The Matrox DSX LE6 video board is the next generation IP card supporting SMPTE ST 2110-20/30/40 protocols. It is equipped with two (one dual) QSFP28 cages in which to connect QSFP28 transceivers. Only 100GbE transceivers are supported.
Key Features
Native SMPTE ST 2110 supports over 100 GbE with no CPU usage.
Up to eight UHDp60/50 inputs and outputs over 100GbE.
ST 2110-21 packet pacing in hardware for narrow senders (Type N).
Wide asynchronous receivers (Type A).
16x HD inputs and outputs over 100GbE.
128 audio flows from one to 64 tracks.
Integrated hardware PTP for ST 2059-2.
Built in NMOS IS-04 and IS-05 support.
UHD-2 support will come with future Matrox driver versions.
General Notes
Please be aware that a DSX LE6 uses a 16x PCIe slot. It cannot use the same slot as an X.mio3.
To make sure the PTP is stable, all Power Management options in Windows and BIOS need to be disabled (Runtime power management disabled in BIOS settings).
Each SFP of a DSX LE6 board requires two IP addresses. This is mandatory.
NTSC and PAL resolutions are not supported by the SMPTE ST 2110 standard.
