Viz Engine 5.5.0
Release Date: 2026-02-12
These are the release notes for Viz Engine version 5.5.0. This document describes the user-visible changes that have been made to the software since release 5.4.1.
Note: Viz Artist maintains its release notes in a separate document starting from version 3.12.0.
Installer Notes
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
The Setup application (both MSI and Bundle installer) must be run in Administrator mode.
Visual C++ Redistributable files are no longer part of the .msi setup file. These files are now installed with the bundle setup application (VIZENG-13210, VIZENG-12629, VIZENG-12701).
The bundle setup application installs or upgrades Viz Artist together with its required Visual C++ Redistributable files (VIZENG-12936, VIZENG-13804).
All files contained in the bundle setup application can be extracted using the
/dumpcommand line option. This creates a sub-folder where the files are extracted (VIZENG-13020).Multiple installations of Viz Engine are not supported.
The installer automatically upgrades (replaces) any existing Viz Artist/Viz Engine 3.x installation. However, downgrading is currently not supported (VIZENG-7098).
If Adobe After Effects is installed after Viz Engine, the Viz installer needs to be executed again to install the AE plug-in (VIZENG-7876).
The user account must have SeCreateGlobalPrivilege (SE_CREATE_GLOBAL_NAME) enabled.
The configuration profiles shipped with Viz Engine guarantee a correct Audio/Video delay, to have a proper lip-sync setup or a correct video wall installation. A manual configuration (for example, number of inputs, clips, etc.) is still required, after applying these profiles (VIZENG-18861).
To use Global Illumination in Viz Artist/Viz Engine, at least Direct X version 9 is required. (VIZENG-19983).
Download the DirectX End-User Runtimes (June 2010):
Microsoft Download Link: Download DirectX End-User Runtimes (June 2010) from Official Microsoft Download Center
Extract the files:
Run the downloaded .exe and select a folder for extraction.
After extraction, navigate to that folder and run DXSETUP.exe.
Complete the installation:
This installs all missing legacy DLLs, including d3dx9_43.dll.
The Basic, Viz DataPool, Viz PixelFX, Viz Maps, Viz Extension and Viz Socialize plug-ins are released together with Viz Engine, starting with version 4.0.0, and are included in the bundle installer. The basic plug-ins are installed by default.
Note: In case of installing Viz Engine with the individual MSI installer and not the Viz Artist Bundle installer, ensure all runtime dependencies are up-to-date (for example, Viz Engine does not start with an outdated Microsoft Visual C++ 2015-2022 Redistributable (x64) version). The minimum required version is 14.40.33810 (https://aka.ms/vs/17/release/vc_redist.x64.exe).
If Microsoft Visual C++ 2015-2022 Redistributable (x64) - 14.40.33810 is already installed and Viz Engine is not starting, the runtime installation could be damaged. Reinstall the runtime redistributable in this case. The related installer is part of the Bundle installer.
Information: In case of upgrading from previously installed versions, and the upgraded version comes with a new CodeMeter version, make sure that all the applications installed using CodeMeter on the same host, are still running.
Windows
This software was tested to run on Windows 11 (LTSC 24H2), Windows 10 (LTSC 1809, 21H2) and Server 2019 and Server 2022.
Windows transparency effects should be turned off (former known as Aero). In Windows 10 set Show transparency in Windows to
Offin Settings > Display and Transparency effects toOffin Settings > Personalization > Colors > More options.Power management and hibernation mode must be turned off under Windows. You can execute
powercfg -h offto remove hiberfil.sys from the hard disk.It is recommended to install the latest Windows Security Updates and Patches, except NVIDIA updates.
Installations on Windows 10 are only supported on their respective supported hardware (see Supported Systems).
.NET framework 4.5 or higher is required (VIZENG-6036).
The minimum Windows Installer version is now 5.0.0 (VIZENG-10146).
To run Viz Engine without Administrator privileges, you need to grant the following permissions:
SeIncreaseBasePriorityPrivilege
SeCreatePagefilePrivilege
SeIncreaseWorkingSetPrivilege
UAC
Viz Engine is UAC aware. Configuration files, profiles, log files, and additional files are stored in %VIZ_PROGRAMDATA%, which defaults to %ProgramData%\Vizrt\VizEngine. Temporary data is stored in %VIZ_TEMPDATA% which defaults to %TMP%\Vizrt\VizEngine. The default value can be changed in the command line of viz.exe.
