Supported NVIDIA GPUs
Blackwell GPUs
Ada Lovelace GPUs
Ampere GPUs
Turing GPUs
Blackwell 6000 Max Q
Blackwell 5000
RTX 6000 Ada
RTX A6000
RTX 6000
Blackwell RTX 4000 Pro
Blackwell RTX 2000 Pro
RTX 5000 Ada
RTX A5500
RTX 5000
Mobile GPUs
Blackwell RTX 3000 Pro
Blackwell RTX 5000 Pro
RTX 4500 Ada
RTX A5000
RTX 4000
RTX 4000 Ada SFF
RTX A4500
RTX 3000
RTX 2000 Ada
RTX A4000
T1000
RTX A2000
RTX A3000 (mobile)
RTX A2000 (mobile)
RTX A1000 (mobile)
Orange entries are recommended for rendering photo-realistic graphics on the Viz Engine Pipeline.
Virtualized GPUs
The following GPUs have been tested in virtualized environments, the listed driver version is the one being used.
The following GPUs are currently supported.
Model
Driver
Platform
NVIDIA RTX PRO Server 6000 (Blackwell)
596.86
AWS (g7e instances)
Proxmox 9.2.2 (12q instance)
596.86
AWS (g7 instances)
NVIDIA L4
(Ada)
596.86
AWS (g6 instances, gr6 instances)
NVIDIA L40S
(Ada)
AWS (g6e instances)
NVIDIA A10G
(Ampere)
596.86
AWS (g5 instances)
NVIDIA T4
(Turing)
596.86
AWS (g4dn instances)
NVIDIA A40
582.78
vSphere 8.0 (VGPU 19.6, 8q instance)
NVIDIA RTX6000
582.78
Driver History
Starting with Viz Engine 5.6 we recommending a minimum driver version only.
Viz Artist/Engine Version
Minimum recommended driver
5.6.0
596.86 for Blackwell, Ada Lovelace, Ampere and Turing GPUs
5.5.0
573.76 for Ada Lovelace GPUs
573.76 for Ampere, Turing, Pascal, Maxwell, Volta GPUs (1)
5.4.1
572.83 for Ada Lovelace GPUs
5.4.0
572.83 for Ampere, Turing, Pascal, Maxwell, Volta GPUs (1)
5.3.1, 5.3.2
553.24 for Ada Lovelace GPU
553.24 for Ampere, Turing, Pascal, Maxwell, Volta GPUs (1)
5.3.0
552.22 for Ada Lovelace GPUs
552.22 for Ampere, Turing, Pascal, Maxwell, Volta GPUs (1)
5.1.0, 5.1.1, 5.2.0, 5.2.1
528.89 for Ada Lovelace GPUs
516.59 for Ampere, Turing, Pascal, Maxwell, Volta GPUs (1)
5.0.0, 5.01
516.59
473.47 for Kepler boards
4.4.0, 4.4.1
472.12
4.3.0, 4.3.1
462.31
4.2.0
442.19
3.13.x, 3.14.x,4.0, 4.1
419.17
3.9.x, 3.10.0, 3.11.x, 3.12.x
385.41
3.8.3
368.86
3.8.2
361.91
3.8.1
353.82
3.8.0
347.25
3.6.4
341.21
(1) When used in combination with Unreal Engine 5.3 and higher, 572.83 is mandatory.
If there is any security concerns about the CVE's you can upgrade to a newer version at your own risk.
Note: There is no driver recommendation for virtual environments as they rely on the host operating system being used.
