Viz World Plug-ins Guide
Shadow Agent
The Shadow Agent plug-in is an agent for the Shadows parameters covered by the scene plug-in Label Manager.
Note: This plug-in is located in: Built Ins -> Geometry plug-ins -> Maps_Adv
Shadow Agent Properties
Render With Camera: Defines for which camera shadows apply.
All: Renders shadows on all cameras (Compatible with previous versions).
Label: Renders shadows only for the defined off screen labels camera.
Map: Renders shadows only for the defined map camera.
Shadow: Renders shadows only for the defined shadows camera, as defined in the Label Manager plug-in (Shadows tab).
