The Overlay Graphics interface provides control and monitoring of overlay graphics for all Viz Mosart-approved graphic engines.
Start Mosart Graphics Interface by double-clicking the application icon:
 or by navigating to the installation directory (by default C:\Program Files (x86)\Mosart Medialab\Mosart Server) executable MMOverLayGraphicsInterface.exe.
The Overlay Graphics Interface (and application icon) is only available if Overlay Graphics was selected when installing the Viz Mosart Server.
The Overlay Graphics interface is only used for overlay graphics. Full-frame graphics are controlled through the AV Automation application.
menu bar at the top offers Settings, Graphics profileTools and Standby.
The Overlay Graphics interface consists of four main areas ([1] to [4] in the illustration).
A status bar at the foot of the UI provides information on product version number and the total number of graphics in Viz Mosart (rundown overlays + named overlays + button overlays. 7 in the example above).
The main column labels are:
  • Time: The time when the graphic was added in Overlay Graphics (usually at rundown import).
  • #U: The number of times this graphic has been updated.
  • #T: The number of times this graphic has been taken.
  • Type: The graphic type. Can be:
Type
Description
A
Auto Out (a Manual CG can also be Auto Out)
B
Background End
S
Story End
M
Manual (Open End)
L
Last Out
Stay Always
if template is STORYSTART
None of the above
Note: Locator is a special graphics item that is linked to a video server crosspoint. When taking the crosspoint from a Viz Mosart template, either as a switcher crosspoint or keyed crosspoint (in a DVE box), the graphics are also (re-)taken.
[1b] Details of a Selected Graphic from the List of Overlay Graphics
Selecting an overlay graphic from the list displays further details
Explanation of Details
Element
Description
Graphic title
Handler name (the destination or the channel for this graphic)
Graphic description
Graphic ID
This is the Viz Mosart Graphic ID, not the graphic ID from graphic database (Graphic Hub/Oracle)
Action Buttons
Take: Takes graphic on air
Take out: Takes graphic off air
Clear: Takes out all taken graphics
Info: Opens an editor window where the graphic MOS item can be changed and updated
[2] Server Status
[3] General Log
The center right contains a log of all actions performed on the overlay graphics either triggered by Viz Mosart or by clicking Overlay Graphics buttons.
To clear this area, double-click inside it.
[4] Event Log
System Information
Menu Bar
Settings
Properties: Opens Overlay Graphics Configuration.
Graphics Profile: Select the required graphics profile.
See Graphics Profiles Tab.
Tools
Editor: Opens a Test graphics window.
Instrumentation Panel: Displays all device commands in real time, as sent to the various connected devices.
See Mosart Instrumentation Panel.
Standby: Toggles the graphics engines in or out of standby.
Take any controller into standby. All the engines linked to the controller are set /unset to standby. The same action can also be performed from the Viz Mosart UI.
Take any engine individually into standby (only in OGI) while the other engines in the same controller are active.
See the respective sections:
