Recording
Create a clip with just video. Viz program output resolution is set to 576i25.
RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH --> wait until the flush has been executed RENDERER*VIDEO*CLIPOUT*1*CREATE VIDEO_SET 1 RENDERER*VIDEO*CLIPOUT*1*RESOLUTION VIDEO_SET 0 0 RENDERER*VIDEO*CLIPOUT*1*CONTAINER VIDEO_SET AVI RENDERER*VIDEO*CLIPOUT*1*CODEC VIDEO_SET DvCPro_411 RENDERER*VIDEO*CLIPOUT*1*NAME SET v:/clips/sample RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 100 --> wait until resording has finished 10 RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSHWe start with flushing the channel,
CONTROL FLUSH, to have a clean state.Then we tell the clip channel to create the video file,
VIDEO_SET 1.The clip resolution should match the output resolution,
RESOLUTION VIDEO_SET 0 0.Container is .avi,
CONTAINER VIDEO_SET AVI.And codec is dvcpro411,
CODEC VIDEO_SET DvCPro_411the codec requires no further options .Open the clip with
NAME SET v:/clips/sample.And record 100 frames,
CONTROL RECORD 100wait until all frames have been recorded.Close the clip,
CONTROL FLUSH.The resulting is a clip v:\clips\sample.avi.
Advanced Recording
Create a downscaled clip with video, separate key, audio, VBI and proxy. Viz Engine program output resolution is set to 1080i25.
RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH--> wait until the flush has been executedRENDERER*VIDEO*CLIPOUT*1*CREATE VIDEO_SET 1RENDERER*VIDEO*CLIPOUT*1*CREATE KEY_SET 1 RENDERER*VIDEO*CLIPOUT*1*CREATE AUDIO_SET 1 RENDERER*VIDEO*CLIPOUT*1*CREATE VBI_SET 1 RENDERER*VIDEO*CLIPOUT*1*CREATE PROXY_SET 1 RENDERER*VIDEO*CLIPOUT*1*RESOLUTION VIDEO_SET 2 0 RENDERER*VIDEO*CLIPOUT*1*CONTAINER VIDEO_SET XDCAM_MXF RENDERER*VIDEO*CLIPOUT*1*CODEC VIDEO_SET 27 RENDERER*VIDEO*CLIPOUT*1*CONTAINER AUDIO_SET W64 RENDERER*VIDEO*CLIPOUT*1*CONTAINER VBI_SET AVI RENDERER*VIDEO*CLIPOUT*1*CODEC VBI_SET YUYV422 RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET IFRAME bitrate=30 forceDCTFrame=0 RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET AUDIO ch=8 bits=24/32RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET VBI ON RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SETTCstartTC=11:00:00:00 RENDERER*VIDEO*CLIPOUT*1*RESOLUTION PROXY_SET 0 50 RENDERER*VIDEO*CLIPOUT*1*CONTAINER PROXY_SET QT_MOV RENDERER*VIDEO*CLIPOUT*1*CODEC PROXY_SET YUYV422 RENDERER*VIDEO*CLIPOUT*1*OPTION PROXY_SET AUDIO ON RENDERER*VIDEO*CLIPOUT*1*NAME SET v:\clips\advanced RENDERER*VIDEO*CLIPOUT*1*OPTION PROXY_SET QTCODEC SVQ3 RENDERER*VIDEO*CLIPOUT*1*OPTION PROXY_SET QTVIDEO average_data_rate=0 quality=512 RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 1000 --> wait until finished RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSHStart with flushing the channel,
CONTROL FLUSH, to have a clean state.Tell the clip channel to create the video, key, audio, VBI and proxy files:
VIDEO_SET 1KEY_SET 1AUDIO_SET 1VBI_SET 1PROXY_SET 1
The resolution should be SD 16:9,
RESOLUTION VIDEO_SET 2 0.The video and key files should be D10 files.
CONTAINER VIDEO_SET XDCAM_MXFCODEC VIDEO_SET 27
Since we want separate audio we need to specify the audio container,
CONTAINER AUDIO_SET W64.Same applies for VBI:
CONTAINER VBI_SET AVICODEC VBI_SET YUYV422
Set the D10 Iframe options,
OPTION VIDEO_SET IFRAME bitrate=30 forceDCTFrame=0.Audio configuration,
OPTION VIDEO_SET AUDIO ch=8 bits=24/32.And VBI configuration,
OPTION VIDEO_SET VBI ON.The MXF file allows to carry time code information,
OPTION VIDEO_SETTCstartTC=11:00:00:00.
This finishes setup of the hires part, next is the proxy configuration.
The proxy should be scaled to 50%,
RESOLUTION PROXY_SET 0 50.Container is QT mov,
CONTAINER PROXY_SET QT_MOV.Codec needs to be set to uncompressed,
CODEC PROXY_SET YUYV422.Audio should be included in the proxy, too,
OPTION PROXY_SET AUDIO ON.
Before we can setup the proxy QT options we need to open the clips:
Open the clip,
NAME SET v:/clips/advanced.Then set the proxy QT codec,
OPTION PROXY_SET QTCODEC SVQ3.And the proxy QT options,
OPTION PROXY_SET QTVIDEO average_data_rate=0 quality=512.Record some frames,
CONTROL RECORD 1000and wait until they are recorded.Close the clip,
CONTROL FLUSH.The resulting clips are:
v:\clips\advanced.d10.mxf (SD 576i with fill)
v:\clips\advanced_key.d10.mxf (SD 576i with key)
v:\clips\advanced_vbi.avi (HD1080i with VBI)
v:\clips\advanced_proxy.mov (proxy with video and audio)
Create Clips with Stage Events Example
This example creates a reference clip and uses stage events to start the recording. It contains various counters and a timecode. It has the capability for audio and video as well. Let’s take a look at each step involved first.
Enable Feedback
FEEDBACK*CLIENT ADD localhost 2001 FEEDBACK*COMMAND ADD localhost 2001 CLIPOUTAt first we enable the feedback channel to send UDP packets to localhost. Now we are ready to initialize the clip channels and the renderer:
Cleanup Clip Out and Clip In Channels
RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH RENDERER*BACK_LAYER*STAGE STOP RENDERER*MAIN_LAYER*STAGE STOP RENDERER*FRONT_LAYER*STAGE STOP RENDERER*VIDEO*CLIPIN*1*CONTROL FLUSH Flush any clips in the clip in and clip out channel. Since the flush command needs to travel through the ringbuffer we need to wait a few frames until they have been executed.
Cleanup Renderer
RENDERER*BACK_LAYER SET_OBJECTRENDERER*MAIN_LAYER SET_OBJECT RENDERER*FRONT_LAYER SET_OBJECTPOOLS CLEANUPUnload scenes from the renderer and cleanup all pools. We want to start with a fresh environment here.
Set Up Stage Start Event
STAGE_EVENTS*STAGE_START CLEAR STAGE_EVENTS*STAGE_START ADD "RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 5000" -1STAGE_EVENTS*STAGE_START GETEnable the Stage Start event to trigger the record command on the clip out channel.
Load Scenes And Set Audio And Video Clips
<! - - load background scene -->SCENE*Vizrt_Research_Developement/Reference/TC/bg LOAD SCENE*Vizrt_Research_Developement/Reference/TC/bg*STAGE*DIRECTOR*Director*KEY*$audioclip*CLIP SET "<11EBC981-11A3-45C7-A78545119738FC68>"SCENE*Vizrt_Research_Developement/Reference/TC/bg*VIDEO*CLIPIN*1*TARGET SET DVE SCENE*Vizrt_Research_Developement/Reference/TC/bg*STAGE*DIRECTOR*Director*KEY*$videoclip*CLIPNAME SET "e:/out/1080_bgclip.m4v" SCENE*Vizrt_Research_Developement/Reference/TC/bg*STAGE*DIRECTOR*Director*KEY*$videoclip*START SET "00:00:00:00" SCENE*Vizrt_Research_Developement/Reference/TC/TC_DISPLAY LOADThis loads the background scene, and sets the audio clip and the video clip. The scene for the main layer is also loaded here.
Cue Scenes
SCENE*Vizrt_Research_Developement/Reference/TC/bg CUESCENE*Vizrt_Research_Developement/Reference/TC/TC_DISPLAY CUEBoth scenes are cued. This is required for frame accurate clip playback.
Load Scenes Into Renderer
RENDERER*BACK_LAYER SET_OBJECT Vizrt_Research_Developement/Reference/TC/bg RENDERER*MAIN_LAYER SET_OBJECT Vizrt_Research_Developement/Reference/TC/TC_DISPLAYThe scenes are loaded into the back layer and main layer.
Reset Animation Timelines
RENDERER*BACK_LAYER*STAGE SHOW 0.0 RENDERER*MAIN_LAYER*STAGE SHOW 0.0The timelines for back and main layers are reset to zero. Now we are ready to configure the clip out channel.
