Escape cancels it, and an emptied name goes back to the automatic one. The eye button decides whether the name is also drawn on the item itself, and the Component actions menu holds Copy, Duplicate, the moves to other pages and into or out of sections, and Delete.
Position and size: X and Y, the column and row of the item's top left cell counted from 0, and W and H, its width and height in cells. Inside a section they count the section's own grid. The fields follow the canvas while you drag, and a number typed in moves the item at once.
Appearance on a Timer, Label, Text or Button: Fill and Text colors, entered as hex values or picked from the swatch, which opens a palette with No fill (transparent) where it applies and Custom color for any other color; Bold font, ON or OFF; Align, left, center or right, which a Button does not offer; and Text size, S, M or L from the panel presets or Fill to scale the text to the item bounds, between Min text and Max text.
Padding, at the end of Appearance on every type, defaulting to the panel-wide value. An Image adds a Fill color of its own, and the other types have nothing else there.
While a setting such as Padding, Min text, Max text or a color holds a value of its own, its name is underlined: click the name to put the default back.
Pages
A panel can hold several pages, so one screen can carry more controls than fit on it at once, for example the cameras on one page and the audio on another. The pages share the panel's grid, aspect ratio, background and presets, and each page has components of its own. A new panel starts with one page, Page 1.
The page bar above the canvas has a numbered tab for each page:
Add a page with the + button after the tabs. The new page is empty, is named Page 2, Page 3 and so on, and opens at once. A panel can have up to 100 pages.
Switch page by clicking its tab. With a tab focused, the arrow keys, Home and End move between pages. Switching page clears the selection.
Rename a page by double-clicking its tab, or by pressing F2 on a focused tab. Enter keeps the new name and Escape cancels it.
Delete a page with the close button on its tab, or by pressing Delete on a focused tab. The Delete page dialog says how many components go with the page, and warns when components elsewhere on the panel go to it when pressed. The last page cannot be deleted.
Move a component to another page with Move to and the page's name, in the component's actions menu or in its row menu in the Layers list. It keeps its position where those cells are free on the other page, and takes the first free spot otherwise.
On the landing page a panel with several pages says how many it has, and its card shows the first page, which is the page the panel opens on.
Page buttons
Display mode has no page bar, so the operator changes page with page buttons on the panel itself. Adding a second page turns them on, and deleting the panel back to one page turns them off. They are set in the Page navigation group of the Panel tab, which appears once the panel has more than one page:
Page buttons: SHOW or HIDE.
Layout: Single puts one button in a corner, chosen under Corner, which steps to the next page and from the last page back to the first. Prev + next puts a previous and a next button in the two corners of one side, chosen under Side as the top or the bottom.
Each page button takes one grid cell and shows the page on screen out of the total, for example 2/3. It sits on top of any component in that cell, so keep the cell free. In the editor the buttons only mark their cells and do not react; in display mode, and in the editor's Preview, they switch page. With the page buttons hidden, a Button with the Navigate to page command can switch pages instead.
Item Reference
The palette holds fifteen item types, three to a row.
Item | What it is for |
Timer | A live timer or countdown driven by Viz Mosart. The basis of a timing display for the control room or the studio floor. |
Label | A live text value from Viz Mosart, such as the current item slug or story name. |
Text | Static text that does not change at runtime. Titles, group headers, instructions, branding. |
Image | A static image uploaded to the server. Logos, role icons, decoration. |
Widget | A category hosting eight built-in variants, from the timeline to a Viz Pilot Edge template and the Media Router's routing matrix. |
Web page | An external web page embedded in the panel, with an optional click action. |
Prompter | The Prompter's rolling script. |
Asset list | A filtered list of the assets in the rundown, each a take. |
Graphics | A Graphics Playlist of the rundown's overlay graphics, to preview, take in and take out. |
Status | The Viz Mosart connection state, or the state of each Viz Mosart device. |
Fader | An audio fader bound to a Viz Mosart audio channel. |
Button | The main interactive item. Sends a command when tapped, and can carry a second action on the next tap. |
Rehearsal | A control that shows whether Viz Mosart is in rehearsal mode, and flips it when tapped. |
Live | A live video preview, with an optional click action. |
Section | An area of the page that shows one of several sets of components at a time, switched by buttons. |
Timer
Shows a live timer or countdown driven by Viz Mosart, synchronized with the active rundown. Use it to build timing displays: one on the studio floor counting the current item, another in the control room counting packages to keep the producer updated.
