This Administrator Guide gives details on the configuration and installation of Viz Engine. It also explains settings available through its configuration user interface.
The term Viz is used for the programs installed and run on the computer. This is used as a general reference for all modes of the program:
What mode of program that can run is determined from the hardware dongle that is attached to the actual machine (the different modes and the hardware dongle are detailed in this User Guide).
Related Documents
  • Viz Artist User Guide: Contains information on how to install Viz Engine and create graphics scenes in Viz Artist.
  • Viz Artist Script Reference: Contains information on how to create scripts for a scene. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-script-doc-webhelp.
  • Viz Engine Plug-in SDK Reference: Contains information on how to create a customized Viz plug-in. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-pluginsdk-doc-webhelp.
  • Viz Engine Command Reference: Contains information about Viz Engine Commands. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-cmd-doc-webhelp
Feedback and Suggestions
Copyright ©2026 Vizrt. All rights reserved.
Antivirus Considerations
