General Shortcuts
Function | Default Key and/or Mouse Shortcut | Configurable |
Moves to Top Container | HOME | |
Moves to Last Container | END | |
Moves to top of page | PAGE UP | |
Moves to bottom of page | PAGE DOWN | |
Scrolls up the Container list | UP ARROW (↑) | |
Scrolls down the Container list | DOWN ARROW (↓) | |
Opens Container tree | RIGHT ARROW (→) | |
Closes Container tree | LEFT ARROW (←) | |
Opens plug-in panel | + |
Basic View Controls and Shortcuts
Inserts New Container | CTRL + INSERT (The new Container is created above the first selected Container.) | |
Rename Container | F2 | |
Multiselects Containers | CTRL + Left click | |
Deletes selected Container(s) | CTRL + DELETE | |
Opens whole Tree | CTRL + O | |
Opens Subtree | ALT + + | |
ALT + RIGHT | ||
Collapses whole Tree | CTRL + I | |
Collapses Subtree | ALT + - | |
ALT + LEFT | ||
Locks selected Container(s) | CTRL + L | |
Unlocks selected Container(s) | CTRL + SHIFT + L | |
Groups selected Container(s) | CTRL + G | |
Ungroups selected Container(s) | CTRL + SHIFT + G | |
Hides selected Container(s) | CTRL + H | |
Shows selected Container(s) | CTRL + SHIFT + H | |
Searches Container | CTRL + F | |
Copies selected Container(s) | CTRL + Left click on container name and drag | |
Copies selected Container(s) to Clipboard | CTRL + C | |
Pastes Containers from Clipboard | CTRL + V (They are created one hierarchical level underneath selected container.) | |
Cuts selected Container(s) | CTRL + X | |
Moves selected Container(s) | Left click on container name and drag | |
Moves selected Container and retain transformation properties | ALT + Left click on container name and drag | |
Copies Properties of Container | Left click on container Properties and drag | |
Merges Group | CTRL + M | |
Splits Container | CTRL + SHIFT + M | |
Convert to Dynamic Geometry | CTRL + D |
Plug-in Overlay
Function | Key and/or Mouse Shortcut | Configurable |
Opens plug-in Panel | + | |
Selects plug-in | Cursor Keys | |
Selects plug-in and applies to selected container(s) | ENTER | |
Leaves plug-in Overlay | ESC | |
