Prerequisites
The feature adds support for custom non-broadcast resolution canvases targeting SMPTE ST 2110-driven video walls.
Note: Make sure your required output is covered by the appropriate license(s). For example, 4K, 8K, …
Supported Video Hardware
  • Matrox X.mio5 D25
  • Matrox DSX LE5 (D25, Q25)
  • Matrox DSX LE6
Known Limitations
  • The canvas resolution cannot exceed 8192 * 4320 pixels for supported X.mio5 and DSX LE5 boards, and 15360 * 2160 pixels for DSX LE6 boards.
  • The canvas resolution has a minimum resolution of the selected output flow resolution, 1280x720 pixels with 720p.
  • When using output flows with different resolutions, the larger output flow dictates the minimum resolution.
  • The canvas width needs to be a multiple of 64 and the height needs to be even.
  • The single cutout flows need to be progressive and in broadcast resolution.
  • There are at most eight cutout flows.
  • The minimum value for the horizontal position is 0 pixels. The maximum value is the canvas resolution width, minus the output resolution width. The position must be a multiple of two pixels. Odd values are rounded to the lower even value.
  • The minimum value for the vertical position is 0 lines. The maximum value is the canvas resolution height, minus the output resolution height.
  • The D25 cards can only handle a maximum of two UHD outputs.
Configuration
There are several settings necessary to enable the large canvas feature. These settings must be set directly in the Viz Engine configuration file (in %PROGRAMDATA%\vizrt\VizEngine).
  1. Write all related settings into the configuration file set VerboseConfig = 1, then start Viz Artist/Viz Engine once, and shut it down again.
  2. Set Matrox.LargeCanvasMode = 1 to enable the feature.
  3. Set the output format to USER DEFINED and the desired resolution using the dimensions and frequency of your video wall (for example, output_system = USER_DEFINED 7680 1080 50.00 0 0).
  4. Depending on the number of outputs required to cover the entire canvas, configure each in the following way (example):
    The output types must be set to IP, and the output content must be set to 1 (Program), for all needed output flows. Set the video system to the broadcast resolution required and the position of the upper left corner of the cutout. Numbers in configuration setting names correspond to the used Viz Engine output channel.
    • out_type1 = IP1
    • Output1.Content = 1
    • Matrox0.VideoOut1.CanvasVideoSystem = 1080P_5000_SMPTE424M
    • Matrox0.VideoOut1.CanvasHorizontalPosition = 0
    • Matrox0.VideoOut1.CanvasVerticalPosition = 0
  5. When using full resolution video walls it is recommended to set output_bpc = 10.
Important: Step 5 is mandatory for video walls running at 59.94 fps.
Key Output
Fill and Key output with large canvas is supported and enabled with the setting Matrox.LargeCanvas.ContainsAlpha = 1 in the configuration file. This enables a key signal on all IP output flows. The usual per-output alpha configuration is ignored. The key signal uses the same video system and canvas position as the associated fill.
Important: Only odd-numbered IP outputs can be used because the even-numbered connectors are used for the key signal. This affects all settings mentioned in the Configuration section.
Attention: The additional bandwidth required means that the overall resolution (numbers of pixels) of a fill and key system is limited to half of that of a fill-only system.
Supported Features
Feature
X.mio5 D25
DSX LE5 D25
DSX LE5 Q25
DSX LE6
Large Canvas support
✅ Yes
✅ Yes
✅ Yes
✅ Yes
Maximum canvas resolution
8192 × 4320
8192 × 4320
8192 × 4320
15360 × 2160
Wall orientation best suited
UHD / 16:9
Linear
UHD / 16:9
Linear
UHD / 16:9
Linear
Very wide / panoramic
Maximum number of Large Canvas outputs
8
8
8
8
UHD outputs in Large Canvas
2
2
4
4
Vertical UHD stacking
(2 × 2160 = 4320 px)
✅ Supported
✅ Supported
✅ Supported
❌ Not supported
(height limit 2160)
UHD 2×2 grid
(4 independent UHD outputs)
❌ Not supported
❌ Not supported
✅ Supported
❌ Not supported
Mixed HD / UHD on same canvas
✅ Yes
✅ Yes
✅ Yes
✅ Yes
Progressive outputs only
✅ Yes
✅ Yes
✅ Yes
✅ Yes
Broadcast resolutions only
✅ Yes
✅ Yes
✅ Yes
✅ Yes
Canvas geometry constraints
Width × 64
Even height
Same
Same
Same
Fill & Key with Large Canvas
✅ Yes
✅ Yes
✅ Yes
✅ Yes
Fill & Key impact
1 logical output = 2 flows (Fill + Key); halves the number of usable outputs
Same
Same
Same
