A Mosart control command can be triggered from a template, executed when the template is cued (Commands On Cue), taken (Command On Take), at a continue point (Continue Points) or when the template is taken out (Command On Take Out).
Info:
  • A Mosart template can trigger multiple control commands.
  • A (not-templated) control command can trigger a Mosart template, often used for a DirectTake template.
Working with Control Commands
This is done through AV Automation > Devices > Template Editor > Template > Properties > Control Commands tab.
The figure above shows a template with several control commands Executed when the template is cued, when it is taken, and at Continue points while the template is on air.
Control commands can also be executed when the template is taken out. Note that Parameter settings are not available at Take Out. In this context, triggering a Direct Take may be more appropriate.
Adding a Control Command
To add a control command
  1. In the Template properties window, click the Control Commands tab.
    There are four categories of control command:
    1. Commands On Cue
    2. Command On Take
    3. Continue Points
    4. Command On Take Out.
  2. Refer to the table Command Values and Parameters below for details.
Commands On Cue
You can recall control commands in Preview, when the template is cued. This enables triggering of events when a story item is taken to Preview.
As illustrated above, you can give the command a Value and a Parameter. Refer to the Command Values and Parameters below for which values and parameters are applicable for a given command.
Also, in a similar way as Autotake offsets for Continue Points, you can set a frame number value of Offset governing when the command is to be executed.
Info: For Cue commands, all offsets are relative to the start of cueing. This differs from Continue Points, where each offset is relative to the previous continue point.
In the illustration above, the User Message (Ready) will be sent 100 frames after cueing. Commands without offset will be executed immediately On Cue.
By defining a Newsroom tag as a parameter for an On Cue command, you can set the parameter from the NRCS.
For Commands On Cue, this applies to the Parameter column.
Parameters as Newsroom Tags
  • In the Parameter column, right-click (once or twice) and select either Add, Remove or Change the newsroom tag.
Tip: The selection with all parameters appear in the Mosart Web App NRCS Plugin, simplifying the task of adding the template to a rundown.
  • The Parameter field gets a pink background color, indicating that a Newsroom tag is present.
  • Hovering-over the field displays the value of the Newsroom tag.
Command On Take
When selected, the commands inserted in Command On Take are executed when the template is taken to Program or on-air.
You can give the command a value and a parameter.
Refer to Command Values and Parameters below for applicable values and parameters for a given command.
By defining a Newsroom tag as a parameter for an On Take command, the user can set the parameter from the NRCS.
For Command On Take, this applies to the Parameter column.
Tip: This selection then appears in the Mosart Web App NRCS Plugin for adding the template to a rundown.
Continue Points
A Continue point may be executed in one of two ways:
  • The user presses TAKE NEXT (default: F12).
  • If a number is entered in the Autotake column (see below), the Continue point will be executed that many frames after the previous Continue point was executed (or, if this is the first Continue point, from when the template was taken on air).
To enable Continue points
  • To enable this functionality, tick the Continue Points checkbox.
The Continue points are defined in this table:
As illustrated above, you can give the command a Value, Parameter and Description. Refer to section Command Values and Parameters about which values and parameters are applicable for a given command.
Description is helpful for explaining the purpose of this command.
  • Cue Next Item Index: Enter the line number (for example, 0, 1, 2, 3) of the Continue point that executes a cue for the next/following Primary object. If empty, Viz Mosart cues when entering the last continue point in the list. In other words:
    1. if Cue Next Item Index is empty, then Mosart will cue the next item in the rundown after all the continue points have been taken to air.
    2. if Cue Next Item Index is 0, then Mosart will cue the next item immediately after this item has been taken.
    3. if Cue Next Item Index > 0, then Mosart will cue the next item after the continue point with the number specified by the value of Cue Next Item Index field has been taken to air.
  • Autotake (optional): The autotake time, in frames. The command is then automatically taken after that time (unless taken manually earlier by the user pressing TAKE NEXT). If empty, the command must be executed manually by the user pressing TAKE NEXT.
Info: For Continue points, all autotake offsets are relative to the last Continue point (or, for the first Continue point, to the time the template was taken). This differs from Commands on Cue, where each offset is relative to the start of cueing.