Pick the value from the Variant drop-down in the Timer group. There are twenty-one:
Group | Types |
Current item | Current Item Countdown (the default), Current Item Time |
Current story | Current Story Countdown, Current Story Planned Duration, Current Story Time |
Next | Next Break Time, Next Item Duration, Next Live Countdown, Next Story Planned Duration |
Rundown | Current Rundown Out, Rundown Elapsed Time, Rundown Over/Under, Rundown Out Over/Under |
Time and break | Time of Day, Time to Next Break, Time to Rundown Out, Duration to Next Break, Duration to Rundown Out |
Story Recorder | Story Recorder Preroll Countdown, Story Recorder Recording Time, Story Recorder Countdown |
Besides the shared properties, a Timer offers Overtime accent, SHOW or HIDE. Shown, the timer changes its background color once it passes zero, which is what you want for countdowns and over/under timers. The same setting is offered on a Label, so a label that reports a negative value can carry the same background change.
Info: There is no per-threshold coloring. Over-time appearance comes from Overtime accent plus the Fill color you choose, not from separate warning and critical colors.
Clock values
Two of the timer types show a wall clock rather than a duration: Time of Day and Next Break Time. Both follow the time zone of the machine the panel is open on, so a panel on a studio screen in another region reads the local time there rather than the automation system's. They are written according to that browser's language settings, always with a two-digit hour.
An administrator can change both of those choices for the whole installation, selecting the Viz Mosart server's time zone instead, or setting the format explicitly with a 12 or 24 hour clock and a regional format. The controls are on the Smart Panel tab of App Configuration in the Configuration Tool; see App Configuration. A panel reads them when it loads, so reload a panel that is already open after they change.
Note: This needs Viz Mosart 5.17 or later. Against an older server the time zone setting has no effect on Time of Day: it shows the Mosart server's wall clock whichever zone is selected, which is what to suspect when that clock reads a time zone you did not choose. The format setting still applies to it. Next Break Time does follow the time zone setting against an older server, but with the Mosart server time zone selected it arrives already formatted by the server, so that is the one value that can show AM and PM on a 24 hour site.
Label
Shows a live text value from Viz Mosart. The same role as a Timer, but for text. Pick the value from the Variant drop-down in the Label group; there are eleven:
Group | Sources |
Current | Current Item Slug (the default), Current Story Name, Current Video Server Channel, Current Graphics Channel |
Next | Next Item Slug, Next Story Name, Next Video Server Channel, Next Graphics Channel |
Rundown and server | Rundown Name, Server Description |
Panel | Page Title, the name of the page the label is on. It comes from the panel itself, so it shows whether or not Viz Mosart is connected. |
Info: The list is fixed. There is no free-form expression, so a Label cannot be bound to an arbitrary Viz Mosart value that is not in the list. Long values can overflow a narrow item, so either size it generously, drop to a smaller preset, or set Text size to Fill with sensible bounds.
Text
Static text, typed by you rather than read from Viz Mosart. Use it for section titles such as Cameras or Audio, group headers, on-screen instructions, and branding such as Studio 3.
The only type-specific property is Custom text, the text itself. Manual line breaks are preserved, so you can lay out a caption over several lines instead of relying on wrapping. The same applies to button labels.
Info: Text items never update on air. If the value should change with the show, use a Label instead.
A static image uploaded to the Mosart Web Apps server and stored with the panel, so every device that opens the panel gets the same file. Use it for studio logos, small role icons next to related buttons, and visual markers that help an operator orient themselves.
Image: its upload button opens a file picker, and once a file is uploaded it reads Replace. Allowed formats are .jpg, .png, .gif and .webp, and the maximum file size is 5 MB. Until something is uploaded, the item shows a placeholder on the canvas.
Scaling has five values: Fill covers the whole item and may cut off the picture's edges, Fit shows the whole picture inside the item and may leave empty space, Stretch fills the item exactly and may distort the picture, Original size shows the picture at its own size, centred, and Shrink to fit behaves like Fit but never enlarges. A new image starts on Fill, 4 cells wide and 2 high.
Fill, in the Appearance group, is the color that shows through wherever the scaling leaves space, or where the image itself is transparent.
Info: There is no opacity property. To dim an image for a watermark effect, bake the transparency into a PNG before uploading it.
Widget
Widget is a category rather than a single item. Drop one on the canvas and pick which of its eight built-in variants it shows from the Variant drop-down in its Widget group. A variant with settings of its own adds a group named after it below.
