 Gateway Administrator Guide
Version 5.3 | Published June 17, 2021 ©
To Start the Gateway Controller Client
Select the program from the Start menu: All Programs > Vizrt > Media Sequencer> Gateway Controller.
Important! This shortcut starts the Gateway Controller as a web-application in the users default web-browser. The Media Sequencer must be running before starting the Gateway Controller.
It is also possible to launch the Gateway Controller by browsing to the following web address: http://<ADDRESS>:8580/app/gatewaycontroller/gatewaycontroller.html.
Note: It is possible to use one instance of the client to connect to multiple Gateway servers. To do this, simply connect to one server at a time and enter the appropriate connection parameters.
Substitute <ADDRESS> above with the actual IP or hostname of the Gateway server.
