Viz Engine with AJA Hardware supports up to two 3G-SDI inputs and fill/key output.
Overview and Connectors
AJA boards support current SD and HD SDI workflows with frame rates up to 50p/59.94p. Audio is supported as embedded signal in the SDI stream.
Configuration
IMPORTANT! For 1080p, only 3G Level A is supported.
Audio Configuration
Embedded audio is supported, always with 16 channels in and out. However, mixer settings are active, and respected. Example: if the user requests only two-channel output, the remaining 14 channels are silent.
Timecode
Viz Engine reads RP188 timecode embedded in the SDI input signal. Two conditions are evaluated from the board's RP188 DBB register: whether timecode is present in the input signal, and whether the board is configured to take the output timecode directly from the input. If the latter bypass is active, Viz Engine disables it so that the output carries Viz Engine's own timecode.
Video Configuration
The default configuration is:
Live Input 1 | SDI 1 |
Live Input 2 | SDI 2 |
Fill Output | SDI 3 |
Key Output | SDI 4 |
Genlock | [REF IN] |
If Live Input 2 is inactive in the configuration, SDI 2 is enabled for preview output.
Info: For 1080p, only one input is supported.
AJA KONA IP (J2K)
Viz Engine also detects AJA KONA IP boards with JPEG 2000 firmware and configures them automatically. Two variants are recognized:
1 input / 1 output (KONAIP_1RX_1TX_1SFP_J2K): SDI 1 is the input, SDI 2, 3 and 4 are outputs.
0 inputs / 2 outputs (KONAIP_2TX_1SFP_J2K): all four SDI connectors are outputs.
The topology is chosen from the board's device ID, so no extra configuration is required.
Configuration Utilities
Vizrt includes two configuration utilities from AJA:
cables.exe: This utility shows the current topology running: Inputs, outputs, color space conversion, fill and key paths. Firmware and driver version information are also accessible. Screen-shots of cables.exe use showing two typical topologies (two video inputs and one video and one preview) are shown below:
Example: Topology using two video inputs:
Example: One video input, one preview:
watcher.exe: This utility shows register settings. You may also write out a status log file. The auto-circulate engine is also observable. This utility is mostly of value for support specialists.
Firmware Upgrade
Only do an upgrade of Io4K firmware if instructed to do so by Vizrt or AJA support. All files for firmware upgrade are provided in a separate directory, typically supplied as a zip-archive. To install the firmware:
Open a command window.
cd to the directory where the firmware upgrade files are located. Make sure no other programs are running that could interfere with the firmware upgrade.
Install the firmware, in this example named IO_XT_4K_13.bit, using the ntv2firmwareinstaller utility (for example, ntv2firmwareinstaller -f IO_XT_4K_13.bit).
The window then pauses for a few minutes. When the firmware upgrade is complete, the command line program asks for a return key press to exit. Please be patient, the firmware upgrade can take three to six minutes (or more, depending on hardware configuration).
Power-cycle the Io4K and reboot the computer to make sure the upgraded firmware configuration is active.
Manufacturer’s documentation (external link at www.aja.com): AJA Io 4K