Existing Lens files are copied from %ProgramFiles% install folder to the new UAC aware %ProgramData% folder during installation (VIZENG-8757).
Existing Viz configuration files are copied from %ProgramFiles% install folder to the new UAC aware %ProgramData% folder during installation (VIZENG-7472).
Cinema 4D
Cinema 4D LiveLink Installation: The installer searches the following location first: %ProgramFiles%\MAXON\CINEMA 4D R16\plugins (VIZENG-7965).
Cinema 4D LiveLink package can be installed any time later by using Viz Artist Installer in Repair mode. Its installation folder is not selectable anymore (VIZENG-8996).
Cinema 4D R23 or newer: LiveLink plug-in is available at %ProgramFiles%\Vizrt\VizEngine\CINEMA 4D LiveLink\R23 (VIZENG-25344).
Driver Versions
These are the recommended driver versions for various hardware components:
Vendor | Driver Version |
NVIDIA Blackwell, Ada Lovelace, Ampere, Turing, Volta, Pascal and Maxwell GPUs | |
NVIDIA Kepler GPUs | 473.47 (419.17 for older boards) |
Matrox Topology based boards | 11.2.101.2608 (LTS) |
Bluefish | |
Bluefish Supernova Firmware | 162 |
AJA | 16.1.0.3 (Firmware 2021/06/23) |
Codemeter Runtime Kit | |
AV PCL/PCI Plura Timecode Reader |
NVIDIA Drivers
Information: Please refer to https://nvidia.custhelp.com/app/answers/detail/a_id/4777/~/nvidia-dch/standard-display-drivers-for-windows-10-faq for information about the DCH and Standard driver versions and how to install a missing NVIDIA control panel.
NVIDIA driver 573.76 is recommended for GPUs with Blackwell, Ada Lovelace Technology. Ampere, Turing, Volta, Pascal or Maxwell Technology cards have been tested with 573.76 only. A driver upgrade is not recommended in general. Kepler GPUs are not recommended anymore, however they might still work using older driver version 473.47. Boards that do not support this version of the driver should use rev. 419.17.
NVIDIA Driver Configuration (Manage 3D Settings):
Setting | |
Vertical sync | Force Off (except Videowall and systems without video hardware). |
Unified Back Buffer | Off |
Power management mode | Prefer maximum performance |
Antialiasing mode | Enhance the application setting |
Antialiasing setting | 4x (4xMS) |
Profile | Workstation App - Dynamic Streaming profile (for systems with video hardware) |
Important: Viz Engine will not start if an outdated driver is used.
Matrox Drivers
For Matrox video cards, driver version 11.2.101.2608 (LTS) is required. This version is mandatory. Pre-release versions are not supported.
Uninstall previous versions of Matrox DSXUtils prior to installing this driver.
Install drivers (DSX-TopologyUtils.exe) only from a local drive.
Reboot between uninstall and install of drivers, and another time after the installation has finished.
The VfW codecs are included in this driver, so uninstall previous versions of the Matrox VfW codecs and do not install any Matrox VfW codecs over the regular driver installation.
Other Drivers
The latest firmware for Supernova and Supernova S+ is 162.
The latest firmware for Neutron is 1i2o 35. There is no longer 1in1out firmware.
The recommended firmware for AJA IO4K+ devices is 2021/06/23.
The recommended driver version for Plura AV timecode reader cards is 5.34.
Please refer to the Viz Engine Administrator Guide for which drivers and driver settings to use.
Given that a supported Matrox device is installed, the following codecs are supported for post-rendering with MatroxFileWriter and the ClipOut channels:
RLE (animation), playback only
H.264
Apple ProRes
HDV
XDCam
DVCPro
DNxHD (4849)
XAVC (UHD requires M264 board)
Upgrade Notes
All plug-in installers are installed per-machine starting with 5.2.0. Uninstalling all previous per-user plug-in installations before upgrading is recommended to avoid duplicated installer entries.
Existing Viz 3 configuration files, Genlock and IP configuration settings are migrated automatically by Viz Engine.
The old Shared Memory output is not supported on the Viz Engine Pipeline.
Due to changes in the video IO part, ring buffer size for interlaced virtual studio setups might require a higher ring buffer setting. Existing configuration file(s) might need to be adapted.
The command interface is not locale-aware. Special regional settings like a semicolon within float numbers do not work. You need to use a regular "."
