The Mosart Remote Control Service (RCS) provides a REST API for controlling Viz Mosart rundowns using REST.
Getting started
To begin using the Mosart REST API
  1. Copy RemoteDispatcherServiceConfig.xml inC:\Program Files (x86)\Mosart Medialab\Mosart Server\ConfigurationFiles
    to
    C:\ProgramData\Mosart Medialab\ConfigurationFiles.
  2. Open the copied file in a text editor.
    1. Locate the <item> element with name="RestApiKey"
    2. Set value an arbitrary string that you choose.
      All API clients must include this key to authorize their requests.
      For example:
      <?xml version="1.0" encoding="UTF-8"?>
      <RemoteServiceConfig>
      <Properties>
      <item name="RestApiKey" value="test-api-key" />
    3. Save the file.
  3. From Windows Services, restart the Mosart Remote Control Service.
  4. Make an HTTP request to http://[machine-name]:55167.
    For example:
    curl -X GET "http://localhost:55167/api/v1/command/reload" -H "accept: */*" -H "X-API-Key: test-api-key"
HTTPS
If you want to enable API access over HTTPS, you must edit the fileRemoteDispatcherServiceConfig.xml, changing the following items:
<Properties>
<item name="SignalRUseHttps" value="true" />
<item name="SignalRCertificatePath" value="C:\cert\server.cer" />
<item name="SignalRCertificateKeyPath" value="C:\cert\server.key" />
<item name="SignalRCertificatePassword" value="password" />
Authentication
Note: When configuring authentication for the Mosart Remote Control REST API, you must also make corresponding authentication configurations for any Mosart Web Apps you are using.
Refer to the topic Configuration Tool > Authentication in the Mosart Web Apps User Guide.
  1. (Prerequisite) Any REST API authentication first requires a configured HTTPS connection, as described above.
  2. Create a new Client/App registration according to your authentication provider guidelines:
    1. Keycloak guide
    2. Keycloak guide for Vizrt SSO
    3. Entra guide
    4. Okta guide.
  3. On the Mosart server, modify the fileRemoteDispatcherServiceConfig.xmlfor the following items:
<item name="UseOidcAuthentication" value="true"/>
<item name="OidcAuthority" value="{{Your Authentication Server}}"/>
<item name="OidcAudience" value="{{Your Audience}}"/>
With the authentication enabled, you now always need to send a JWT token (from the Authentication server), either as a header or a URL parameter in your REST calls, for them to authenticate.
Main/Backup setup
If you want your API calls to go to the currently active Mosart Server, you can route them through Mosart Web Applications.
Install them on a separate machine and configure connection to both main and backup. Then use the endpoint http://[web-apps-machine-name]:65152 and Web Apps will act as a proxy and redirect the call to the active server.
Swagger Documentation
Mosart Server ships with an interactive Documentation page, available after enabling the Mosart REST API.
Explore interactively: Swagger UI (local instance).
Endpoints
Below is a description of the various Endpoints available through this API. They are grouped according to category:
Assets
List Graphics
GET /api/v1/assets/graphics?onair={true|false} (since v5.13.0)
Get a list of all the overlay graphics in a rundown.
The optional onair parameter filters to only graphics currently on air. (since v5.14.0)
Example of the response.
"id": "100_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ba6f770a-1962-47ec-bdbe-54b81b3c25a6_2",
"type": "100",
"variant": "TIMECODE-DSK",
"slug": "Mosart=L|-00:00|00:29",
"storyId": "ba6f770a-1962-47ec-bdbe-54b81b3c25a6",
"status": 0,
"graphicType": "",
"handlerName": "DSK",
"description": "(DSK) - Mosart=L|-00:00|00:29",
"hasContent": true,
"in": 0,
"duration": 29,
"plannedDuration": 29,
"actualDuration": 0,
"fields": [],
"hasTemplate": null,
"emptyTemplate": null,
"templatePlaceHolders": null
"id": "100_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ba6f770a-1962-47ec-bdbe-54b81b3c25a6_5",
"type": "100",
"variant": "MANUAL-DSK",
"slug": "Mosart=L|M|O",
"status": 1,
"graphicType": "MANUAL",
"description": "(DSK) - Mosart=L|M|O",
"hasContent": true,
"in": 0,
"duration": 5,
"plannedDuration": 5,
"fields": [],
Take/Take out Graphics
POST /api/v1/assets/graphics/{mosartItemId}/take (since v5.13.0)
POST /api/v1/assets/graphics/{mosartItemId}/take-out (since v5.13.0)
Take or take out an overlay graphics by its Mosart ID.
