Release Date: 2025-02-28
We’re thrilled to announce the launch of Web Applications 2.2, packed with exciting new features, polished designs and productivity-enhancing improvements. This release continues to refine your experience, with notable updates to Showmaker.
We value your insights and encourage you to share your feedback, feature requests or comments, to help us continue to innovate.
Showmaker
Showmaker is revolutionizing how you can create rundowns for Viz Mosart. Although still in “early access” mode, it’s now closer than ever to being production-ready. Here's what’s new:
Ready to air
Set a rundown ready to air, to push it into Viz Mosart.
On air status
You now see exactly what Viz Mosart has on air, from Showmaker. This opens the possibility of Showmaker now being part of your operational interface.
Copy/paste/duplicate
Stories and story items can now be duplicated, copied and pasted, even between rundowns.
Story List design
A new-look Story List includes auto-numbering and a flag indicating manual items.
Planned duration comparison
A total duration progress bar compares planned duration of the rundown to the combined duration of all stories, to help with show planning.
NRCS Plugin
Clip search
The NRCS Plugin can now connect to the active Viz Mosart server and search for clips on the connected video servers.
Note: Requires Viz Mosart 5.11 or later.
Improved Gallery/Template set selection
A redesigned Gallery/Template set selector now displays long template set names.
Support for OpenMedia
The OpenMedia NRCS is now supported by the NRCS Plugin.
Rundown Viewer
Manual items
You can now see manual items in the Story Script section of the Rundown Viewer.
Ad-lib colors
We now correctly represent the colors of the different types of Adlib templates.
Mosart REST API
Mosart Web Applications can now be used as a proxy to call the Mosart REST API on the current active server.
API Documentation
With Web Apps running, you can browse the API documentation at
http://[web-apps-machine:port]/mosart/swagger .
Bug Fixes
Installation and Upgrade Process
Installation: To download this version, please visit the Vizrt FTP site at download.vizrt.com and navigate to / products/VizMosart/Latest Version/WebApplications/.
Upgrade: The installer manages the upgrade, automatically removing older versions of Vizrt Mosart Web Applications and Vizrt Mosart Web Applications Configuration Tool before installing the new package.
Remember to close any running version of the Vizrt Mosart Web Applications Configuration Tool before upgrading.
System Requirements & Documentation
Ensure compatibility with Windows 10, Windows Server 2022, and latest Chrome/Edge for a seamless experience across all Web Applications.
NRCS Plugin: Works with any version of Viz Mosart.
NRCS Plugin with Viz Pilot Edge requires Viz Pilot Edge 3.1 or later.Timing Display: Viz Mosart 5.0.3 or later.
Rundown Viewer: Viz Mosart 5.1.0 or later.
Showmaker: Viz Mosart 5.7.0 (MOS 4.0 support introduced) or later.
User guides are accessible within each application. Latest insights and instructions are continually updated to the Vizrt Documentation Center.
Support