Variant | What it shows |
Timeline | The Viz Mosart timeline for the current story. |
Story Script | The script for the current story. |
Current Item Type | A visual indicator of the on-air item's type, such as camera, package or graphic. |
Next Item Type | The same, for the next item. |
Audio Toggles | Read-only indicators for five Viz Mosart audio modes: HA for hold audio transition, K for keep sound levels, FM for fade manual, L2 for use level 2 preview and an underlined L2 for use level 2 on air. Each lights up when its mode is on. Indicators picks which of the five appear. They report state only, so tapping one does nothing. |
Video Transition | Read-only indicators for the video transition: HV for hold video transition, M for mix, W for wipe, E for effect, and a fifth cell carrying the transition rate in frames, or the effect name when an effect is set. Indicators picks which of the five appear. |
Pilot Edge Action Panel | A Viz Pilot Edge template hosted in action mode, as a permanent control surface. See below. |
Media Router Matrix | The live routing of a Viz Mosart Media Router, as a matrix of inports and outports. See below. |
Five more live views have tiles of their own in the palette, and their settings sit in a group named after the tile:
Component | What it shows |
Status | Shows picks one of two views. Connection: the Viz Mosart connection state, shown as a beacon for the main server, with a second beacon for the backup where redundancy is configured. Hovering a beacon reports the Viz Mosart Server version it is connected to, and while the main server is idle, tapping its beacon on a running panel offers to make it active, confirmed with a hold, where the panel's Ready check allows it. Otherwise the panel says to make it active in Viz Mosart. Devices: live status indicators for the connected Viz Mosart devices, showing connected, disconnected or standby. |
Asset list | A filtered list of the assets in the rundown. See below. |
Graphics | A Graphics Playlist: the rundown's overlay graphics as a table, story by story, to preview, take in and take out. See below. |
Prompter | The Prompter's rolling script, embedded from the Prompter app in its display-only mode. The Prompter's controls, status strip and banners are hidden, so the component shows the script and a thin progress bar at the bottom of the frame and nothing operable. To start and stop the roll from the panel, add a Button with the Prompter Play/Pause command. |
Web page | An external web page embedded in the panel. See below. |
Apart from Web page, Pilot Edge Action Panel and Media Router Matrix, all of these are driven by Viz Mosart and need a live connection to show real data. Without one they show placeholder content.
Asset list
The most configurable component. It lists the assets available in the show and can be narrowed down heavily, so several asset lists on one panel can each cover a different job, for example manual overlays, overlays on the current story, fullscreen graphics, and everything in the rundown.
Asset source: Mosart rundown, or Media Sequencer for a playlist or show. Choosing Media Sequencer requires the Media Sequencer to be configured, and replaces the groups below with Source, holding the MSE profile, the Source type (playlist or show) and the Source to read from, and Display, holding Thumbnail and Group name.
In the widget: Story filter and Asset filter, SHOW or HIDE, decide whether the operator gets those two filters in display mode, so they can narrow the list themselves. The choice under each applies whether it is shown or not, as where the list starts or as what it always lists: Stories is All, On Air or Next, and Assets is All, Scheduled or Manual.
Display: under Sort by, Timeline keeps the rundown order and Template groups the items by template type. Under Layout, List gives one row per asset, and Tiles wraps the assets as tiles in a card per story, sized with Tile size (S, M, L or XL). Thumbnail shows or hides thumbnails, with their Size, and Story name and Script add context to each row. Tiles does not offer Script.
Stories to include: Story slug filter, Show the stories whose type is and Show the stories whose status is: narrow the list story by story before any asset is looked at, so a story that fails is left out with all its assets. The story types are Camera, Package, Voice-over, Live, Graphics, DVE, Telephone and Float, and a story of none of these types, such as a segment break, always stays. The story statuses are Valid, On air, Next, Aired and Other: the story on air answers to On air alone and the next story to Next alone, whatever status they carry, and a status none of the boxes names counts as Other.
Assets to include: the filters below, applied to the assets of the stories that remain.
Show the assets whose type is: show or hide each of Camera, Video, Live, Graphics, DVE, Float, Overlay graphic and Accessories independently.
Destination filter: restrict graphics to the graphics destinations you list, each written in full. An asset with no destination always stays.
Slug filter and Template variant filter: show only the items whose slug or template variant matches one of the terms. Put * at either end of a term as a wildcard, for example *goal* or CAM*. The story slug filter takes wildcards the same way. For an overlay graphic with a graphics destination, the Template variant filter matches the destination instead of the template variant.
Show the assets whose status is: show or hide Valid, Invalid, On air, Aired and Other items independently. The item on air answers to On air alone and an item that has aired to Aired alone, whatever status they carry.
Show the assets whose template is: Valid for items with a template that is present and not empty, Unavailable for the rest. Overlay graphics, sound items and accessories carry no template of their own and always count as Valid. Clear Unavailable to leave out items with no usable template.
The four text filters, for story slugs, destinations, slugs and template variants, each hold a list of terms. Type a term and press Enter, or click the + button beside the field, to add it as a chip. Click a chip's text to edit it, and its close button to remove it. A comma-separated list pasted into the field becomes one chip per term. An item passes when any term matches, case is ignored, and a filter with no terms lets everything through.
Note: Filtering by story type and story status needs Viz Mosart 5.19 or later. Against an older server the story type boxes have no effect, and every story other than the one on air and the next one counts as Other.
Rows carry the item slug and, for overlay graphics, their on-air status, so an operator can see what is already live before taking something. Items the Viz Mosart GUI added to a story itself, such as a direct take, are not listed, and an asset that appears twice in a story is listed once. In display mode, and in the editor's Preview, a row is also a take: tapping it takes that asset, a template for a rundown asset and the graphic for a Media Sequencer source. As with a Button there is no confirmation, so place an asset list where an operator will not brush it under pressure.
Graphics Playlist
The Graphics tile adds a Graphics Playlist: a table of the rundown's overlay graphics, story by story, from which an operator previews graphics, takes them in and takes them out. Each row shows the graphic, its destination and how it leaves air: after a duration, at the end of its item (Item end) or story (Story end), or only when taken out (Open end). The story on air is highlighted, a graphic on air carries an On air badge, and graphics that have aired are dimmed. A Graphics Playlist preset panel holds one, ready to use.
In display mode, and in the editor's Preview, each row has Preview, which sends the graphic to the preview engine, and Take in. On a graphic that is on air, the On air badge is its Take out button. A graphic with continue points plays in steps: taking it in shows its first state, and each continue moves it on to the next. When any graphic in the playlist has continue points, the table gets a Continue column (with Row buttons on). Off air it shows how many points a graphic has, such as 3 points (1 point for one). On air with points left it is a button that names the point it takes next, such as Continue 2/3, or just Continue while the panel does not yet know how many points have been taken. Once the last point is taken, the column shows the progress, such as 3/3, and no button. Each continue sweeps across its row, including a continue made from the Viz Mosart GUI or another panel. In the editor the rows show live data but the buttons do nothing, and the widget says so. Once the playlist has focus it also works from the keyboard: the arrow keys move between graphics, Page Up and Page Down move between stories, Space sends the graphic to preview, Enter takes it in and, on a graphic on air with continue points left, continues it, Delete or Backspace takes the graphic out if it is on air, Home takes the last graphic out and Ctrl+X takes all graphics out.
Its settings are grouped as follows:
In the widget: Destination filter shows a filter in the Destination column header, with which the operator turns destinations on and off. Shortcuts button shows a button at the left of the header that lists the playlist's keys. Row buttons shows Preview and Take in on each graphic, and a Continue column when any graphic has continue points; hidden, the table shows a status column instead, and a graphic with continue points shows a small mark beside its name: the number of points or, on air once known, how many have been taken out of the total.
Display: Thumbnail and its size, Story names for the page number and story name on each story's first graphic, and Empty stories to list stories with no overlay graphics too, so the table follows the whole rundown.
Graphics to include: Destinations, a list of destinations, each written in full, saved with the panel. With none, every destination is listed, and the operator's filter can narrow the list further.
Note: Previewing, taking in, taking out and continuing from the Graphics Playlist needs Viz Mosart 5.19 or later.
Hosts one Viz Pilot Edge template in its action mode, so an operator fires the template's own controls from the panel. You pick the template by title from your Viz Pilot Data Server, and a template designed for action mode works as it is.
The Pilot Data Server is set once for the whole installation, on the Server Configuration page of the Configuration Tool. If none is set there, Smart Panel uses the server of a Viz Pilot Edge plugin configured for Showmaker or the Named Overlays Editor, unless that plugin is on localhost. Without either, you cannot pick a template, and the widget says so: No Pilot Data Server is configured. Set it up on the Server Configuration page of the Web Applications Configuration Tool. See Server Configuration.
Select template ...: opens a searchable list of the templates on the Pilot Data Server. Once one is chosen, its title and ID are shown, with a pencil to change it.
Edit in Template Builder: opens the chosen template in a new tab, in the Template Builder set on the Server Configuration page.
Show template name: adds a header carrying the template title above the frame.
Set a playout target: when on, the template uses the Media Sequencer configured for the Web Apps as its playout target, with the Profile and Channel you set here. You pick them from lists read from that Media Sequencer, or type them when it cannot be read. Turn the switch off if the template's script sets its own target. With the switch on and no Media Sequencer configured, or only localhost, the frame stays empty and the widget says what is missing.
In the editor the frame is inert, so clicks select the widget and nothing fires. In display mode, and in the editor's Preview, the template is live. Signing in to a secured Pilot system happens in the operator's browser, with the method chosen in the Configuration Tool.
Info: None of the preset panels uses this variant, because it needs your site's Pilot Data Server.
Media Router Matrix
Shows the routing of a Viz Mosart Media Router live, as a matrix: inports as rows and outports as columns, each grouped by category, such as Video or Vision Mixer, and colored by it. A filled dot marks each crosspoint routed now. When a take moves a route, the new crosspoint blinks and the one it replaced fades out. Where an inport and an outport of different categories meet, the crosspoint is dimmed. The widget only shows the routing: nothing in it takes a route. It needs Viz Mosart 5.19 or later, the first version whose Media Router has the SignalR service the widget connects to.