mosartItemId: The ID of the overlay graphic you want to take out. id property from /graphics.
POST /api/v1/assets/graphics/take?name={name} (since v5.13.0)
POST /api/v1/assets/graphics/take-out?name={name} (since v5.13.0)
Take or take out an overlay graphics by its name.
name: The slug of the graphic. This is the name visible in the Viz Mosart GUI. slug property from /graphics.
Info: If there are multiple graphics with the same name, only the first one in the rundown will be picked.
Take Story Item from rundown
POST /api/v1/assets/template/{mosartItemId}/take?target={program/preview}insert={true/false} (since v5.14.0)
Take a story item (“filled” template) from a rundown by its ID into which target (Preview or Program). For target Preview, an insert option governs whether the template shall be inserted in front of, or overwrite, an existing manual item.
When an optional parameter is not used, defaults are program (for target) and false for insert.
Devices
Standby Device
PATCH /api/v1/devices/{type} (since v5.13.0)
Sets the standby status of the specified device type.
type: audio, audio-player, fullscreen-graphics, generic-rest, gpi, graphics, lights, loudness, robotic-camera, router, subtitling, switcher, video, video-wall, virtual-set, weather.-graphics, generic-rest, graphics, robotic-camera
Example of the request body
"standby": true
PATCH /api/v1/devices/{type}/{id} (since v5.13.0)
Sets the standby state for a single device/controller identified by one ID.
type: fullscreen-graphics, generic-rest, graphics, robotic-camera
id: The device (or controller) ID. For graphics, this can be the engine ID or the destination.
"standby": true
PATCH /api/v1/devices/{type}/{controllerId}/{deviceId} (since v5.13.0)
Sets standby for a device addressed by controller and device IDs.
type: robotic-camera
controllerId: The controller ID.
deviceId: The device ID.
"standby": true
Media
Search media
GET /api/v1/media/search?name={clip-name} (since v5.11.0)
Searches the video servers configured in Mosart and returns a list of clips.
clip-name: The word you want to search for.
"name": "File name @100%[test]&copy.mxf",
"description": "File name @100%[test]&copy.mxf",
"previewPath": "http://vmp-superdemo:21099/serve/proxy/34c8bc7b-c5a2-4c0f-ad69-50452346cb10.mp4",
"thumbnailPath": "http://vmp-superdemo:21099/serve/thumb/34c8bc7b-c5a2-4c0f-ad69-50452346cb10.jpg"
Settings
Get NRCS settings
GET /api/v1/settings/nrcs (since v5.13.0)
Get the details of how Mosart is configured to connect to the NRCS.
Example of response.
