vtefi_connection
The view vtefi_connection is an alternative to the tdfi_connection table. The tdfi_connection table is a relation between the td_templatedescription and fi_fields table while the vtefi_connection view provides a relation between the te_template and fi_fields table (i.e. no need to access the td_templatedescription table directly). The view is a join between the td_templatedescription and tdfi_connection tables.
Note: The vtefi_connection view only returns fields for templates description belonging to the gallery with ga_recno = 1. This is added by default and equal to the SHARED gallery.
Name
Type
Allow Null
Description
vtefi_te_recno
integer
No
Foreign key referencing the template te_recno in the te_template table.
vtefi_fi_recno
integer
No
Foreign key referencing the corresponding field fi_recno in the fi_field table.
vtefi_default
varchar(128)
Yes
Optional default value for fields not of type ENUMERATION (i.e for STRING and NUMBER types).
vtefi_em_recno
integer
Yes
Optional foreign key for the default value for ENUMERATION field types. Reference to a enumeration value em_recno in the em_enumerationmember table.
Note: Template description as stored in the td_templatedescription table that relates to the shared gallery (ga_recno=1) is defined to be shared information (i.e. common between all galleries). When the template description is updated from a gallery, a copy is made for the corresponding template description related to the shared gallery.