The order that the instructions appear in the table is important. Looking at the example above:
  1. The first (Player Status) will be run 50 frames after Take
  2. The next one (status from the NRCS) 110 frames later (160 frames after Take) and
  3. The third 20 frames later (180 frames after Take).
By defining a newsroom tag as a parameter for Autotake, you can set the parameter from the NRCS.
  • In the Autotake column, right-click and select either Add, Remove or Change newsroom tag.
Note also that the Autotake field will get a pink background color to indicate that a Newsroom tag is present. Hovering over the field displays the Newsroom tag value.
Command On Take Out
The commands inserted here are executed when the template is taken from Program, taken off air, or at the end of the template. Only a single command can be used in Command On Take Out, and no parameters are accepted.
You can give the command a Value. Refer to Command Values and Parameters below for applicable values to a given command.
Info: Commands where the Parameter field is marked with (*) do not work for templates.
Note: It is not possible to enter a Parameter in the Command On Take Out section.
COMMAND
Value
Parameter
Description
ACCESSORIES
TAKE_NEXT
AUDIO
FADE_MANUAL
Toggle fade manual.
FADE_OUT_KEEPS
Fader rate
Faders that are set as keep level in the template On Air are faded out. Will also work when new templates have been taken in between the keep action and the FADE_OUT_KEEPS.
FADE_DOWN SECONDARY_AUDIO
Fader rate
Viz Mosart fades down relevant audio sources not connected to the video currently on air.
FADE_UP SECONDARY_AUDIO
Fader rate
Viz Mosart fades up relevant audio sources not connected to the video currently On Air, when cutting between sources.
SET_LEVEL_2_ONAIR
TRUE
FALSE
<empty>
These settings apply to fader second levels in the template that is On Air.
TRUE: The second level for faders are set to ON.
FALSE: The second level for faders are set to OFF.
<empty>: (no value entered) The second level for faders are set to TOGGLE their current state (default).
Info: A blank command parameter is a toggle function, and is therefore not suited for use from a template.
SET_LEVEL_2_PREVIEW
<empty>
This setting applies to fader second levels in the template that is in Preview. The operation will be performed at next transition.
<empty>: (no value entered) The second level for faders in the template in Preview are set to TOGGLE their current state.
FREEZE_AUDIO
TRUE
FALSE
<empty>
TRUE: All sound faders are frozen, and do not respond to commands from templates.
FALSE: All sound faders  respond to commands from templates.
<empty>: (no value entered) All faders are set to TOGGLE their current response state (default).
AUTOTAKE
N/A
AUTOTRANS
PP, ME1, ME2, ME3, ME4
MixEffect (MIX OR WIPE) + Transitionrate
For example: MIX 33, WIPE 10
Info: The Effect cannot be used.
AUX, Default
CROSSOVERCOMMAND
N/A
DEVICE_PROPERTY
CAMERA CONTROL
See Description column to the right.
Info: This is for camera robotics.
When the DEVICE_PROPERTY control command is used with the value CAMERA CONTROL, only
setting speed (Camerobot) and anchor (Camerobot/FxMotion) are controllable from a template.
Details for Camerobot ANCHOR:
ANCHOR=pos1:presenter1[,pos2:presenter2]…
The position and presenter is given as a pair separated with ‘:’.
Multiple position-presenter pairs are possible, separated by ‘,’.
Info: The position is a string and does not have to be a number.
Details for Camerobot Time:
If Time =1 (>0), Viz Mosart sends MATRIX_MOVE_MPOS command to Camerobot,
while if Time = 0 Viz Mosart sends MATRIX_CUT_MPOS command Camerobot.
AUDIO
Requires <fields> structure as parameter with
parameter1=AUDIO,
parameter2=key,
parameter3=value
or
connectionstring style
Info: This is for an audio mixer.
DEVICE_STANDBY
AUDIO_MIXER, GPI, LIGHTS, LOUDNESS, ROUTER, SOUND_PLAYER, SUBTITLING, VIDEO_SERVER, VIDEO_SWITCHER, VIDEO_WALL, VIRTUAL_SET, WEATHER
ON
OFF
TOGGLE
ON: The device chosen (in Value) is put in Standby.
OFF: The device chosen (in Value) is taken out of Standby.
TOGGLE: The Standby status (ON/OFF) of the device chosen (in Value) is toggled.
(If there are several devices of the chosen kind (e.g. video servers), all of them are affected.)