"ncsType": "Mos",
"mosServer": "ws://mosserver/api/v1/showmaker/mos/mymossocketncs",
"mosServerBackup": "",
"ncsId": "SHOWMAKER.MOS",
"ncsIdBackup": "",
"mosId": "MOSART.MOS.SHOWMAKER",
"useBackServer": false,
"mosCommunicationMode": "WebSocket",
"forceMosProtocolVersion": "2.8.4",
"mosLowerPort": 10540,
"mosLowerPortTimeout": 0,
"mosUpperPortTimeout": 0,
"mosHighPortTimeout": 0,
"mosServerTimeout": 0,
"mosServerTimeZone": "",
"mosSchema": "http://www.mosartmedialab.no/schema/mositem.dtd",
"defaultReadyToAir": false,
"templatesToMosObject": [
"Enabled",
"SendAllSets"
"storyScope": "Single",
"mosReplyWithConnectionMosId": false,
"minTimeBetweenStoryUpdate": 1000,
"itemIdGenerator": "",
"ignoreInitialSynchronization": false,
"ignoreSendItemStatusFilter": "",
"newsRoomTagKeepKeywords": [],
"itemStatusUnavailableValues": [
"NOT READY",
" ERROR"
"videoServerGotoDelayOnRetake": 1500,
"ftpServerName": "inews-server",
"ftpServerUserName": "inews-user",
"ftpServerPassword": "inews-password",
"ftpPort": 21,
"ftpUseActiveMode": true,
"ftpActivePortRange": "",
"ftpPreferEncryption": true,
"inewsWorkingDirectory": "SHOW",
"inewsEncoding": "UTF8",
"inewsWebServiceConnectionString": "",
"inewsUseFullStoryLocator": false
Update NRCS settings
PATCH /api/v1/settings/nrcs (since v5.13.0)
Change the NRCS connection in Mosart. Can we used to switch between different NRCS systems. I.e. using Showmaker for certain shows.
If the name of the setting (the key) does not exist -> that setting will be skipped, while the rest will succeed.
If the value is of the wrong type -> 400 Bad Request.
Example of body.
"ncsType": "Mos",
Status
Build
GET /build (since v5.1.0)
GET /api/v1/build (since v5.4.0)
Information about the version of the Mosart Server.
"version": "5.13.0.38555 Beta",
"timestamp": "2025-10-21T07:15:10Z",
"hubVersion": 1
Status
GET /status (since v5.4.0)
GET /api/v1/status (since v5.4.0)
Get the status of the Mosart server.
Example of returned status
"state": "Active",
"timeline": "Running",
"autoTake": false,
"rehearsalMode": false,
"crossoverClient": false,
"serverDescription": "MosartServer"
Timeline
Timeline Information
GET /api/v1/timeline (since v5.13.0)
Get timeline information including timeline status, current story, next story, current item and next item.
"status": "Stopped",
"currentStory": {
"id": "1F52BA57",
"slug": "S1"
"nextStory": {
"id": "1E52BA57",
"slug": "S3"
"currentItem": {
"id": "0_SHOW.TESTSHOW.T-1_1F52BA57_CAMERA20_6",
"slug": "CAMERA 20"
"nextItem": {
"id": "0_SHOW.TESTSHOW.T-1_1E52BA57_CAMERA2_16",
"slug": "CAMERA 2"
Update source item in preview or program
PATCH /api/v1/timeline/{target} (since v5.14.0)
Content-Type: application/json
Updates fields on the current item in preview or in program. Used to change the crosspoint assignment for a newsroom tag field.
Example of body
"newsroomTag": "left",
"crosspoint": "INPUT 1"
Rundown
GET /api/v1/rundown (since v5.13.0)
Get the currently loaded rundown.
