Version 5.4 | Published July 22, 2024 ©
sq_sequence
The sq_sequence table contains recorded sequences from a Viz Mosart Automation. Sequences are gallery dependent and related to the template set in use when recorded. A sequence makes it possible to record any sequence from a rundown in Viz Mosart automation for later playback.
         Name  |
         Type  |
         Allow Null  |
         Description  |
         sq_recno  |
         integer  |
         No  |
         Primary key.  |
         sq_ga_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table.  |
         sq_ts_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding template set ts_recno in the ts_templateset table.  |
         sq_name  |
         varchar(32)  |
         No  |
         Name of sequence.  |
         sq_description  |
         varchar(128)  |
         Yes  |
         Optional description of the sequence.  |
         sq_xml  |
         longtext  |
         No  |
         The gallery specific implementation of the sequence. Stored as received from Mosart Automation in XML.  |