Above the matrix, the router's name carries a beacon: green while the router is active, orange while it is idle (a slave, which takes no routing commands), and gray while it is not answering. Hovering the name reports the router's address and, once it answers, its version. Hovering a port name reports its device and whether that device is connected, its category and its status, among other details. Hovering a routed crosspoint names its inport and outport, and a requested one adds Pending: not confirmed by the client yet.
Its settings, in the Media Router Matrix group:
Media Router address: the address of the Media Router's SignalR service, its host and the HTTP port set in MediaRouterServiceConfig.xml, 55171 unless set otherwise, such as
http://mmr-host:55171. For anhttps://address, use the HTTPS port set in the same file instead. Include the port. If you leave out the scheme, the address is taken ashttp://. An entry that is not a web address is flagged when you leave the field: Not a web address. Enter one such as http://mmr-host:55171. On a panel served over HTTPS, anhttp://address is flagged too: This page uses HTTPS, so the browser blocks an http address. Use the router's https address.Pending: SHOW or HIDE. Shown, a crosspoint requested and not yet confirmed by the client device is drawn as an outline. Shown by default.
Unused ports: SHOW or HIDE. Hidden, the matrix keeps only the inports and outports routed now, and those of the latest change, both the new and the previous one, so a sparse matrix stays small. When no port is left to show, the widget says Nothing is routed. Shown by default.
Problems show as a message on the panel, once for each router rather than at every retry:
Set the Media Router address in the widget options.: the address is empty.
The Media Router address is not a web address.: correct the address in the widget options.
This page uses HTTPS, so the browser blocks the Media Router at <host>, which uses HTTP. Turn on HTTPS in the Media Router's SignalR service and use its https address.
Cannot reach the Media Router at <host>. Retrying… or Lost the Media Router at <host>. Reconnecting…: the widget keeps trying, and the matrix it last had stays on screen, dimmed, until the router answers again.
The Media Router <name> is idle (slave): it takes no routing commands.
The Media Router <name> has no ports to show.
In the editor the matrix shows live data but is inert, so clicks select the widget. The messages about the address do not appear there: an entry that is not a web address, or an http:// address on a panel served over HTTPS, is flagged under the Media Router address field instead, and an empty address shows no message at all.
Info: None of the preset panels uses this variant, because it needs your site's Media Router address.
Web page
URL: the address to embed, an
http://orhttps://address. If you leave out the scheme, an address such asexample.com/newsis taken ashttps://. This works when the host has a dot or is localhost. A one-word host, such asgrafana:3000, needs itshttp://orhttps://typed. The frame is loaded directly. An entry that is not a web address is flagged when you leave the field.Interaction: Add interaction makes the whole frame act as a button, with the same options a Button offers under On press. Without an interaction, clicks pass through to the embedded site.
Note: The embedded site decides whether it may be framed. If it sends X-Frame-Options: DENY or a restrictive Content-Security-Policy: frame-ancestors, the frame stays blank and Smart Panel cannot override it. The editor checks this and warns under URL that the site does not allow other pages to show it.
Fader
An audio fader bound to a Viz Mosart audio channel. The operator drags the bar to change the level on air. It renders as a vertical bar with the channel name at the top, the current level in dB below the name, and the track and its scale beneath them, showing -∞ at the floor.
Use it for any source that needs continuous control: a presenter microphone, a music bed, a remote feed. The Channel drop-down is populated from the audio channels Viz Mosart is currently reporting, so name each fader after its source (INPUT 1, INPUT 2 and so on) and operators can tell at a glance which channel they are riding.
Note: The channel list only exists while Viz Mosart is reachable. With the connection down the drop-down is empty, so faders can only be bound while Viz Mosart is connected.
Button
The main interactive item. Its Button group holds Variant, Single state or Two-state, and the Label drawn on it. A new button does nothing until you click Add interaction in its Interaction group. Under On press the button then picks what it talks to, its Source, and then what it sends. The bin button in the Interaction title removes the interaction, and the message that follows offers Undo.
Choosing the source
Source | What you can send |
Mosart | A template take, a timeline command, a control command, Prompter play/pause, or one of the panel's own page and section commands. See below. |
TriCaster | A TriCaster macro, chosen by folder and then by name. |
MSE | Take a graphic. Pick the Media Sequencer profile, whether the graphic comes from a playlist or a show, and then the element itself. |
Viz Arc | A Viz Arc action, chosen by project and then by action. |
The TriCaster, MSE and Viz Arc sources need their integration configured first. See Setup and Administration of Smart Panel.
