This Administrator Guide gives details on the configuration and installation of Viz Engine. It also explains settings available through its configuration user interface.
The term Viz is used for the programs installed and run on the computer. This is used as a general reference for all modes of the program:
Viz Artist (see the Viz Artist User Guide)
Viz Engine
Viz Configuration
What mode of program that can run is determined from the hardware dongle that is attached to the actual machine (the different modes and the hardware dongle are detailed in this User Guide).
Related Documents
Viz Artist User Guide: Contains information on how to install Viz Engine and create graphics scenes in Viz Artist.
Viz Artist Script Reference: Contains information on how to create scripts for a scene. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-script-doc-webhelp.
Viz Engine Plug-in SDK Reference: Contains information on how to create a customized Viz plug-in. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-pluginsdk-doc-webhelp.
Viz Engine Command Reference: Contains information about Viz Engine Commands. This is installed locally at C:\Program Files\Vizrt\VizEngine\Documentation\viz-cmd-doc-webhelp
Feedback and Suggestions
Legal
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