DEVICE_STANDBY
GRAPHICS (full-screen)
As above (ON/OFF/TOGGLE)
or
engineno:[ON|OFF|TOGGLE]
(Example: 2:TOGGLE)
ON/OFF/TOGGLE: As above, applied to all graphics engines.
If an engine number is given, only the designated engine is affected.
DEVICE_STANDBY
ROBOTIC_CAMERA
or
controller:[ON|OFF|TOGGLE]
(Example: 1:ON)
or
controller:camera:[ON|OFF|TOGGLE]
(Example: 1:2:ON)
ON/OFF/TOGGLE: As above, applied to all cameras on all controllers.
If a controller (but no camera) is given, only the cameras on the designated controller are affected.
If both a controller and a camera is given, only the designated camera is affected.
DEVICE_STANDBY
OVERLAY_GRAPHICS
OR
Engine No:[ON|OFF|TOGGLE]
(Example:
2:TOGGLE: Toggles Engine 2 Standby status)
OR
Destination name:[ON|OFF|TOGGLE](Example:
DSK:TOGGLE: Toggles Destination DSK Standby status)
ON/OFF/TOGGLE: Applied to all overlay graphics (all controllers and corresponding engines).
If an engine number or destination name is given, only the designated engine or destination is affected.
If the given number is both engine number of a overlay graphic and the destination name of some overlay graphics, all those overlay graphics are affected.
Info: Engine numbers are shown in the list of active engines in Overlay Graphics Interface and followed by '/' and destination name of  the engine.
(Engine Handler, Destinations, Controller have no effect).
DEVICE_STANDBY
GENERIC_REST
OR
GenericRest No:[ON|OFF|TOGGLE]
For example:
1:TOGGLE: Toggles GenericRest 1 Standby status)
ON/OFF/TOGGLE: Applied to all generic REST devices.
If a generic REST number is given, only the designated generic REST device is affected.
The generic REST number can be found in AV Automation Status panel and Standby list.
DIRECTTAKE
The Recall Nr (see Template Properties) of the direct take template to execute
Executes the direct take template provided in Value.
DVE
FORWARD
REVERSE
Recall forward/reverse EMEM
n/a
ENABLE_GRAPHICS_
MIRRORING
n/a
FULLSCREEN_GRAPHICS
CONTINUE_FULLSCREEN
AUTO
Continue Command Only: The AUTO parameter will replace the continue command with the number of continue points in the graphics item.
The number of continue points is taken from the graphics_continuecount field.
Examples:
AUTO+1: The number of continue counts from the graphics + 1
AUTO-2: The number of continue counts from the graphics - 2
FULLSCREEN_GRAPHICS
CONTINUE_FULLSCREEN
Engine no
The target output fullscreen engine number to execute the action on (for example, 1,2,3).
MACRO
Engine no : macro
The target output fullscreen engine number to execute the action on (for example, 1,2,3) and Macro name.
The engine number must be same as the number defined in AV Automation
GRAPHICSPROFILE
N/A
HOLD_AUDIO_
TRANSITION
N/A
HOLD_VIDEO_
TRANSITION
N/A
ITEM_UPDATE_FIELDS
N/A
Must be a comma separated list in the format:
Bus,Newsroomtag,Crosspoint
Example: Preview,left,CAM1
Update the source (Crosspoint) assigned to a Newsroom tag, for the item in PREVIEW or in PROGRAM.
Bus: Preview or Program
Newsroomtag: Newsroom tag name that will be updated.
Crosspoint: Video crosspoint name in AV Config.
LIGHT
N/A
MARKER
N/A
NCS
START_STATUS,
STOP_STATUS
RUNDOWN
STORY
ITEM
Specific for Open Media
NEXT_CUE_DELAY
EXTEND
A number of frames
If there is a pending cue (when this control command is executed), this cue is postponed by the number of frames given.
Otherwise (no pending cue), the next cue operation will be additionally delayed by the number of frames given. (I.e., the value will be added to the sum of the settings
  • Min. Cue delay in AV Automation Devices Vision Mixer
  • Next cue delay in Audio and Video Setup, Vision Mixer Effects Configurations, Settings (if an effect is involved).
OVERLAY_GRAPHICS
CLEAR
Destination
Current
Render
From where to clear which graphics.
Destination: Non-numerical value.
Current: Clear all overlay graphics currently on air.
Render: Numerical value, the Engine number.
