ti_templateimplementation
The table ti_templateimplementation contains the gallery specific template implementation as created by the Mosart template editor (i.e. this information is gallery dependent).
         Name  |
         Type  |
         Allow Null  |
         Description  |
         ti_recno  |
         integer  |
         No  |
         Primary key.  |
         ti_te_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding template te_recno in the te_template table.  |
         ti_ga_recno  |
         integer  |
         No  |
         Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table.  |
         ti_xml  |
         longtext  |
         Yes  |
         The actual xml-formatted template implementation as created by the Mosart template editor.  |
Information: The template implementation must be created per gallery and is stored using its native XML representation, as received from the Mosart template editor
