The Matrox X.mio series cards all support a selection of different codecs for both SD and HD. Certain codecs require certain card classes. Depending on the card class, a license upgrade may be required to extend the range of codecs supported by the installed video card. The Matrox video cards have a built-in license dongle used by the Matrox codecs to determine licensing rights.
For the Matrox topology based video cards, the following classes apply:
100 class: No clip playback.
500 class: SD and HD clip playback.
550 class: SD and HD clip playback, including support for Apple ProRes codecs.
For UHD playback a M264 board is highly recommended or mandatory for some codecs.
All codecs are implemented in the software.
Viz Engine uses Matrox hardware to utilize QuickTime codecs for clip playback and post-rendering with MatroxFileWriter and ClipOut channel.
The following QuickTime codecs are supported:
Matrox cards support the following codec types and formats:
Container | Codec | Features | Audio |
.avi | MPEG2-IFrame422 720x576 | Alpha: no Bitrate: 10-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame4224 720x576 | Alpha: yes Bitrate: 10-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP SD 4:2:0, itemary, Program, Transport720x576 | Alpha: no Bitrate: 1-15 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP SD 4:2:2, itemary, Program, Transport720x576 | Alpha: no Bitrate: 5-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf | MPEG2 IBP SD 4:2:0, itemary, Program, Transport720x576 | Alpha: no Bitrate: 1-15 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf | MPEG2 IBP SD 4:2:2, itemary, Program, Transport720x576 | Alpha: no Bitrate: 5-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MJPEG Lossless 720x576 | Alpha: no Bitrate: 160 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DV/DVCAM 4:2:0 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DVCAM 4:2:0 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCAM 4:2:0 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | DVCAM 4:2:0 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.avi | DVCPRO 4:1:1 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DVCPRO 50 4:2:2 720x576 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DVCPRO 4:1:1 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.dv | DVCPRO 50 4:2:2 720x576 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCPRO 4:1:1 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | DVCPRO 50 4:2:2 720x576 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | DVCPRO 4:1:1 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | DVCPRO 50 4:2:2 720x576 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf Panasonic P2 (OP-Atom) | DVCPRO 4:1:1 720x576 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf Panasonic P2 (OP-Atom) | DVCPRO 50 4:2:2 720x576 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf XDCAM (OP1a) | D10 (IMX) 4:2:2 720x608 | Alpha: no Bitrate: 50 Bitdepth: 10 VBI: required Timecode: required TDIR: no | AES3 |
.mov | H.264/AVC 720x576 | Alpha: no Bitrate: VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | ProRes 422 720x576 | Alpha: no Bitrate: 42 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | ProRes 422 HQ 720x576 | Alpha: no Bitrate: 42 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUVU 4:2:2 720x576 | Alpha: no Bitrate: 160 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUAVUA 4:2:2:4 720x576 | Alpha: yes Bitrate: 240 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame422 720x480 | Alpha: no Bitrate: 10-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame4224 720x480 | Alpha: yes Bitrate: 10-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP SD 4:2:0, itemary, Program, Transport 720x480 | Alpha: no Bitrate: 1-15 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP SD 4:2:2, itemary, Program, Transport 720x480 | Alpha: no Bitrate: 5-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2 IBP SD 4:2:0, itemary, Program, Transport 720x480 | Alpha: no Bitrate: 1-15 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2 IBP SD 4:2:2, itemary, Program, Transport 720x480 | Alpha: no Bitrate: 5-50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MJPEG Lossless 720x480 | Alpha: no Bitrate: VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DV/DVCAM 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DV/DVCAM 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCAM 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kH 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | DVCAM 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mxf Panasonic P2 (OP-Atom) | DV/DVCAM 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.avi | DVCPRO 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DVCPRO 50 4:2:2 720x480 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DVCPRO 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.dv | DVCPRO 50 4:2:2 720x480 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCPRO 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | DVCPRO 50 4:2:2 720x480 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf | DVCPRO 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf | DVCPRO 50 4:2:2 720x480 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf Panasonic P2 (OP-Atom) | DVCPRO 4:1:1 720x480 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf Panasonic P2 (OP-Atom) | DVCPRO 50 4:2:2 720x480 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf XDCAM (OP1a) | D10 (IMX) 4:2:2 720x512 | Alpha: no Bitrate: 30, 40, 50 Bitdepth: 10 VBI: required Timecode: required TDIR: no | AES3 |
.mov | H.264/AVC720x480 | Alpha: no Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | ProRes 422 720x486 | Alpha: no Bitrate: 42 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | ProRes 422 HQ720x486 | Alpha: no Bitrate: 63 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUVU 4:2:2 720x480 | Alpha: no Bitrate: 160 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUAVUA 4:2:2:4 720x480 | Alpha: yes Bitrate: 240 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame422 1280x720 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame4224 1280x720 | Alpha: yes Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP HD 4:2:0, itemary, Program, Transport1280x720 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP HD 4:2:2, itemary, Program, Transport1280x720 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2, IBP HD 4:2:0, itemary, Program, Transport1280x720 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2, IBP HD 4:2:2, itemary, Program, Transport1280x720 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DVCPRO HD1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DVCPRO HD1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCPRO HD1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | DVCPRO HD1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf Panasonic P2 (OP-Atom) | DVCPRO HD1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mov | HDV1280x720 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | XDCam EX 1280x720 | Alpha: no Bitrate: 25 CBR, 35 VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | XDCam HD 4221280x720 | Alpha: no Bitrate: 18-35 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mp4 | XDCam EX 1280x720 | Alpha: no Bitrate: 25 CBR, 35 VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf XDCAM (OP1a) | XDCAM HD, IBP HD 4:2:0,itemary, Program, Transport 1280x720 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: |