CONTINUE
Destination or graphics ID
The parameter can be either one of the Mosart graphics destinations (channels) or a valid graphics ID.
MACRO
Engine no:macro
or
Destination:macro
The engine number can be identified from the Overlay Graphics Interface (OGI) screen, where device statuses are displayed.
For Vizrt Graphics specifically, the destination configured in OGI can also be used in the command.
Examples:
4:macrotest
DSK:macrotest
When sending a macro command for Vizrt Graphics, Mosart will direct it to the Media Sequencer (MSE), specifying the destination linked to the engine number provided in the command.
In cases where multiple engines are mapped to the same destination (commonly seen in a mirroring setup), the Media Sequencer (MSE) will send the command to all engines associated with that destination, not just to the engine with the number specified in the command.
Info: For Vizrt Graphics, when multiple controllers are defined in OGI, the engine number shown in the OGI screen is not reliable and instead, the destination should be used.
PRETAKE_NEXT_OVERLAY
Destination
Destination (handler) to pretake the next overlay on.
TAKE_LAST_OUT
No function from templates. Can only be used from keyboard shortcut or remote control command.
TAKE_NAMED_OVERLAY
Name/slug of the named overlay to take
TAKE_MANUAL_OUT
Destination or Empty
Destination to take out the manual graphics from.
Non-numerical value: Destination
Empty or Numerical value: Takes out all the manual graphics
Note:
For versions before Viz Mosart 5.5.0, the TAKE MANUAL OUT command would also take out overlay graphics set to wait for background end or story end. If this functionality is needed, use the below TAKE ALL OUT command introduced in Viz Mosart 5.5.0.
TAKE_ALL_OUT
Destination to take out the graphics from.
Empty or Numerical value: Takes out all the graphics
OVERLAY_TO_MANUAL
Parameter 1: ONAIR (default), PREVIEW.
Parameter 2: Comma-separated list of handler names
Parameter 3: AUTOMATIC (default) / MANUAL
Parameter 2 and Parameter 3 must be separated by a semicolon. (E.g. WALL,DSK;MANUAL.)
Info: If there is no semicolon after Parameter 2; nothing to the right of the semicolon; or Parameter 3 has any value other than 'MANUAL', then Parameter 3 gets the default value ‘AUTOMATIC’.
  • For user operations, see the Viz Mosart User Guide, section
    Viz Mosart User Interface > Keyboard Shortcuts > Control Command Keys > OVERLAY_TO_MANUAL.
PLAY_STORY
N/A
RECORD
PREPARE,
START,
STOP
Split parameters using,
- first: clipname,
- second: recorder (optional),
- third: port name (default Rec),
- fourth: group name (default Rec)
For example: clip33,recorder1,Rec,Rec
RELEASE_BACKGROUND
N/A
RESET_OVERUNDER
N/A
Resets the
Rundown Over/Under timer to 00:00.
RUNDOWN_NCS_
RESYNC
N/A
SEQUENCE
LOOP
Sets a running sequence to start looping
STOP_LOOP
Stops running a looped sequence in loop
STOP
Stops a running sequence
START
Restarts a previously stopped sequence
SET_AUX_CROSSPOINT
N/A
SET_CROSSPOINT
AUX
Default
bus/layer:xpoint
Two arguments, separated by a colon [:], are supported.
The first parameter is the Mixer Region’s bus.
The second is the crosspoint, as configured in A/V Setup.
Info:
  • If no colon is used, the value is interpreted as only a crosspoint, and bus A is used.
  • For the TriCaster video switcher, it is possible to specify the layer (A,B,C,D) in addition to the crosspoint, enabling control of the buses for M/E effects with 4 layers.
Examples:
PP CAM1 - Switch source CAM1 in Program
PP A:CAM1 - Same as above
PP B:CAM1 - Switch source CAM1 in Preview
ME1 CAM2 - Switch source CAM2 in Program
ME1 B:CAM2 - Switch source CAM2 in Preview
ME1 1:CAM1 - Switch source CAM1 for keyer 1
ME1 2:CAM2 - Switch source CAM2 for keyer 2
ME1 C:CAM1 (TriCaster) - Switch source CAM1 for the the third layer of M/E effect.
SET_CURRENT_ME
AUX
Default
SET_VIDEOSERVER_
SALVO
Select a configured video server from the list
These same settings are available as keyboard shortcuts, as presented in the Viz Mosart User Guide, under section Viz Mosart User Interface.
