Setting up the Rundown Viewer
Prerequisites
  • Viz Mosart 5.1.0 or later
Installation and Configuration
The Rundown Viewer requires no additional configuration.
  1. Ensure that your Viz Mosart system is operating under normal working conditions.
    As a minimum,
    1. Manus Admin must be running.
    2. The Viz Mosart UI is running, displaying a rundown.
  2. From the Mosart Web Apps Configuration Tool, select App Launcher > Rundown Viewer.
Optional Server Setups
Support for Main/Backup Connection
  • If you have a backup server for redundancy, you will need define the environment in the menu section Server Configuration.
Support for HTTPS
Troubleshooting
Please refer to section Troubleshooting.