Information: Viz Engine is not forward-compatible. Opening scenes created in this version of Viz Engine might drop warnings when opening in previous versions. A scene saved with this version might look different if you open it in a previous version. This affects scenes containing more than four streaming channels.
Licensing Model
The CodeMeter Runtime (installed with the bundle installer) is required to use the WIBU license system. Details can be found in the manual in section "WIBU-based Licensing System". Please refer to the Vizrt Licensing documentation on how to apply a license container.
Cloud-based installations require a license server; standalone cloud installations are not supported.
Other Upgrade Notes
NVIDIA Tesla Grid K2 Support was removed because no up-to-date drivers are available anymore.
Lens distortion uses a slightly different norm since revision 54263. If you need older lens files, please use
use_lens_compatibility_mode = 1in the config file.Viz Artist is now being started by the Viz Engine process and not by command file anymore. If you start viz.exe and VizGui.exe independently, the Restart Current option fails.
A 64-bit version of each codec must be installed to work with Softclip64. Most codecs come with an installation manual on how to install them correctly.
Softclip64 has been tested to work with the following 64-bit codecs:
HuvYuff Version 2.1.1
Lagarith Version 1.3.27
Newtek SpeedHQ
Virtual Environments
The following GPUs have been tested in virtualized environments, the listed driver version is the one being used. The following GPUs are currently supported (Kepler are only supported in the Classic Render Pipeline):
Model | Driver | Platform |
NVIDIA L4 | 573.07 | AWS (g6 instances, gr6 instances) |
NVIDIA A10G | 573.07 | AWS (g5 instances) |
NVIDIA T4 Tensor Core | 573.07 | AWS (g4dn instances) |
NVIDIA Tesla V100 | 431.79 GRID9.1 | AWS (p3 instances) (1) |
NVIDIA A40 (2) | 572.60 | vSphere 7.0 and 8.0 |
NVIDIA RTX6000 | 572.60 | vSphere 7.0 and 8.0 |
(1) Instance not supported on Windows Server 2025 or higher (legacy uefi boot).
Viz Engine has been tested to run in the following virtual environments:
Viz Engine Render Pipeline | Classic Render Pipeline | |
Amazon Cloud (AWS) | ||
Microsoft Azure (1) | ||
fra.me/nutanix (1) | not tested |
VMWare ESXi (6.0(1), 6.50(1), 7.02, 8.0.2) |
Alibaba Cloud (1) | not tested |
(1) Tested with Engine 5.0.0 only | ||
Note: Backup and Restore on Azure systems are currently not supported.
New Features
Key Features
Key |
Summary |
New Features: General
New Features: Renderer
New Features: Video IO
Fixed Issues
Fixed Issues: General
Fixed Issues: Renderer
Fixed Issues: Video IO
Security Updates
Changes
Upcoming Changes
NVIDIA has announced that drivers 580.xx are the latest ones to support Maxwell and Pascal architectures.
Support for Windows 10 LTSC 1809 will be dropped.
Changes: General
NVIDIA Tesla M60 VGPU support has been removed.
Windows Server 2019 VGPU support has been removed.
ChromaFX license has been renamed to Precision Keyer.
Changes: Renderer
Using Tracking Hub is now enabled by default in Configuration.
NVIDIA Kepler GPUs were set as deprecated (NVIDIA isn't supporting Kepler boards in newer driver versions anymore).
Changes: VideoIO
Note: The Matrox channel mapping format has been updated in the configuration file. Old config files are migrated automatically during startup.
Known Issues
General
The final position and size of scaled image channels in DVE mode might change by 1 pixel after fixing rounding issues.
Saving a new scene with references that do not exist anymore fails. Those references need to be removed manually to save the scene.
Importing HDR images with special characters in its file name from a drive with 8dot3 disabled fails.
Transition Logic scenes require to have GeomAutoFree = 1 set in the Viz Config file. With inactive GeomAutoFree, system stability is not guaranteed.
Interactive Applications within a GFX channel only work in DVE mode in Fullscreen or if the GFX channel has an offset in Fullscreen. Scaled GFX channels or plug-ins that rely on screen coordinates (Graffiti) are not supported.
Bones and Skin live motion data tracking requires Tracking Hub 1.1.2 (released together with Viz Engine 3.11).
Viz Engine REST interface does not start if a user is Non-Admin (VIZENG-23386).