Viz Mosart commands
With Mosart as the Source, the Command is one of:
Template: takes a Viz Mosart template. Choose the Bus, Program to take on air or Preview to cue, then pick the Template from a picker that lists the whole template catalogue by category and lets you search it.
Timeline: one of ten timeline actions, namely Toggle Rehearsal Mode, Open Rundown, Reload, Start Continue, Skip Next, Unskip Next, Skip Next Sub Item, Unskip Next Sub Item, Start From Top, and Take Server Out Of Idle. Open Rundown can point at a specific rundown, or leave the choice to the operator at runtime.
Control Command: the full Viz Mosart control command set, from autotake and direct take through overlay graphics, audio, crosspoints and studio setup. Commands that need arguments take them in the parameters field, in URL query form (
param1=value1¶m2=value2). For exampleengine_switcherneeds an engine name. Leave it blank for commands that take none.Prompter Play/Pause: starts and stops prompter scrolling.
Switch section variant: changes which variant a section shows, without sending anything to Viz Mosart. Pick the Section, then the Variant: Next variant or Previous variant, which wrap round, or one of its variants by name. It is offered once the page has a section, and a button inside a section switches its own section unless you pick another. A button that sits in only one variant of the section it switches hides itself when it switches away, and the editor says so: put a way back in every variant, or keep the button on the page beside the section.
Navigate to page: switches the panel to another page, without sending anything to Viz Mosart. Go to offers Next page, Previous page or one of the pages by name. It is offered once the panel has more than one page. If the page a button goes to is deleted, the button names it Deleted page, and a press says the page no longer exists until you point it at another one.
Test, in the title of On press, sends the configured command straight from the editor, so you can confirm a binding without leaving it.
Note: Test sends the real command to the connected Viz Mosart server. Do not use it during a live show unless you mean to. Control command parameters are also passed through as typed: a typo fails silently from the operator's point of view, so check the Viz Mosart server log if a button appears to do nothing.
Two-state buttons
A button can carry a second action. Set Variant to Two-state: Label becomes State 1 label, State 2 label is added, shown while the button is armed for its second action, and the Interaction group splits into On first press and On second press, each with its own Test. The first tap sends the first action, the next tap sends the second, and the button then resets to the first state. Both halves take the full range of targets and commands, so one cell can hold a take and its matching take out.
If you leave State 2 label empty, the button keeps its ordinary label in both states, so give it a second label whenever the operator needs to see which action the next tap will send.
Switching sections as well
Besides its action, a button can switch one or more sections, on its own page or on another, so that one press both sends a command and shows the controls that go with it. Under the action, And switch a section adds an And switch row, where you pick the Section and the Variant it should show: Next variant, Previous variant or one of its variants by name. A button can switch up to 10 sections, and each row has a button that removes it. A section the button's own Switch section variant command already switches is not offered. A button can also switch sections without any action of its own. On a two-state button each press has its own rows.
The sections switch only once the action has gone through, or straight away when there is no action, so the panel never shows a state that did not happen: if the command fails, nothing switches. A button whose command lets the operator choose the rundown when the button is pressed only opens the rundown picker: its sections do not switch, not even after a rundown is picked. A two-state button likewise moves on to its other state only when the press went through. As with Switch section variant, a row that switches the button's own section away from the only variant the button is in hides the button, and the editor says so. If a section a row points at is deleted, the row shows Deleted section, and a press says that a section it switches no longer exists.
A running panel does not confirm the switch, because the operator sees the sections change. When you test the button in the editor, a message says which sections it switched and what they now show. If it switches more than three, the message counts the sections instead of naming them, and names what they show only when they all show the same variant.
Appearance
Buttons carry the full color and font controls, so use color and a short, unambiguous label (TAKE, CUE, CAM 1) to make the purpose obvious at a glance.
Note: A button fires as soon as it is tapped. Smart Panel does not ask the operator to confirm a button press, so for an action that must not go to air by accident, rely on placement, size and colour, and keep it away from the buttons an operator reaches for under pressure. A two-state button is not a safety guard either: its first tap fires immediately.
Rehearsal
A control with two states that reflects the current state in Viz Mosart as well as changing it, so the operator can see at a glance which way it is set and does not have to look elsewhere to confirm it. That reading back of the state is what separates it from a Button: a plain Button can also have two states, but it never shows you what Viz Mosart currently thinks.
The state it flips is Viz Mosart's rehearsal mode. Placed on a panel, it lights up while Viz Mosart is in rehearsal and switches it when tapped. Its Rehearsal group holds only the Label drawn on it, Rehearsal unless you type another.
Info: If you want a one-way action instead, or another state, use a Button. Toggle Rehearsal Mode is also available as a plain timeline command on a Button, which flips rehearsal without showing its state.