"id": "a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0",
"name": "graphics",
"stories": [
"id": "ba6f770a-1962-47ec-bdbe-54b81b3c25a6",
"insertId": "NSID-1",
"storyDuration": 10,
"storyPlannedDuration": 0,
"storyBackTime": -1,
"pageNumber": "",
"slug": "Untitled",
"accessories": [
"type": "100",
"status": 1,
"hasContent": true,
"in": 0,
"duration": 5,
"fields": [
"name": "graphics_description",
"value": "Mosart=L|M|O",
"default": null,
"fieldType": "TEXT",
"keyList": null,
"inputMask": null,
"servers": null
"name": "graphics_id",
"value": "13059",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_dur",
"value": "00:05",
"default": "00:00",
"fieldType": "TIMECODE",
"keyList": null,
"inputMask": "mm:ss",
"servers": null
"name": "continuecount",
"value": "-2",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "payloaduri",
"value": "/dataelements/13059/payload",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "thumbnailuri",
"value": "/dataelements/13059/thumb",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "elementuri",
"value": "/dataelements/13059",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "editoruri",
"value": "/app/pilotedge/pilotedge.html?dataelement=13059&edit=",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"items": [
"subItems": [
"type": "100",
"status": 0,
"graphicType": "",
"hasContent": true,
"in": 0,
"duration": 29,
"fields": [
"value": "Mosart=L|-00:00|00:29",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "23757",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_dur",
"value": "00:29",
"default": "00:00",
"keyList": null,
"servers": null
"value": "0",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23757/payload",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23757/thumb",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23757",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/app/pilotedge/pilotedge.html?dataelement=23757&edit=",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_in",
"value": "00:00",
"default": "00:00",
"keyList": null,
"servers": null
"transition": {
"type": "Mix",
"rateOrIndex": 0
"bodyText": "",
"id": "0_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ba6f770a-1962-47ec-bdbe-54b81b3c25a6_CAMERA1_1",
"type": "0",
"variant": "1",
"slug": "CAMERA 1",
"status": 0,
"graphicType": null,
"handlerName": null,
"description": null,
"hasContent": true,
"in": 0,
"duration": 5,
"fields": [
"name": "xpoint",
"value": "CAM1",
"default": "CAM1",
"fieldType": "LIST",
"keyList": "mixerinputs",
"inputMask": null,
"servers": null
"name": "sr_create_story_clip",
"value": "False",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "sr_publish_story_clip",
"value": "False",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "sr_story_clip_id",
"value": "",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "sr_story_clip_slug",
"value": "",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"hasTemplate": true,
"emptyTemplate": false,
"subItems": [],
"transition": {
"type": "Mix",
"rateOrIndex": 0
"bodyText": "",
"id": "4_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ba6f770a-1962-47ec-bdbe-54b81b3c25a6_Mosart=F_4",
"type": "4",
"variant": "FULL",
"slug": "Mosart=F",
"status": 0,
"handlerName": "FULL",
"hasContent": true,
"in": 5,
"duration": 5,
"fields": [
"name": "scenename",
"value": null,
"default": "",
"keyList": "",
"inputMask": null,
"servers": null
"name": "text",
"value": null,
"default": "",
"keyList": "",
"inputMask": null,
"servers": null
"value": "Mosart=F",
"default": "",
"keyList": null,
"inputMask": null,
"servers": null
"value": "23661",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_dur",
"value": "00:05",
"default": "00:00",
"keyList": null,
"servers": null
"value": "1",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23661/payload",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23661/thumb",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/23661",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/app/pilotedge/pilotedge.html?dataelement=23661&edit=",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"id": "ca6a3127-48a6-42e9-814b-a79ccafa8a12",
"insertId": "ba6f770a-1962-47ec-bdbe-54b81b3c25a6",
"storyDuration": 5,
"pageNumber": "",
"slug": "Untitled",
"accessories": [],
"items": [
"subItems": [
"id": "100_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ca6a3127-48a6-42e9-814b-a79ccafa8a12_2",
"type": "100",
"variant": "DSK",
"slug": "A test/Mosart=L",
"storyId": "ca6a3127-48a6-42e9-814b-a79ccafa8a12",
"status": 0,
"graphicType": "",
"description": "(DSK) - A test/Mosart=L",
"hasContent": true,
"in": 0,
"duration": 5,
"fields": [
"value": "A test/Mosart=L",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "14617",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_dur",
"value": "00:05",
"default": "00:00",
"keyList": null,
"servers": null
"value": "-2",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/14617/payload",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/14617/thumb",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/dataelements/14617",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "/app/pilotedge/pilotedge.html?dataelement=14617&edit=",
"default": null,
"keyList": null,
"inputMask": null,
"servers": null
"name": "tc_in",
"value": "00:00",
"default": "00:00",
"keyList": null,
"servers": null
"transition": {
"type": "Mix",
"rateOrIndex": 0
"bodyText": "",
"id": "0_a1e1e678-4adc-420a-bdbb-8aaa76dc6cf0_ca6a3127-48a6-42e9-814b-a79ccafa8a12_CAMERA1_1",
"type": "0",
"variant": "1",
"slug": "CAMERA 1",
"status": 0,
"hasContent": true,
"in": 0,
"duration": 5,
"fields": [
"name": "xpoint",
"value": "CAM1",
"default": "CAM1",
"inputMask": null,
"servers": null
"value": "False",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "False",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
"value": "",
"default": null,
"fieldType": null,
"keyList": null,
"inputMask": null,
"servers": null
Open Rundown
GET /api/v1/command/open-rundown?id={rundown-id} (since v5.10.0)
Load a specific rundown in Mosart.