On Air output shows wrong field-of-view if AuxRenderer is enabled, PP in scene editor is disabled and Viz Engine is not in On Air mode.
The Toggle plug-in can not handle the background loading of objects or scenes.
Oversized snapshot requests (bigger than the configured output resolution) in the Classic Render Pipeline aren't supported. Use the Viz Engine Render Pipeline instead.
The
clogcommand now includes all child processes. Upon abnormal end, all child processes are terminated before a restart is attempted (VIZENG-11361).Scaling directors down can cause keyframes to be scaled down to 0.0. These values do not recover when scaling directors up again afterwards (VIZENG-31610).
Installation
Do not use the C4D Version 15R2 patch file(s) unless you are using this version. Otherwise, it prevents Cinema 4D R16 from starting up.
When uninstalling Viz Engine, the installer might report that links could not be removed. Please check that none of the desktop.ini files of Windows have write protection. For example, Skype seems to change the permissions of some desktop.ini files with every update.
Windows 10
Right-clicking on the Taskbar icon of Viz Engine starts a new instance. Starting an additional VizGui process is prevented on Windows 10.
Error message "Windows Media Player Rich Preview Handler has stopped working while opening specific clips with Softclip x64". To fix open Windows Explorer > Tools > Folder options > View tab, and deselect Show preview handlers in the preview pane.
Videowall
It might happen that Viz Engine is running at half speed on videowall, but goes back to full speed if another window comes into focus. If so, start
viz.exe -y -w, instead of the regular videowall modeviz.exe -n -w.GFX channels with Alpha != 100% decrease render performance. On video wall setup,
gfx_channels_antialiased = 0should be turned off in the Viz Configuration section RENDER_OPTIONS.Windows scaling can lead to unwanted side effects.
The maximum resolution on videowall setups is limited to 16392px by 16392px.
Enabling video output for audio setups is not recommended for performance reasons. It is recommended to grab the audio from one of the HDMI/DP outputs of the NVIDIA GPU and use an Audio embedder instead.
Configuration
Specifying a path in the configuration file including the # character is not supported. Such paths are cut before the # character.
Existing Scenes using Global Illumination might need a precompute again to enable debug views.
Background loading of external images (filesystem, network locations, etc.) is not supported. Images from Graphic Hub should be used.
Flexbox labels in Scene Editor do not support Unicode characters.
Scene Transitions within GFX channels or Superchannels are not supported.
Soft Shadow intensity is currently not working together with Global Illumination.
We recommend using a warmup scene showing all needed assets once. Under certain circumstances, video and clip surfaces can show up red the first time being used.
Playing Audio clips on systems with no physical audio hardware available stops the renderer. You need to turn off audio in the configuration file.
On some systems with hybrid graphics, like laptops, the dynamic swapping must be disabled in the BIOS and the stronger GPU must be assigned as default.
Stencil-based shadows (Caster/Receiver) do not work on rotated geometry.
When changing
CurlAuthUnsafe = 1, Viz One Browser does not work anymore.VGA Fullscreen Output is only active if offscreen rendering is turned off. Setting
offscreen=0in section RENDER_OPTIONS enables fullscreen output.Blending cubemapped images are not supported.
Cubemapping with Browser plug-in is not supported.
Fonts need to be re-imported to use new Pathrendering or Razor fonts technology.
Masks are not supported on Path rendered Fonts (VIZENG-13737).
Do not send other commands than
IS_RENDERER_READYand database connection commands before this command returns1, otherwise the renderer and video output might not be initialized.If you encounter stability issues with an NVIDIA driver or issues during driver installation, uninstall the old NVIDIA driver completely, delete the folder C:\Program Files\NVIDIA Corporation\Installer2, install the new driver and select Custom installation, then check-mark the perform clean installation option and finish the installation.
Enabling background loading might decrease the render performance by up to 15 frames per second. This is due to OpenGL requirements.
M-Zone keyer only works with HD when rendering with full frames.
Decreased render performance in HD since Viz Engine 3.5.0 when the ringing filter is activated. Before Viz Engine version 3.5.1 there was no ringing filter for HD. Turn off the ringing filter via configuration or scene-setting to get the same performance.
Sporadic NVIDIA driver error The NVIDIA OpenGL driver lost connection with the display driver and is unable to continue. which in turn causes Viz Engine to freeze. Make sure that the driver profile Workstation App > Dynamic Streaming is selected. Always use the recommended NVIDIA driver for your GPU.