Live
Embeds a live video preview on the panel. Use it for camera and source previews, and any other picture the operator needs to glance at. A common arrangement is a Live preview paired with its own take button, both labelled with the same source name so the link between what you see and what you cut to is obvious.
Source type offers four choices:
Source type | What to select |
NDI | An NDI source, picked from the sources Mosart Web Apps has discovered on the network. The server receives the NDI stream and passes it to the browser, so nothing needs installing on the operator's machine. |
TriCaster | A TriCaster input or output, from the TriCaster configured in the Configuration Tool. |
HTML Video | A video URL the browser can play directly, such as an |
Stream | A |
Each source type remembers its own URL, so switching between them while experimenting does not lose what you entered for the others.
Add interaction, in the Interaction group, turns the preview into a button as well: the same options a Button offers appear under On press, so tapping the picture can take that source. Without an interaction, a press on the preview does nothing.
Info: If a source cannot be reached, the picker says which part failed rather than simply showing an empty list. The messages and their remedies are listed under Setup and Administration of Smart Panel. Earlier releases required a separate Viz Coder service for NDI; that is no longer used.
Section
A section is an area of the page that holds several sets of components, its variants, and shows one of them at a time. Buttons on the panel switch which variant it shows, so one area of the screen can serve several purposes in turn.
A new section covers 8 by 6 cells and has a grid of its own of the same size, so its cells line up with the page's until you change either. It starts with one variant, Variant 1. Sections are named Section 1, Section 2 and so on, in reading order on their page, unless you give one a name of its own.
Putting components in a section. Drop a component from the palette onto the section, or drag a component on the page into it: it goes into the variant the section shows in the editor. Drag it out past the section's edge to put it back on the page. Hold Ctrl (Cmd on a Mac) while dragging to keep a component on the grid it is on: a page component can then sit on top of a section, and a component in a section snaps back inside it. The component's actions menu and its row menu in the Layers list also offer Move into a section and Move out of section. A section always sits on the page, never inside another section.
A section's own properties are:
Fill: its background color, which can also be transparent.
Variants: the list of variants, each with the number of components in it. The selected variant is the one the canvas shows and you edit. The + button adds a variant, up to 50. Double-click a variant, press F2 on it or use its rename button to rename it, and its delete button to delete it. Deleting a variant that holds components, or that a button switches to, asks first. The last variant cannot be deleted.
Section grid: the section's own Rows and Columns, and Default component padding for the components inside it, which follows the panel's default until you set it.
In the editor a section draws its grid and, once it has more than one variant, names the variant it shows. Deleting a section that holds components, or that a button switches, asks first. A running panel opens every section on its first variant, and the panel's buttons switch it from there; see Switch section variant under Viz Mosart commands. The editor's Preview runs the panel, so its buttons switch sections there too, and back in Edit each section shows the variant it showed before.
To check a panel while you are still designing it, switch the app bar from Edit to Preview, or use the play button in the app bar to open it in display mode in a new tab.
To run it for real, open it in display mode: choose Display mode on the panel's card, use Copy Link and open that link on the operator's screen, or navigate to /smartpanel/<panel> without /edit. The panel fills the window, touch-friendly and ready for use, and cannot be edited there. For a completely bare screen, use the browser's own full-screen mode.
On air:
Timers, labels and indicators update live from Viz Mosart.
A panel with several pages opens on its first page. The page buttons, and any button with the Navigate to page command, switch page.
Buttons send their command as soon as they are tapped. A two-state button sends its second action on the next tap, then resets. A button that also switches sections switches them once its command has gone through.
Faders apply level changes as they are dragged, but only while the Viz Mosart audio mixer is connected. Otherwise the fader is dimmed and its handle will not move, and tapping the handle reports why: the audio mixer is not configured on the Mosart Server, is in standby, or is not connected.
Display mode has no app bar, so there is no Offline chip there. Instead the Ready check says on the panel itself when the connection drops or Viz Mosart cannot act, unless it is turned off; see Ready check below. A Status component set to Connection also shows the server state on the panel.
Where authentication is enabled, a panel holds its sign-in for as long as its page is open, so running a panel on air does not put a sign-in dialog over the controls: the session does not expire under the operator. An administrator can choose to let Smart Panel time out when idle instead, in which case a warning appears before it does; see Setup and Administration of Smart Panel.
Ready check
A running panel checks whether its components will work and says so in plain words, so whoever stands at the panel knows before a press fails. How much it shows is set in the Ready check group of the Panel tab, under Visualize:
Off: nothing is shown. Use it for clocks and monitors that are in shot.
Strip only: a status strip while something is wrong. The default for a panel with no components that send Viz Mosart commands.
Strip and sheet: the strip, plus a Ready sheet before the show that can get Viz Mosart ready where you allow it. The default for a panel with components that send Viz Mosart commands. A panel with no such components shows the strip only.
