Setting up the Rundown Viewer
Prerequisites
Viz Mosart 5.1.0 or later
Installation and Configuration
The Rundown Viewer requires no additional configuration.
Ensure that your Viz Mosart system is operating under normal working conditions.
As a minimum,Manus Admin must be running.
The Viz Mosart UI is running, displaying a rundown.
From the Mosart Web Apps Configuration Tool, select App Launcher > Rundown Viewer.
Optional Server Setups
Support for Main/Backup Connection
If you have a backup server for redundancy, you will need define the environment in the menu section Server Configuration.
Support for HTTPS
If you are using HTTPS, you will need define the environment in the menu Server Configuration.
Troubleshooting
Please refer to section Troubleshooting.