rundowm-id: Either the name or IDof the rundown. Both can be found from the response of /rundown.
Reload Rundown
GET /api/v1/command/reload (since v5.4.0)
Reload the current rundown.
Take Next
GET /api/v1/command/start-continue (since v5.4.0)
Take the next item in the rundown. Has some optional URL parameters:
option: Default, Continue, Mix, Wipe, Effect
rate: The transition rate for mix/wipe (integer)
effect: The effect number (integer)
delay: The delay in milliseconds for continue (integer)
Skip Next
GET /api/v1/command/skip-next (since v5.10.0)
Skip the next item in the rundown.
Unskip Next
GET /api/v1/command/un-skip-next (since v5.10.0)
Unskip the last skipped item in the rundown.
Skip Next Sub Item
GET /api/v1/command/skip-next-sub-item (since v5.10.0)
Skip the next sub item in the rundown.
Unskip Next Sub Item
GET /api/v1/command/un-skip-next-sub-item (since v5.10.0)
Unskip the last skipped sub item in the rundown.
Start Rundown from Top
GET /api/v1/command/start-from-top (since v5.4.0)
Restart the rundown from the first story.
Set as Next
GET /api/v1/command/set-as-next?storyid={story-id} (since v5.10.0)
Set story as next.
Enable/Disable Rehearsal Mode
GET /api/v1/command/rehearsal-mode?state={state} (since v5.4.0)
Enable/disable/toggle Rehearsal mode.
state: true = enable, false = disable, no parameter = toggle.
Take a Template
GET /api/v1/command/template?type={template-type}&variant={variant}&bus={preview|program}&insert={true|false} (since v5.4.0)
Takes the template by its type and variant (name) as well as optionally, which bus (Preview or Program) and, for Preview bus, the insert option (if the template should be inserted in front of or overwrite an existing manual item). If an optional parameter is not used, the defaults are program (for bus) and false for insert.
Examples:
GET /api/v1/command/template?type=Camera&variant=CAM1
This will cut the Camera template variant CAM1 directly to Program.
GET /api/v1/command/template?type=Camera&variant=CAM1&bus=PREVIEW
This will put the Camera template variant CAM1 into Preview, replacing any manual item already in Preview.
GET /api/v1/command/template?type=Camera&variant=CAM1&bus=PREVIEW&insert=true
This will put the Camera template variant CAM1 into Preview, inserted in front of the item currently in Preview, not overwriting any manual item in Preview.
Trigger a DirectTake Template
GET /api/v1/command/directtake?number={number} (since v5.4.0)
Trigger a given DirectTake template. You must provide the template number.
Trigger Control Command
GET /api/v1/command/controlcommand/{command}?params… (since v5.10.0)
Trigger a control command in Mosart.
See also:
  • Keyboard-based Control Command Categories in the Viz Mosart User Guide (section Viz Mosart User Interface > Keyboard Shortcuts > Control Command Keys)
and
Here is a list of the control commands supported by the API along with the parameters the command takes.
