Viz Mosart Media Router Guide
Version 5.7 | Published May 03, 2024 ©
Media Router Installation and Configuration
Installation
You install a Media Router from the Viz Mosart installer identified as
VizMosartMediaRouter-<version number>.msi
Configuration
MMR Configuration is performed in two xml-based configuration files:
Media Router service configuration
in MediaRouterServiceConfig.xml -
Media Router Database Configuration
in MediaRouterDB.xmlNote: The name of MediaRouterDB.xml is configurable within the Media Router service configuration.
Normally both files are placed at:
%ProgramData%\Mosart Medialab\ConfigurationFiles
Older systems use a legacy location
C:\ChannelTemplates
