Mosart Web Applications are value-adding utilities and plugins that simplify working with Viz Mosart. They are not part of a standard Viz Mosart delivery.
Prerequisites
  • A running Viz Mosart system. Individual web apps depend on the Viz Mosart server supporting them, so for the Viz Mosart version required by your Mosart Web Apps release, see the Mosart Web Apps Release Notes at the Vizrt Documentation Center.
  • To use Showmaker, you must have Viz Mosart 5.14.3 or later.
Getting Started
  1. Collect the latest software bundle from Vizrt's customer download site at https://download.vizrt.com/
    by navigating to /products/VizMosart/Latest Version/WebApplications/.
Note: If upgrading, make sure an existing instance of the Mosart Web Applications Configuration Tool is not open.
  1. Run the downloaded file MosartWebApplications.Bundle-n.n.n.n.exe.
    The Web Applications that will be installed are listed.
Info: The Installer places these services and applications on the target machine:
  1. Mosart Web Applications: A Windows service that serves the Mosart Web Applications.
  2. Mosart Web Proxy: Caddy2 bundled within the Mosart Web Apps installer, running as a Windows service.
  3. Mosart Web Applications Configuration Tool: A desktop web application for configuring and launching the web applications.
  4. The set of Mosart Web Applications listed on the Installer.
  1. Click Install.
    Any previously installed version of the Mosart Web Applications is automatically upgraded. All configurations and preferences are retained and you complete the installation by clicking Finish.
  2. After successful installation, the Mosart Web Applications Configuration Tool displays, together with a desktop shortcut for quick access.
  3. From the navigation sidebar on the left, select one of the following:
Sidebar entry
What it is for
Home
The landing page, which is also the app launcher: one card per installed web app. On a multi-studio site the cards are grouped, those that open against the selected studio under Apps for that studio, and the rest under Cross-studio. A single-studio installation shows one flat list.
App Configuration
Per-app settings on five tabs: NRCS Plugin, Showmaker, Template Editor, Named Overlays Editor and Smart Panel.
Server Configuration
The Mosart server addresses, proxy, HTTPS, authentication and the shared integrations. HTTPS and sign-in are documented separately, under HTTPS and Certificates and Authentication.
Studios
Definitions of the studios on a multi-studio site.
Help & Resources
The User Guide, Release Notes, API Docs, the Stream Deck plugin and the Mosart Server settings editor.
Quick setup
Re-enters the guided first-run wizard, at the bottom of the sidebar.
  • If your system is already configured, open Home and launch any of:
    Showmaker
    NRCS Plugin
    Rundown Viewer
    Smart Panel
    Prompter
    Template Editor (Early Access). Every installed app has a card. An app that ships switched off shows an ENABLE button instead of launching, and its card is moved to the front of the list; the Template Editor is the one that does, and its ENABLE button takes you to the Template Editor tab of App Configuration.
  • If this is your first running of the Configuration Tool, or you will start using a new Web App, you must make some one-time configurations,
    as described in section Configuration Tool. The quickest route on a fresh installation is the Quick setup wizard, which opens on first run.
Note: The Timing Display web app was removed in Mosart Web Apps 3.1. Its capabilities are provided by Smart Panel. See Timing Display for the migration notes.
User Guides
Each web app's own section of this guide is listed in the navigation on the left. Inside the Configuration Tool, Help & Resources opens the copy of this guide that shipped with your installation, together with the release notes for that version.
Tip: The onboard descriptions are often early drafts. For latest documentation, visit the online resources at the Viz Mosart Documentation Center.
Related Documents
For more information about all of the Vizrt products, visit:
Feedback and Suggestions
Copyright © 2026 Vizrt. All rights reserved.
Disclaimer
Vizrt provides this publication "as is" without warranty of any kind, either expressed or implied. This publication may contain technical inaccuracies or typographical errors. While every precaution has been taken in the preparation of this document to ensure that it contains accurate and up-to-date information, the publisher and author assume no responsibility for errors or omissions. Nor is any liability assumed for damages resulting from the use of the information contained in this document.
Vizrt's policy is one of continual development, so the content of this document is periodically subject to be modified without notice. These changes will be incorporated in new editions of the publication. Vizrt may make improvements and/or changes in the product(s) and/or the program(s) described in this publication at any time. Vizrt may have patents or pending patent applications covering subject matters in this document. The furnishing of this document does not give you any license to these patents.
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