Configure Clip Out Channel
RENDERER*MAIN_LAYER*TREE*$UserData$Label*GEOM*TEXT SET 1080i XDCAM_MXF422, Audio=8 ch RENDERER*VIDEO*CLIPOUT*1*CREATE VIDEO_SET On RENDERER*VIDEO*CLIPOUT*1*RESOLUTION VIDEO_SET 0 0 RENDERER*VIDEO*CLIPOUT*1*CONTAINER VIDEO_SET XDCAM_MXF RENDERER*VIDEO*CLIPOUT*1*CODEC VIDEO_SET 22 RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET AUDIO ch=8 RENDERER*VIDEO*CLIPOUT*1*NAME SET "d:/1080i_3in" 5.0The first line sets a text container in the main layer with some descriptive information. The following lines configure the clip out channel and on the last line open the clip.
Start The Animation
RENDERER*BACK_LAYER*STAGE START RENDERER*MAIN_LAYER*STAGE STARTThis starts the animation on both layers. The stage start event trigger fires and the recording starts.
Close Clip
After the recording of the predetermined number of frames has been finished (can be observed on the feedback channel) we close the clip:
RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSHWe have now recorded a clip with 5000 frames in XDCAMHD422 format in an MXF container.
Render a Playlist
Recent additions to Viz Artist ease rendering a complete playlist into separate clips. This example guides through those new features. First we need to prepare some steps in the configuration file.
Default Profile
First, we create default profile that we can load with a single command. In This profile we make use of the placeholders for the name of the clip. This is under the section CHANNELS_CONFIG in the configuration file.
# the <self> placeholder gets replaced with the proper RENDERER*VIDEO*CLIPOUT*1ClipOut1.profile.default_1=<self>*CREATE VIDEO_SET On ClipOut1.profile.default_2=<self>*RESOLUTION VIDEO_SET 0 0 ClipOut1.profile.default_3=<self>*CONTAINER VIDEO_SET XDCAM_MXF ClipOut1.profile.default_4=<self>*CODEC VIDEO_SET 22*ClipOut1.profile.default_5=<self>*OPTION VIDEO_SET AUDIO ch=8 ClipOut1.profile.default_6=<self>*OPTION VIDEO_SET TC startTC=10:00:00:00 # we make use of three placeholders.one is the clip root.the others are # for the scene name to be set and clip placeholder name itself # that gets set with RENDERER*VIDEO*CLIPOUT*1*NAME PLACEHOLDER_SET ClipOut1.profile.default_7=<self>*NAME SET <clip_root> playlist/<base_scene2_name>/<clip_name>Scene Load Interceptor
The profile that we created in the previous section should always be applied when we change the scene. To be more specific we want it to be applied right before when a scene gets loaded into the render editor but before it is actually loaded. We make use of the command injector on the scene load interceptor on the MAIN_LAYER.
RENDERER*MAIN_LAYER CLEAR_INJECT_BEFORE RENDERER*MAIN_LAYER ADD_INJECT_BEFORE "RENDERER*VIDEO*CLIPOUT*1*PROFILE APPLY" -1Stage Interceptors
The Stage events have been already introduced above. Here we make use of them again but this time bound only onto the MAIN_LAYER. When the animation starts then an infinite record command is set to the clip out channel. When the animation stops the clip is flushed and hence properly closed.
STAGE_EVENTS*LAYER_STAGE_START CLEAR MAIN_LAYERSTAGE_EVENTS*LAYER_STAGE_STOP CLEAR MAIN_LAYERSTAGE_EVENTS*LAYER_STAGE_START ADD MAIN_LAYER "RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 0" -1 STAGE_EVENTS*LAYER_STAGE_STOP ADD MAIN_LAYER "RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH " -1Startup Commands
The Interceptors are not part of a scene or the configuration file. They need to be applied once. So we just bundle them together in the startup commands section together with the activation of the feedback channel. The feedback channel commands make only sense if the controlling application resides on the localhost. Otherwise, replace localhost with the name of the host where the UDP feedback should be directed at or leave them out of the startup commands.
