Daily Log (As Run)
For information and troubleshooting purposes, a daily log file provides details on every event that was played. The file is located on the Media Sequencer machine at: %ProgramData%\Vizrt\Media Sequencer
. Since the file is not set up as part of the installation process, it must be created as part of the installation process described in the Playout section.
The logging file naming convention is ChannelName-YY-MM-DD.log
. Each file includes the events played on the calendar day specified, which may not necessarily correspond to a playlist. As such, the events in a playlist that starts at 7 AM and extends till the following day at 6 AM will be saved in two separate files - one for each calendar day.
A posssible example of a log file’s contents is shown below:
2007
12
18
12
06
36
: Running: read on /ChannelBranding/channels/AD/playlists/continuous/elements/PLAYLIST_DATA_ROMY_14_24_40_681_13_12_2007_823_IM_0
2007
12
18
12
06
41
2007
12
18
12
07
15
: Running: read on /ChannelBranding/channels/AD/playlists/continuous/elements/PLAYLIST_DATA_ROMY_12_06_58_663_18_12_2007_22_PA_0
2007
12
18
12
08
28
2007
12
18
12
09
34
2007
12
18
12
09
39
2007
12
18
12
09
46
2007
12
18
12
16
50
: Running: read on /ChannelBranding/channels/AD/playlists/continuous/elements/PLAYLIST_DATA_ROMY_14_24_40_759_13_12_2007_715_IM_2
2007
12
18
12
16
53
: Running: read on /ChannelBranding/channels/AD/playlists/continuous/elements/PLAYLIST_DATA_ROMY_12_16_29_344_18_12_2007_319_DR_0
Log File Locations
As explained above, all log files in the list below are relative to the log file base directory of C:\ProgramData\Vizrt\Viz Channel Branding\
Viz Channel Branding Client: .\Client\
Playlist Importer : .\Playlist Importer\
Upgrade Tool: .\Upgrade Tool\
Harris Integration Module: .\Harris Integration\
Pebble Beach Marina Integration Module: .\Marina Integration\
Pebble Beach Neptune Integration Module: .\Neptune Integration\
Promo Server: No log-file on disk, use Windows Event Viewer
Integrations Hub: No log-file on disk, use Windows Event Viewer
Warning: Care should be taken to set up automatic tasks or manual routines to prune or delete old log files that are no longer needed, otherwise the log files could eventually fill the disk.
