The Matrox DSX LE5 video board is an IP card supporting SMPTE ST 2110‑20/30/40 protocols. It is equipped with 25GbE SFP28 cages and is available in two models:
  • DSX LE5 Q25 — four (two dual) SFP28 cages, delivering an effective, fully redundant bandwidth of 50GbE, capable of providing four UHD inputs and outputs.
  • DSX LE5 D25 — two (one dual) SFP28 cages, delivering an effective, fully redundant bandwidth of 25GbE, capable of providing two UHD inputs and outputs.
Both models support 10GbE and 25GbE SFP28 transceivers. (The SFP+ form factor is identical to SFP28: SFP+ designates 10GbE, SFP28 designates 25GbE; both are compatible with the card.)
Key Features
  • Native SMPTE ST 2110 support with no CPU usage.
  • ST 2110‑21 packet pacing in hardware for narrow senders (Type N).
  • Wide asynchronous receivers (Type A).
  • Integrated hardware PTP for ST 2059‑2.
  • Built-in NMOS IS‑04 and IS‑05 support.
  • Genlock over IP (one genlock-over-IP setting per SFP, conforming to SMPTE ST 2059‑2).
Per-model capacity
DSX LE5 Q25
DSX LE5 D25
SFP28 cages
Four (two dual) — A/B/C/D
Two (one dual) — A/B
Effective redundant bandwidth
50 GbE
25 GbE
UHDp60/50 in & out
Up to four
Up to two
HD in & out (over 25GbE)
32
16
Audio flows
256
128
Ancillary-data connectors
1-64
1-32
Status LEDs
4
2
Power (with active transceivers)
38 W
34 W
SMPTE compliance
-10/-20/-21/-22/-30/-31/-40, ST 2059‑2, ST 2022‑7
identical
General Notes
  • The DSX LE5 is a full-height, ½-length PCIe Gen3 x16 card (x8 electrically) and uses a 16x PCIe slot. It can't use the same slot as an X.mio3.
  • To keep PTP stable, all Power Management options in Windows and BIOS must be disabled (Runtime power management disabled in BIOS settings).
  • Each SFP of a DSX LE5 board requires two IP addresses (one for the Matrox network adapter and one for genlock over IP). This is mandatory.
  • NTSC and PAL resolutions are not supported by the SMPTE ST 2110 standard.
  • UHD is only supported with 25GbE SFP cables; it is not possible with 10GbE SFP cables.
  • On the Q25, the second SFP pair (SFP C/D) provides connectors starting at video 17 / audio 129 / ancillary 33. See Explicit Usage of the Second SFP Pair. The D25 has only the first SFP pair (SFP A/B).
  • Changing a transceiver's speed (10GbE ↔ 25GbE), or fitting a 25GbE transceiver where none was present, requires a system restart (default link speed is 10GbE when no transceiver is connected).
ℹ️ Large Canvas Output: The Matrox DSX LE5 (both D25 and Q25) supports Large Canvas Output for SMPTE ST 2110‑driven video walls, with custom non‑broadcast canvas resolutions up to 8192 × 4320 pixels composed from up to eight progressive, broadcast‑resolution cutout flows. Appropriate output license(s) (4K, 8K, …) are required. See Large Canvas Output (Large Canvas Output for configuration details.
Matrox DSX LE5 IP Configuration
Please see section SMPTE ST 2110 Configuration for further details.