Control command
Parameters (case sensitive)
start_from_top
switch_rehearsal_mode
Action=TOGGLE | ACTIVATE | DEACTIVATE
If no Action parameter is passed, it will DEACTIVATE.
autotake
Action=TRUE | ACTIVATE | FALSE | DEACTIVATE | TOGGLE
If no Action parameter is passed, it will TOGGLE
play_story
Story Name=string
videowallmode
MixEffect=string
release_background
CueOnly=TRUE | FALSE
overlay_graphics
Render=string
Action=CONTINUE | TAKE_MANUAL_OUT | TAKE_ALL_OUT | TAKE_LAST_OUT | PRETAKE_NEXT | CLEAR | MACRO | TAKE_NAMED_OVERLAY
Parameter=string
Value=string
directtake
Template=number
accessories
ncs
Action=START_STATUS | STOP_STATUS
Parameter=string
rundown_ncs_resync
user_message
Message=string
overlay_to_manual
Target=SELECTED | ONAIR | PREVIEW
Handlers=string
TakeOutMethod=AUTOMATIC | MANUAL
storyid=string
gui
asrunlog_event
Action=RemotePanelFunctions
Parameter=string
switch_graphics_mirroring
Action=TOGGLE | ACTIVATE | DE-ACTIVATE
enable_graphics_mirroring
Target=BOTH | OVERLAY | FULLSCREEN
Action=TRUE | FALSE
switch_genlock_mode
engine_switcher
Action=INIT | PRESET_STYLE | GOTO_PREV_PRESET
PresetName=string
Transition=CUT | TAKE
autotrans
MixEffect=PP | PROGRAM | ME1 | ME2 | ME3
Transitionrate=string
video_server_goto
ServerChannel=ONAIR | PREVIEW
frame=number
dve
Direction=FORWARD | FWD | REVERSE | REV | BACKWARD
fullscreen_graphics
Engine=string
Action=CONTINUE | MACRO
Parameter=string
audio
Action=FADE_MANUAL | FADE_OUT_KEEPS | FREEZE_AUDIO | SET_LEVEL_2_PREVIEW | SET_LEVEL_2_ONAIR | FADE_DOWN_ALL_MAINS | FADE_DOWN_SECONDARY_AUDIO | FADE_UP_LAST_MAINS | FADE_UP_SECONDARY_AUDIO
Faderate=number
light
Scene=number
sequence
Action=START | STOP | LOOP | STOPLOOP
take_server_to_program
Transitionrate=number
video_port
Action=PLAY_PAUSE | STOP | CUE | RECUE | SET_LOOP | PLAY_TAIL | CUE_TAIL
VideoPort=string
Parameter=string
get_player_status
VideoPort: string
weather
Action=PLAY | CONTINUE | GOTO_FIRST
graphicsprofile
Name=string
studiosetup
Name=string
set_aux_crosspoint
Bus=string
CrossPoint=string
set_crosspoint
MixEffect=PP | PROGRAM | ME1 | ME2 | ME3 | ME4
Bus=A | B | C | D | KEY1 | KEY2 | KEY3 | KEY4 | KEY5 | KEY6
CrossPoint=string
transition_type
TransitionType=MIX | WIPE | EFFECT | Default | Toggle | Cut | None
Value=number
record
Command=PREPARE | START | STOP | STOP_AND_DETACH | DELETE | GETSOM
ClipName=string
PortName=string
Group=string
Recorder=string
Duration=number
IgnoreClipNamePattern=TRUE | FALSE
device_property
For audio mixer device properties:
Parameter1=AUDIO
Parameter2=string
The key of the property you want to set.
Parameter3=string
The value of the property you want to set.
For camera control device properties (format depending on robotic camera system):
Anchor=string
Category=string
Speed=string
set_videoserver_salvo
Salvo=string
switch_videoserver_mirroring
reset_overunder
item_update_fields
Rather use the Remote Control API command "Update source item in preview or program".
For description of this command, see the entry for ITEM_UPDATE_FIELDS in Control Commands in Templates | Command Values and Parameters.