STUDIOSETTUP
SWITCH_GRAPHICS_
MIRRORING
TOGGLE,
ACTIVATE,
DE-ACTIVATE
For standard and Story Recorder (SR) shows.
SWITCH_GENLOCK_MODE
TOGGLE,
ACTIVATE,
DE-ACTIVATE
Story Recorder (SR) specific:
As long as some standard show elements are not supported with SR, use this command to control the use of Genlock mode.
SR can only run in Genlock mode.
SWITCH_REHEARSAL_MODE
TOGGLE,
ACTIVATE,
DE-ACTIVATE
SR can only run with Rehearsal mode deactivated, use this command to ensure Rehearsal mode is not accidentally active.
SWITCH_VIDEOSERVER_
MIRRORING
N/A
This command has no parameters, it simply acts as a toggle.
TAKE_CONTINUE_POINT
N/A
TAKE_SERVER_TO_
PROGRAM (as a Continue Points command)
Transition Rate (frames)
Takes a video server port to program. For example: a video clip is running on a video wall. The control command can then be used to take the last used/active video server to program.
The transition will be done over the number of frames given as Value to this command.
TAKE_SERVER_TO_
PROGRAM (as Commands On Cue, Command On Take or Command On Take Out)
N/A
This will be done as a cut, since it is not allowed to define a transition rate for these cases.
TRANSITION_TYPE
CUT,
MIX
Rate
EFFECT
Effect no
TOGGLE
TRIGGER_START
N/A
Plays the cued clip from the taken template that had TRIGGER START enabled in the video server device, see (5.16) Template Device Functions#Video-Server .
UNKNOWN
N/A
Default fallback. Does nothing.
VIDEO_PORT
N/A
command,port,
parameter
For example: PLAY_PAUSE,A,PLAY.
VIDEO_SERVER_GOTO
N/A
VIDEOWALLMODE
N/A
WEATHER
N/A
Parameters with Placeholders
Control command parameters can include placeholders which are then populated with values found among the fields of a currently on air, Viz Mosart item. A placeholder is defined as a string of characters, within curly brackets {placeholder}.
For example, a placeholder can be useful for transmitting values from the NRCS, for use as control commands that will be executed when the template is taken on air.
Example: Providing the clip name to be recorded, from the NRCS.
In the NRCS, a column can be created for giving the name of the clip to be recorded with Viz Mosart. Then, in Viz Mosart Newsroom settings, map the column in Story External Metadata as follows:
<mostag mostagname="NCScolumn" mosart_action="item_variable" action_value="NCS_filename" format_type="String" />
In Manus file, the Mosart item will have the following fields (the value Clip1 is given from the NRCS):
Mosart Item
<fields>
<field name="NCS_filename" value="Clip1" />
</fields>
Then, in Template Editor, the control command for the respective template is configured as follows:
Control Command
RECORD PREPARE {NCS_filename}_Test,Recorder,RecPort
When the template is executed, a clip with name Clip1_Test is prepared for recording.
VIDEO_PORT Control Commands in AV Automation Template Properties
The VIDEO_PORT control commands can also be used in templates. The syntax order of the parameter is important.
Examples
Examples using port A:
PLAY_PAUSE,A,PLAY PLAY_PAUSE,A,PAUSE PLAY_PAUSE,A
STOP,A STOP,A,CUE
RECUE,A,PLAY RECUA,A
SET_LOOP,A SET_LOOP,A,OFF SET_LOOP,A,12-444
CUE_TAIL,A,-15 CUE_TAIL,A,15
PLAY_TAIL,A,-15 PLAY_TAIL,A,15
VIDEO_PORT: Syntax
Value=Command, Parameter=[@Delay,]VideoPort,Properties
VIDEO_PORT: Commands
  • PLAY_PAUSE: Viz Mosart will begin to play the cued content. If the content is already playing, it will pause the content
    • No Properties: PAUSE if playing and PLAY if paused
    • Properties=PLAY: Always try to PLAY channel
    • Properties=PAUSE: Always try to PAUSE channel.
  • STOP: Viz Mosart will stop the cued content
    • Properties: CUE. Cue the channel after the stop.
  • CUE: Viz Mosart will initially CUE the port
    • Properties: ClipName.
  • RECUE: Viz Mosart will RECUE the port
    • Properties: PLAY. Viz Mosart will play the clip after the recue.