Possible performance problems with scenes imported from Viz Engine 2.x. Check the following settings (applies to old 2.x scenes only):
Image Combining should be set to Multi Texturing in the Render options in the configuration (or flag
combine_with_multitex = 1in the configuration file) to avoid inefficient image combining.Set Key Render Mode to Single Pass in the rendering options in the configuration. The Key Render Mode can also be set on scene level. Available options are:
Config (inherit the setting from the configuration).
Single Pass (fill and key are rendered in a single pass).
Double Pass (fill and key are rendered in separate rendering passes).
Key rendering results differ between these options for compatibility reasons.
Use Single Pass scenes imported from Viz Engine 2.x and Double Pass for Viz Engine 3.x scenes.
The configuration flag
exec_all_animationsin the section RENDER_OPTIONS should be set to0if it is not necessary to execute hidden animations.Turn off the VGA preview in On Air mode to avoid performance drops due to multiple rendering of the scene (applies only to video version of Viz Engine).
Hide containers that are not required for the current animation.
Re-import fonts directly with the Viz Engine.
Grid picking currently only works for Cube and Cylinder geometry.
The behavior of scripts with cyclic dependencies to other scripts is undefined. Avoid cyclic dependencies.
Bad performance when using multiple dynamic scenes, even if they are set inactive. To avoid unnecessary updates, change the Update mode in Dynamic Scenes to Auto instead of Always.
CLR LOADcommand can crash Viz if not used correctly. Required function signature: static int pwzMethodName(String pwzArgument).Alpha setting for DVEs is not correctly supported when a scene is used nested using a GFX channel (VIZENG-10212).
Glow plug-in drops performance when used on multiple containers and rendered within a GFX channel or viewport tile (Classic pipeline) (VIZENG-11342).
Scene transitions do not work when dynamic images from different folders are involved. Dynamic images always need to be stored directly in the root folder dynamic and references must point there. Dynamic images in a subfolder of the dynamic folder or any other folder are not found.
Font option "lighted" has no effect on fonts rendered with type "vector" (VIZENG-18941)
16-bit PNG images are not rendered properly when imported with compression.
Unreal Integration
Note: It is not advisable to utilize the Unreal integration in production environments outside of Game Mode. For instructions on how to initiate Unreal in Game Mode, please consult the Viz Artist User Guide Chapter Third Party Integrations.
Unreal Engine 5.x with Temporal Super Resolution (TSR) enabled can lead to flicker issues when used in combination with NVIDIA Driver 528.89. Changing to FXAA solves the issue.
Unreal Engine 5.5 with DLSS enabled can lead to memory issues.
Post Renderer
Because of performance issues rendering fullscreen sequences in UHD is not supported.
Ghosting effect in post-rendered interlaced video: Make sure that the Flicker Filter is set to
0in the post-rendering options of the Video Render plug-in.Post-rendering does not work properly if
onair_no_videoout flag = 1(Videowall mode).Post-rendering does not work properly if TriCaster integration is active and the output format is set to User Defined or Fullscreen.
DVCPRO expects 720x480 in NTSC resolution. Please set the correct output width in AVIRenderer.
The alpha channel cannot be rendered with Intel Indeo 5.10 codec. This codec is not supported.
Viz Engine might crash if certain VfW codecs are used on non-Matrox installations in Post Render Mode.
Matrox
Important: When upgrading from 10.4 to 11.x Matrox driver, follow these mandatory steps:
Uninstall old Matrox driver
Cold Boot (Turn off computer for at least 20 seconds)
Switch Computer on
Continue installation of new driver
Enable Hardware DVE/(Fast Texture Mode) is only available for two instances.
The configuration ClipIn[n].UseV210 and ClipIn1. ContainsAlpha are mutually exclusive and should not be enabled at the same time.
The overall delay is one field higher than in previous versions using IO3 This is caused by the required A/B buffer of IO 4.
A program output channel needs to be defined. Pure preview or Cleanfeed is not supported.
HDR output on UHD 2SI requires at least a Quadro P6000 GPU.
Large Canvas setups require a RTX5000 Ada or higher.
Mixing different frame rates with clips processed by a M.264 board is not supported and causes jittering.
Upgrading the FPGA can cause a PCI error during the boot process on certain systems. Unattended upgrading of the FPGA is not recommended.
