1. What it is for
The Camera Stats overlay lets you watch the live values of the current camera in the Render Preview and follow how they change over time. Use it to check camera position, rotation, field of view, optical centre shift, focal distance and lens-distortion values, to compare a few of them side by side, and to save a recording for later analysis in a spreadsheet.
It appears only in the Render Preview and does not affect the captured or on-air output.
2. Quick start
Turn on “Camera Stats” in the Renderer Overlays menu (see section 3).
Click the value(s) you want to watch -- up to three (see section 5).
Switch on “Record” if you want to keep a long history (see section 7).
Click “Export CSV” to save the recording (see section 8).
3. Turning the overlay on
Open the Renderer Overlays menu -- the settings (gear) button in the Render Preview toolbar -- and tick Camera Stats. The Camera Stats window then appears in the preview. Untick the entry to hide it again.
The same menu also contains the other preview overlays (Renderer Performance, Tracking Timing, Center Shift Marker, Audio); you can turn Camera Stats on or off independently of those.
4. The window at a glance
The Camera Stats window opens on the left of the preview. At the top is a row of buttons, below it the current camera values, and at the bottom the graphs.
Button | What it does |
Record | Keeps a long history so you can scroll back and export it. See section 7. |
Maximize graph / Restore | Hides the value list so the graphs fill the whole window. Restore brings the values back. |
Export CSV | Saves the recording to a file. See section 8. |
5. Choosing which values to plot
The current camera values are listed in groups. Click a value to add it to the graphs; click it again to remove it. You can plot up to three values at the same time -- once three are selected, clicking another has no effect until you remove one. The value list is hidden while the graph is maximized.
Group | Values | Shows |
Position | X, Y, Z | where the camera is in the scene |
Rotation | Pan, Tilt, Twist | which way the camera is pointing |
Field of View | FOV X, FOV Y | horizontal and vertical field of view |
Center Shift | Shift X, Shift Y | optical centre shift of the lens |
Focal Distance | Focal Dist | the camera's focus distance |
Lens Distortion | K1, K2, Focus, Zoom | lens distortion values (listed only while a lens is active) |
6. Working with the graphs
Each value you pick gets its own graph, stacked one below the other. All graphs share the same time axis so they line up for easy comparison, and each one scales its height to its own values. When a value changes, its line updates live.
Use the controls above the graphs to change what you see:
Control | What it does |
Visible samples | Sets how much history is shown at once -- drag left to zoom in, right to zoom out. |
Follow latest | Keeps the newest data in view. It turns off by itself as soon as you scroll by hand. |
Drag in a graph | Drag left or right inside a graph to scroll back and forth through the history. |
Auto-scale Y | Fits each graph's height to the values on screen. Turn it off to set the range yourself with the slider that appears. |
Show delta | Adds a second, orange line showing how much the value changes from one moment to the next, on its own scale. |
7. Recording the history
The graphs always run live, showing the most recent activity. The Record button controls how far back the history reaches:
Record | History kept | When to use |
Off (default) | the last couple of minutes | Quick glance at what the camera is doing right now. |
On | a long recording | Capturing a take you want to review or export afterwards. A red REC marker is shown while recording. |
Turn Record on before the take you want to keep. If you turn it off again, only the recent live view is kept -- the longer recording is not retained.
8. Saving a recording (CSV)
Click Export CSV to save the recording to a file. A short message shows where the file was written; it disappears after a few seconds. The file has one row per recorded moment and opens directly in Excel, Google Sheets or any spreadsheet. It always uses a dot as the decimal separator, so it opens correctly whatever your regional settings are.
The file contains these columns, in order:
Time_ms, PosX, PosY, PosZ, Pan, Tilt, Twist, FovX, FovY,
CenterShiftX, CenterShiftY, FocalDistance,
LensK1, LensK2, LensFocus, LensZoom
The first column is the time in milliseconds; the rest are the recorded values. The lens columns are filled only for moments when a lens was active.
