Setting up the Timing Display
Prerequisites
Viz Mosart 5.0.3 or later.
Perform the installation as described in Getting Started.
Configuration
Timing Display will work out-of-the-box if the Mosart Web Apps are installed on the same machine as the Viz Mosart server.
It is recommended to visit the Server Configuration page to verify proxy server connections and other security aspects.
Optional Server Setups
Support for Main/Backup Connection
If you have a backup server for redundancy, you will need define the environment in the menu Server Configuration.
Support for HTTPS
If you are using HTTPS, you will need define the environment in the menu Server Configuration.
Troubleshooting
Please see section Troubleshooting.