Watchdog is only supported in 50/60M and 60Hz frequencies.
When using 3G formats (1080p/UHD) or the Zero-Frame-Delay Mixer, auto-sensing of the sync signal is not supported due to incompatible H-/V-phases, that are set in the process.
Instead, either Tri-Level or Blackburst must be used together with correct H-/V-Phase. This might result in a missing key signal (VIZENG-11708).
For dual channel systems, please perform the following steps after enabling the watchdog to ensure the correct state is written to the Matrox Board:
Start Channel 1.
Wait until channel has started up and topology has been written.
Start Channel 2.
Exit channel 2.
Exit channel 1.
Start channel 1.
Start channel 2.
ClipOut channel does not work when Matrox0.VideoOut1.FrameBufferDelay is set to zero (VIZENG-16373).
UHD Clip Playback with M264 S1/S2/S3 alone requires color conversion on the shader level. (VIZENG-20700).
Two Sample Interleave (2SI) clips played as DVE are not supported.
Cutting of Audio tracks should not be done at all, as this results in a crackling noise. Always use a cross-fade to change audio sources.
Certain M4V clips may cause Viz Engine to lock and flood the console with errors when being played in a loop.
Running interlaced AVC-Intra 100 clips on M.264 boards may lead to instabilities when played non-stop over several hours.
Always verify the Destination Connector when changing/adding configurations of output channels.
X.mio3 Boards
If the Viz instance is closed unexpectedly, the X.mio3 topology might become unusable. To reset the topology, enable ResetTopology in the config file, restart Viz, close it and start Viz again.
Turning on the Cleanfeed Feature increases the delay by one frame.
It is not recommended to change the frame group of any input signal while Viz Engine is running.
Only two DVE UHD inputs are supported at 50Hz. For 60M formats, only two texture inputs are supported.
Animating UHD DVE scaling might result in jittering. You need to increase the VideoDelayDVE setting to
2.Texture delay with PAL/NTSC, and Enable Hardware DVE is five fields instead of four fields. (VIZENG-16955).
When using watchdog together with a clean feed, the watchdog triggers on the clean feed connector rather than the program output (VIZENG-16589).
X.mio5 Boards
Standard Definition (PAL and NTSC) resolutions are not supported by X.mio5 IP boards according to the SMPTE ST 2110 standard.
Streampunk ledger RDS does not list the Matrox X.mio5 nodes. This is due to some old NMOS APIs that are partially deprecated.
Riedel Explorer fails listing the X.mio5 nodes. Riedel Explorer automatically selects NMOS API Version 1.3 instead of 1.2. It is possible to select the used API version manually if you switch to static mode and/or enable version downgrade in the Riedel Explorer.
The X.mio5 board has been tested to support up to 12 Inputs (1080i 50 and 60M) on a 10GbE network.
DSX.core
After the installation of the DSX-core client version of the driver perform the following steps:
Unregister mvfDsxCore.dll.
Click Start > Run (or use the Windows command line: Search > CMD > (Right click) Run as Administrator)
Type
REGSVR32 /U "C:\Program Files\Matrox DSX-TopologyUtils\System64\mvfDsxCore.dll"and press ENTER.
Shut down http://X.info in the task manager (mveXinfo.exe).
Delete mvfDsxCore.dll from the folder C:\Program Files\Matrox DSX-TopologyUtils\System64\.
Start http://X.info (mveXinfo.exe).
Other Video Boards
When Viz Engine is in On Air mode, there might be audio distortions using Bluefish cards (VIZENG-8853).
Bluefish Supernova S+ cards can only be used in a Virtual Set Environment if the board is synced to Blackburst/Trilevel.
NDI
Security Updates Windows 11 – KB5063878 and Windows 10 – KB5063709 can lead to traffic drops in NDI output.
NVIDIA
When the computer is running out of virtual page size and the user keeps ignoring the low memory warnings in the console, the NVIDIA driver may cause Viz Engine to crash.
The NVIDIA driver doesn't recognize other GPUs under certain circumstances in combination with video wall mosaic installations. Remove and reinstall the driver.
Graphic Hub
Communication with the Graphic Hub Server might fail if virtual network adapters are active. Please disable all virtual adapters or increase the timeout.
If the connection to the naming server fails, please verify the communication port in the config file (Port
19396).