  • SET_LOOP: Viz Mosart will set the already cued clip to looping
    • Properties: OFF, RESET. Viz Mosart will turn the looping off
    • Properties: 12-444 (configurable). Viz Mosart will set the looping from frame 12 to frame 444.
  • CUE_TAIL: Viz Mosart will recue the cued clip at a specific time (in seconds)
    • Properties: -15 (negative value) - configurable. Viz Mosart will cue at the start of the last 15 seconds of the clip (the clip will have 15 seconds left to play plus Post roll)
    • Properties: 15 (positive value) - configurable. Viz Mosart will cue 15 seconds into the clip.
  • PLAY_TAIL: Viz Mosart will recue and play the cued clip at a specific time (in seconds)
All commands may be prefixed with an optional delay given in frames. If a delay is specified then the Parameter section shall start with an ‘@’ character.
VIDEO_PORT VideoPort Syntax
The VideoPort may be given either explicitly or by using one of the following identifiers:
  • ONAIR: The current on-air video port used by a primary story item
  • PREVIEW: The current video port in preview from a primary story item
  • VideoPortGroup,CURRENT: The current video port for the given video port group.
VIDEO_PORT Examples:
Value
Parameter / Properties
Description
PLAY_PAUSE
D
Alternatively plays / pauses the clip cued in Mosart port D
PLAY_PAUSE
D,PLAY
Always do a play for the clip cued in port D
PLAY_PAUSE
D,PAUSE
Always do a pause for the clip cued in port D
STOP
D
Stops any running clip in port D
STOP
D,CUE
Stops any running clip in port D followed by a recue
CUE
D,TestClip
Cues the clip TestClip in port D.
CUE
@25,D,TestClip
Cues the clip TestClip in port D after a delay of 25 frames
RECUE
D
Recues the clip in port D
RECUE
D,PLAY
Recues the clip in port D and plays it
RECORD Control Commands in AV Automation Template Properties
The RECORD control commands can also be used in templates.
Examples
Value
Parameter
Description
PREPARE
TestClip,Default,R
Prepare a clip with name TestClip on the Default recorder. The Default recorder will be using video port R.
For Quantel this clip will be initiated using the default duration.
PREPARE
TestClip,Default,R,1500
For Quantel this clip will have an initial duration of 1500 frames = 1 minute (25 frames/sec)
PREPARE
TestClip;Category=Totem ,Default,R,1500
Same as above but the clip will be assigned to the “Totem” category in a Quantel video server system.
Info: There is a semicolon between TestClip and Category.
START
,Default
Starts the recording on the Default recorder.
Info: There is a leading ‘,’ in the Parameter
STOP
,Default
Stops the recording on the Default recorder
The options in the Value dropdown are
  • PREPARE
  • START
  • STOP
  • STOP_AND_DETACH
  • DELETE.
The Parameter should be a comma-separated list of up to four items:
  • ClipName
  • Recorder
  • PortName
  • Duration.
If all four items are present, the Parameter will be
<ClipName>,<Recorder>,<PortName>,<Duration>
RECORD: Syntax
If not all items are present, any commas to the left of present items will still have to be present.
For example, if only Recorder is present, the syntax is:
,<Recorder>
In some cases, the ClipName item may have sub-items. In that case, the sub-items are separated by semicolons. (An example is given below.)
Here the options in the Value dropdown are explained in more detail:
  • PREPARE: Viz Mosart will prepare a clip for recording.
    • Parameter: <ClipName>,<Recorder>,<PortName>,<Duration>
    • ClipName: The name of the clip to be created
    • PortName: The name of the video port where the recording shall take place. Note that this port has to be part of the 'Rec' virtual video port group.
    • Recorder: A user-defined name to be used for the recording, tied to ClipName and PortName. Used by START and STOP.
    • Duration: Estimated duration of the recording in frames.
Info: For the setup of recording ports, please refer to section Working with Mosart Port Configurations. See also Recording in section Viz Mosart User Interface of the Viz Mosart User Guide.
  • START: Viz Mosart will start a recording previously PREPAREd
    • Parameter: ,<Recorder>
    • Recorder: Name of recording session as created by PREPARE
Info: Note the leading comma in ,<Recorder> as explained above.
  • STOP: Viz Mosart will stop a recording previously STARTed.