.mxf XDCAM (OP1a) | XDCAM HD422, IBP HD 4:2:2, 1280x720 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | PCM: |
.mxf (OP-Atom) | DNxHD 145, 220, 220x 1280x720 | Alpha: yes (except 220x) Bitrate: 100 Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio |
.mxf (OP1a) | DNxHD 145, 220, 220x 1280x720 | Alpha: yes (except 220x) Bitrate: 100 Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | DNxHD 4:2:2 1280x720 | Alpha: no Bitrate: 36, 145, 220 Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | AVCIntra Class 50 1280x720 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | AVCIntra Class 100 1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 50 1280x720 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 100 1280x720 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mov | H.264/AVC 1280x720 | Alpha: no Bitrate: VBR Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mp4 | XDCAM EX 1280x720 | Alpha: no Bitrate: VBR Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:2:2 1280x720 | Alpha: no Bitrate: 100 (LT), 147, 220 (HQ) Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:4:4:4 1280x720 | Alpha: yes Bitrate: VBR Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUVU 4:2:2 1280x720 | Alpha: no Bitrate: 700 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUAVUA 4:2:2:4 1280x720 | Alpha: yes Bitrate: 1050 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame422 1920x1080 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame4224 1920x1080 | Alpha: yes Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP HD 4:2:0, itemary, Program, Transport1920x1080 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2 IBP HD 4:2:2, itemary, Program, Transport1920x1080 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2, IBP HD 4:2:0, itemary, Program, Transport1920x1080 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | MPEG2, IBP HD 4:2:2, itemary, Program, Transport1920x1080 | Alpha: no Bitrate: 50-300 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | DVCPRO HD1920x1080 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.dv | DVCPRO HD1920x1080 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: |
.mov | DVCPRO HD1440x1080 | Alpha: no Bitrate: 100 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP-Atom) | DVCPRO HD1440x1080 | Alpha: no Bitrate: 100 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf (OP1a) | DVCPRO HD1440x1080 | Alpha: no Bitrate: 100 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | HDV1440x1080 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | XDCam EX1920x1080 | Alpha: no Bitrate: 25 CBR, 35 VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | XDCam HD1440x1080 | Alpha: no Bitrate: 35 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | XDCam HD 4221920x1080 | Alpha: no Bitrate: 18-35 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mp4 | XDCam EX 1920x1080 | Alpha: no Bitrate: 25CBR, 35VBR Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mp4 | XDCAM EX1920x1080 | Alpha: no Bitrate: VBR Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | XDCAM HD,IBP HD 4:2:0,itemary,Program,Transport 1920x1080 | Alpha: no Bitrate: 25 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: |
.mxf (OP-Atom) | DNxHD 145, 220, 220x, 1920x1080 | Alpha: yes (for 220) Bitrate: 100 Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio |
.mxf (OP1a) | DNxHD 145, 220, 220x, 1920x1080 | Alpha: yes (for 220) Bitrate: 100 Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP-Atom) | AVCIntra Class 50 1440x1080 | Alpha: no Bitrate: 50 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf (OP-Atom) | AVCIntra Class 100 1920x1080 | Alpha: no Bitrate: 100 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio |
.mxf (OP1a) | AVCIntra Class 50 1440x1080 | Alpha: no Bitrate: 50 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mxf (OP1a) | AVCIntra Class 100 1920x1080 | Alpha: no Bitrate: 100 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | H.264/AVC 1920x1080 | Alpha: no Bitrate: VBR Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:2:2 1920x1080 | Alpha: no Bitrate: 100 (LT), 147, 220 (HQ) Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:4:4:4 1920x1080 | Alpha: yes Bitrate: VBR Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUVU 4:2:2 1920x1080 | Alpha: no Bitrate: 800 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUAVUA 4:2:2:4 1920x1080 | Alpha: yes Bitrate: 1200 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | H.264/AVC 1920x1080 | Alpha: no Bitrate: 50/100 Bitdepth: 8; 10 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:2:2 1920x1080 | Alpha: no Bitrate: 147, 220 Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame422 3840x2160 | Alpha: no Bitrate: 900-1200 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | MPEG2-IFrame4224 3840x2160 | Alpha: yes Bitrate: 900-1200 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:2:2 3840x2160 | Alpha: no Bitrate: VBR Bitdepth: 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.mov | I-Frame 4:4:4:4 3840x2160 | Alpha: yes Bitrate: VBR Bitdepth: 8, 10 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
.avi | Uncompressed YUVU 4:2:2 1920x1080 | Alpha: no Bitrate: 800 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 16,24 bit; 48kHz 4 ch: 16,24 bit; 48kHz 8 ch: 16,24bit; 48kHz 16 ch: 16,24; 48kHz
.avi | Uncompressed YUAVUA 4:2:2:4 1920x1080 | Alpha: yes Bitrate: 1200 Bitdepth: 8 VBI: N/A Timecode: N/A TDIR: no | No Audio PCM: 2 ch: 16,24 bit; 48kHz 4 ch: 16,24 bit; 48kHz 8 ch: 16,24bit; 48kHz 16 ch: 16,24; 48kHz
.mxf (OP1a) | H.264 level 5.2, 3840x2160 | Alpha: no Bitrate: 960 Bitdepth: 8, 10, 12 VBI: yes Timecode: yes TDIR: yes | No Audio PCM: 2 ch: 24 in 32-bit; 48kHz 4 ch: 24 in 32-bit; 48kHz 8 ch: 24 in 32-bit; 48kHz 16 ch: 24 in 32-bit; 48kHz
