Slot/Card Installation
Default Hardware
Single CPU 20-Cores
Dual redundant Power Supply
1125/1450W Platinum redundant, hot-swap
PCIe Gen4 + Gen5 Slots
8 PCIe Slots
64GB DDR5
1x 512GB M.2 + 1x 1TB M.2
2x Gbit RJ45 onboard
OS Support:
Windows 10 LTSC 2021
Windows 11 LTSC 2024
GPU Support:
A2000
A4000
A5000
A6000
4000 Ada
5000 Ada
6000 Ada
PCI Configuration
Slot | Usage |
Slot 1 Gen5 x16 | Second Graphics Card (no Monitor) |
Slot 2 Gen5 x4 | Free or used by Dual Slot GPU |
Slot 3 Gen5 x16 | First Graphics Card (with Monitor) |
Slot 4 Gen4 x4 (PCH) | Free or used by Dual Slot GPU |
Slot 5 Gen4 x16 | Matrox Video Card (X.mio3, X.mio5, DSX LE4) |
Slot 6 Gen3 x8 | Empty |
Slot 7 Gen4 x16 | Matrox M264 or other Expansion Card (Serial, GPI) |
Slot 8 Gen4 x4 (PCH) | Other Expansion Card (Serial, GPI) |
Bios Settings
Security/Secure Boot Configuration Secure Boot: Enable
Advanced/Built-In Device Options:
Increase PCIe Idle Fan Speed(%): 50
PCIe Idle Fan Tracking mode: Enable
Advanced/Power Management Options:
Hardware P-States: Disable
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced/Performance Options:
Workload Configuration: I/O-Focused
Advanced/Power Supply Options:
Power Supply Mode: Redundant
