Viz Mosart Media Router Guide
Version 5.5 | Published February 04, 2024 ©
Media Router Naming Convention for Components
When contacting support there is a standard naming convention for the following applications and components that form Viz Mosart:
Short Name |
Long Name |
Description |
AVA |
AV Automation |
Application controlling attached broadcast equipment. |
Client (output) |
A client in this context denotes a service which are given access to one or more sources via the Media Router. In router terminology a client defines an output of a router matrix. |
CurrentSalvo |
Internal Media Router state containing validated crosspoints. |
GUI |
Viz Mosart GUI |
Main user control application. |
Manus Admin |
Manus Administrator |
Application controlling the Viz Mosart rundown. |
Media Admin |
Media Administrator |
Application for monitoring media objects (clips). |
OGI |
Overlay Graphics Interface |
Application that controls Overlay graphics systems. |
PendingSalvo |
Internal Media Router state containing all pending crosspoints (corresponding configuration changes to be validated by Mosart servers). |
Source (input) |
A dedicated media content provider to be controlled. Examples of sources in this context are video play-out server ports and graphics controllers. In router terminology a source defines an input of a router matrix |
MMR |
Mosart Media Router |
Previously known as Mosart Media Router or MMR. Application that shares broadcast devices between control rooms. |
MMT |
Media Router Test Application |
NCS, NRCS |
Newsroom Computer System |
Salvo |
A predefined list of crosspoint operations which when executed all occur simultaneously. |