# scene load interceptor StartupCommands_1= RENDERER*MAIN_LAYER CLEAR_INJECT_BEFORE StartupCommands_2= RENDERER*MAIN_LAYER ADD_INJECT_BEFORE "RENDERER*VIDEO*CLIPOUT*1*PROFILE APPLY" -1 # stage main layer interceptor StartupCommands_3= STAGE_EVENTS*LAYER_STAGE_START CLEAR MAIN_LAYER StartupCommands_4= STAGE_EVENTS*LAYER_STAGE_STOP CLEAR MAIN_LAYER StartupCommands_5= STAGE_EVENTS*LAYER_STAGE_START ADD MAIN_LAYER "RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 0" -1 StartupCommands_6= STAGE_EVENTS*LAYER_STAGE_STOP ADD MAIN_LAYER "RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH " -1# feedback channel StartupCommands_7= FEEDBACK*CLIENT ADD localhost 2001 StartupCommands_8= FEEDBACK*COMMAND ADD localhost 2001 CLIPOUTReady to Render The Playlist
Load the scenes into Viz Engine and cue them.
SCENE*Vizrt_RD*/tmp/n1 LOAD SCENE*Vizrt_RD*/tmp/n1 CUE SCENE*Vizrt_RD*/tmp/n1*STAGE SHOW 0.0 SCENE*Vizrt_RD*/tmp/n2 LOAD SCENE*Vizrt_RD*/tmp/n2 CUE SCENE*Vizrt_RD*/tmp/n2*STAGE SHOW 0.0 SCENE*Vizrt_RD*/tmp/n3 LOAD SCENE*Vizrt_RD*/tmp/n3 CUE SCENE*Vizrt_RD*/tmp/n3*STAGE SHOW 0.0After that the scenes are ready to be put into the render editor. Now let’s set the placeholder for the clipname and render the first clip.
RENDERER*VIDEO*CLIPOUT*1*NAME PLACEHOLDER_SET "heidi_1" SCENE*Vizrt_RD/tmp/n1*STAGE SHOW 0.0 RENDERER*MAIN_LAYER SET_OBJECT Vizrt_RD/tmp/n1This triggers the scene load command injector that executes the RENDERER*VIDEO*CLIPOUT*1*PROFILE APPLY which in turn loads the profile and applies it to the clip out channel.
RENDERER*VIDEO*CLIPOUT*1*CREATE VIDEO_SET On RENDERER*VIDEO*CLIPOUT*1*RESOLUTION VIDEO_SET 0 0 RENDERER*VIDEO*CLIPOUT*1*CONTAINER VIDEO_SET XDCAM_MXF RENDERER*VIDEO*CLIPOUT*1*CODEC VIDEO_SET 22 RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET AUDIO ch=8 RENDERER*VIDEO*CLIPOUT*1*OPTION VIDEO_SET TC startTC=10:00:00:00 RENDERER*VIDEO*CLIPOUT*1*NAME SET <clip_root>playlist/<base_scene2_name>/<clip_name>assuming that is set v:/clips/out/, then the clip name is expanded to v:/clips/out/playlist/n1/heidi_1.xdcamHD422.mxf. The next step is to start the animation. This triggers the stage start command injector.
RENDERER*MAIN_LAYER*STAGE STARTWhich, in turn, triggers the stage start command injector.
RENDERER*VIDEO*CLIPOUT*1*CONTROL RECORD 0Now the controlling application watches the feedback channel it subscribed to before:
CLIPOUT [0] OPEN CLIP=’v:/clips/out/playlist/n1/heidi_1’ VIDEO=1 (v:/clips/out/playlist/n1/heidi_1.xdcamHD422.mxf,,) AUDIO=1 () VBI=0 () TC=0CLIPOUT [0] START REQ=0 CLIPOUT [0] WRITE REC=64 TOT=64 CLIPOUT [0] WRITE REC=128 TOT=128 CLIPOUT [0] WRITE REC=192 TOT=192 CLIPOUT [0] WRITE REC=256 TOT=256 CLIPOUT [0] WRITE REC=320 TOT=320 CLIPOUT [0] WRITE REC=384 TOT=384 CLIPOUT [0] WRITE REC=448 TOT=448 CLIPOUT [0] WRITE REC=512 TOT=512 CLIPOUT [0] STOP CLIP= ’v:/clips/out/playlist/n1/heidi_1’ REC=550 TOT=550 CLIPOUT [0] FLUSH CLIP=’v:/clips/out/playlist/n1/heidi_1’ TOT=550as we can see in the feedback messages there are also STOP and FLUSH commands. Once the animation stops the stage stop command injector kicks in.
RENDERER*VIDEO*CLIPOUT*1*CONTROL FLUSH 0This command stops and flushes the clip. Now we can repeat with rendering the next clip until the playlist is completed.