Adaptive Scene Design
WindowMask plug-in prevents Flexbox labels from being picked.
Audio
Unplugging a USB microphone from the machine while EAS is enabled freezes Viz Engine without the possibility to recover (VIZENG-29571).
Supported Hardware and Software
This software has been tested to run on:
Windows 11 (LTSC 2402)
Windows 10 (LTSC 21H2) & (LTSC 1809)(1)(2)
Windows Server 2025, Windows Server 2022
(1) Future Versions of Viz Engine will no longer provide support for Windows 10 LTSC 1809.
(2) Unreal Engine requires a newer Windows 10 version than 1809. UE Integration was successfully tested with 21H2
Note: Only English language Operating System(s) are supported.
Supported Systems
System |
Lenovo P3 Ultra / Lenovo P3 Ultra Gen2 |
Lenovo P620 |
Lenovo SR655 V3 |
DELL R7920 |
HP Z8 G5 Fury |
HP Z8 G4 |
HP Z4 G5 (Rack and Tower) |
HP Z4 G4 |
HP ZCentral 4R |
Supported GPUs
Blackwell GPUs | Ada Lovelace GPUs | Ampere GPUs | Turing GPUs | Volta GPUs | Pascal GPUs | Maxwell GPUs |
Blackwell 6000 Max Q | RTX 6000 Ada | RTX A6000 | RTX 6000 | GV100 | Quadro P6000 | Quadro M6000 |
RTX 5000 Ada | RTX A5500 | RTX 5000 | Quadro P5200 | Quadro M4000 | ||
RTX 4500 Ada | RTX A5000 | RTX 4000 | Quadro P4200 | Quadro M2000 | ||
RTX 4000 Ada SFF | RTX A4500 | RTX 3000 | Quadro P4000 | |||
RTX 2000 Ada | RTX A4000 | T1000 | Quadro P3200 | |||
RTX A2000 | Quadro P2200 | |||||
RTX A3000 (mobile) | Quadro P2000 | |||||
RTX A2000 (mobile) | Quadro P1000 | |||||
RTX A1000 (mobile) |
Supported Video Boards
Video Board | Configuration |
Matrox Electronic Systems Ltd | |
Matrox X.mio5/X2 SDI | Up to four 12G SDI input with up to four SDI 12G SDI outputs |
Matrox X.mio5/8 SDI | Up to four 12G SDI input with up to four SDI 12G SDI outputs |
Matrox X.mio5 IP | Up to 32 ST 2110 inputs and 32 ST 2110 outputs depending on used SFPs and resolution |
Matrox X.mio3 Full Height | Various input/output configurations from 48 to 84 |
Matrox X.mio3 12G | Two 12G inputs, two 12G outputs |
Matrox M.264 S1/S2/S3/S4 | H.264 Encoder/Decoder board |
Matrox DSX LE 5L /4 | Various input/output configurations from 04 to 40, all in 12G |
Matrox DSX LE 4 /8 | Various input/output configurations from 08 to 80 |
Matrox DSX LE 4 /4 | Various input/output configurations from 04 to 40 |
Matrox DSX LE 4 IP | Various input/output configurations from 04 to 40 |
BlueFish Technologies | |
Bluefish Epoch Neutron | Two video inputs, two video outputs (fill & key) |
Bluefish Epoch 4K Supernova | Two video inputs, two video outputs (fill & key) |
Bluefish Epoch Supernova S+ | Two video inputs, two video outputs (fill & key) |
Bluefish Kronos K8 | Four video inputs, two video outputs (fill & key) |
AJA Video Systems, Inc. | |
AJA IO4K Plus | Two video inputs, two video outputs (fill & key) |
AJA Kona 4 | Two video inputs, two video outputs (fill & key) |
Build Information
Platform Toolset: Visual Studio 2022 (v143)
Windows SDK Version: 10.0.22621
Documentation
Info: Starting with Viz Artist/Viz Engine 5.4.0, the installer no longer installs the Viz Artist User Guide, Viz Engine Administrator Guide or Viz Plugins User Guide as offline documentation.
Documentation for Viz Engine, Viz Artist and Viz Plugins is available online on the Vizrt Documentation Center:
Installation and Support
Installation
The installation wizard guides you through the installation process. Make sure to close any running Viz application prior to the installation. In order to run Viz Artist or Viz Engine independent of a database server, you need to install the Viz Graphic Hub database software locally.
Support