A panel follows these defaults until you change something in the Ready check group, and only what you change is saved. So a panel with components that send Viz Mosart commands, where nothing has been changed, shows the strip and the sheet with every action of the sheet switched on. This includes panels made in an earlier version. To keep a panel quieter, choose Strip only or Off, or switch off the actions it should not offer.
The status strip runs along the top of the panel and names the problem and what it affects, for example No connection, Can't reach Mosart, Mosart is not running, Mosart is idle or No rundown loaded. It never takes a tap: a press always reaches the component under it. While the show runs, the strip gives way to a small badge in a corner the components leave free. If every corner is taken, it goes where it covers the least. While Viz Mosart cannot act on them, components that send it commands are dimmed and carry a mark, and a press still sends. A time that stops updating gets a Not updating mark, and after a few more seconds shows placeholders.
The Ready sheet covers the panel only before the show, while nothing is on air, and closes when the show starts. It offers what you allow in the Ready check group. With Strip and sheet, on a panel with components that send Viz Mosart commands, all three switches are on by default:
Panel can make Mosart active: a Mosart is idle card with Hold to make Mosart active. Going active sets up every studio device and can take graphics off air, and with a rundown loaded Viz Mosart also cuts to its first item. It is not offered with a main and backup server. On a Strip only panel the same hold is reached by tapping the beacon of a Status component set to Connection on the panel. With Strip only this switch starts off, so turn it on to offer the hold there.
Panel can load a rundown: a No rundown loaded card with Choose a rundown, which lists the rundowns Viz Mosart offers (with a filter when there are more than 12), and loads the one chosen with Load. Viz Mosart checks the load, and it never replaces a loaded rundown.
Quick Show template and Panel can start without a rundown: with a template picked and the switch on, the card also offers Start without a rundown, which goes on air with that template after Hold to go on air. With a template picked and no rundown loaded, a button with the Start Continue timeline command asks Go on air now? in the same way, and starts nothing if the template is not in Viz Mosart's template set. The Quick Show template field shows only while Panel can start without a rundown is on or the panel has a button with the Start Continue timeline command. Until a template is picked, the sheet does not offer Start without a rundown.
Not now or Show my panel puts the sheet away, and the strip's Get ready button brings it back. Actions that go on air or affect the whole gallery take a one-second hold, and the sheet's buttons ignore taps for a moment after it appears, so a finger already on its way to the panel does not press them. An action counts as done when Viz Mosart reports it, not when it is sent.
The rundown and Quick Show settings need a Viz Mosart server that reports its rundown and can start a chosen template. The Panel tab says when the connected server cannot, and asks you to connect to Viz Mosart before you change them. While a setting cannot apply, its switch shows off, and the note under it says when the setting is on.
Streaming a panel as an NDI source
A finished panel can also be sent out as an NDI source, so it can be taken as a picture on a video device or mixer rather than only viewed in a browser. Start and stop this with NDI Stream in the app bar.
A stream stays on until you turn it off. If the Mosart Web Apps server restarts, or the machine it runs on reboots, the streams that were on start again by themselves once the server is back. Deleting a panel turns its stream off.
What to avoid while live
Editing the panel an operator is currently using. Saves take effect on their next page load, unsaved editor changes are not reflected on their screen, and a misclick in the editor can fire a real command.
Renaming or deleting a panel that is in use.
Touch operation
Use an aspect ratio that matches the touch monitor. A mismatch leaves dead bands at the edges that operators tap by accident.
Avoid tiny items. A button smaller than a fingertip is unreliable under pressure.
Keep clear contrast between active and idle states so the operator can see which action just fired.
Keyboard Shortcuts
Press K to see this list in the app.
Action | Shortcut |
Move between panels | Arrow keys |
First or last panel | Home / End |
Move the selected item | Arrow keys |
Resize the selected item | Shift + arrow keys |
Duplicate while dragging | Alt (Option on a Mac), held when you let go |
Delete the selected item | Delete or Backspace |
Copy item | Ctrl+C (Cmd+C on a Mac) |
Paste item | Ctrl+V (Cmd+V on a Mac) |
Drag without entering or leaving a section | Ctrl (Cmd on a Mac), held while dragging |
Cancel placement or a drag | Escape |
Graphics Playlist: move between graphics | Up / Down arrow |
Graphics Playlist: previous or next story | Page Up / Page Down |
Graphics Playlist: send to preview | Space |
Graphics Playlist: take in | Enter |
Graphics Playlist: continue a graphic on air | Enter |
Graphics Playlist: take the graphic out | Delete or Backspace |
Graphics Playlist: take the last graphic out | Home |
Graphics Playlist: take all graphics out | Ctrl+X |
Show keyboard shortcuts | K |
