The Matrox X.mio5 video board is the next generation IP card supporting SMPTE ST 2110‑20/30/40 protocols. It is equipped with 25GbE SFP28 cages and is available in two models:
  • X.mio5 Q25 - four (two dual) SFP28 cages, delivering an effective, fully redundant bandwidth of 50GbE, capable of providing four UHD inputs and outputs.
  • X.mio5 D25 - two (one dual) SFP28 cages, delivering an effective, fully redundant bandwidth of 25GbE, capable of providing two UHD inputs and outputs.
Both models support 10GbE and 25GbE SFP28 transceivers. (The SFP+ form factor is identical to SFP28: SFP+ designates 10GbE, SFP28 designates 25GbE; both are compatible with the card.)
Key Features (both models)
  • Native SMPTE ST 2110 support with no CPU usage.
  • ST 2110‑21 packet pacing in hardware for narrow senders (Type N).
  • Wide asynchronous receivers (Type A).
  • Audio flows from one to 64 tracks.
  • Multi-channel HDR conversion.
  • On-board de-interlacing, scaling and compositing.
  • Integrated hardware PTP for ST 2059‑2.
  • Built-in NMOS IS‑04 and IS‑05 support.
ℹ️ Large Canvas Output: The Matrox X.mio5 D25 supports Large Canvas Output for SMPTE ST 2110‑driven video walls, allowing custom non‑broadcast canvas resolutions of up to 8192 × 4320 pixels, composed from up to eight progressive, broadcast‑resolution cutout flows. The D25 supports a maximum of two UHD outputs. Appropriate output license(s) (4K, 8K, …) are required. Large Canvas Output is not supported on the X.mio5 Q25. See Large Canvas Output (Large Canvas Output for configuration details.
Per-model capacity
Q25
D25
UHDp60/50 in & out
Up to four
Up to two
HD in & out (over 25GbE)
32
16
Audio flows
256
128
General Notes
  • An X.mio5 uses a 16x PCIe slot (x8 electrically). It can't use the same slot as an X.mio3.
  • To keep PTP stable, all Power Management options in Windows and BIOS must be disabled (Runtime power management disabled in BIOS settings).
  • Each SFP of an X.mio5 board requires two IP addresses. This is mandatory. (One for the Matrox network adapter and one for genlock over IP.)
  • NTSC and PAL resolutions are not supported by the SMPTE ST 2110 standard.
  • UHD is only supported with 25GbE SFP cables. UHD is not possible with 10GbE SFP cables.
  • On the Q25, the second SFP pair (SFP C/D) provides connectors starting at video 17 / audio 129 / ANC 33. See Explicit Usage of the Second SFP Pair on Matrox X.mio5 Q25. The D25 has only the first SFP pair (SFP A/B) and therefore no second pair.
  • Ethernet packet capture (mvNetworkCapture) is not supported on the D25.
Matrox X.mio5 IP Configuration
Please see section SMPTE ST 2110 Configuration for further details.
