Chroma Keyer
This Shader clear regions in a video defined by a color. The color-space of this Shader is YUV, which is defined as following:
The luminance (Y) component determines the brightness of the color, while the U and V components determine the color itself (the chroma). Luminance (Y) ranges from 0.0 (dark) to 1.0 (bright). U and V ranges from -0.5 to 0.5.
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Chroma Keyer Properties
Video: Sets the input video channel for keying. Be sure that for the set video channel the “Keying Mode” has been set to M-Zone (see Keying Mode).
Blend: Sets the alpha for the key signal
Fit: Select Screen or Object
Invert: Flips the key signal.
Sampling Filter
Nearest: Color information is taken from one pixel.
1D-Filter: Color information is taken after applying a 1D-linear filter.
2D-Filter: Color information is taken after applying a 2D-linear filter.
Luminance: Sets the luminance.
Basic parameters for first method:
HueAngle: Selects the color to key in YUV space.
OpeningAngle: Tolerance for the color in YUV space.
KeyGain: Gradient for borders to neighboring colors (1=soft, 10=sharp).
SatMin: Lower saturation limit for keyed colors.
SatMinGrad: Gradient for lower saturation limit (0=sharp, 1=soft).
SatMax: Upper saturation limit for keyed colors.
SatMaxGrad: Gradient for upper saturation limit (0=sharp, 1=soft).
Basic parameters for second method:
U-Color: U-value for color keying.
V-Color: V-value for color keying.
UV-Diameter: All colors between the reference UV and this diameter will be removed.
UVGradient: Gradient for fade out at diameter border (0=sharp, 1=soft).
Removing keying from Highlights and Shadows:
LumMin: Lower luminance limit for keyed colors.
LumMinGrad: Gradient for lower luminance limit (0=sharp, 1=soft).
LumMax: Upper luminance limit for keyed colors.
LumMaxGrad: Gradient for upper luminance limit (0=sharp, 1=soft).
Sampling reference point:
UVRangeCheck: This option can be used to get an information of the sampled color
URangeMin: Defines the minimum UColor that should be accepted
URangeMax: Defines the minimum UColor that should be accepted
VRangeMin: Defines the minimum UColor that should be accepted
VRangeMax: Defines the minimum UColor that should be accepted
SampleTrustiness: Percentage of samples in the limited UV-Color space
Pos. X: X-coordinate for sampling.
Pos. Y: Y-coordinate for sampling.
Note: The origin of the coordinate system is in the upper left corner.
Width: Sets number of pixels in x-direction.
Height: Sets number of pixels in y-direction.
Sample at Pos: If enabled Pos. X and Pos. Y will be replaced by XY-coordinates of the object center. If disabled the XY-coordinates will be set by values in the interface.
Get Sample: Sample another time the reference point.
To use the Chroma Keyer, a license must be present. ENG_PLUG_CHROMAFX
