- General
- Action
- Playlist
- Control Object
- MIDI
- Art-Net DMX
- MQTT
- RabbitMQ
- Object Tracker
- Viz Arena
- Parameter
- Channel
- Viz Engine/Unreal Engine Communication
- Tracking Hub Command
- SMM Handling
- GPI
- Viz Pilot
- Timer
- StreamDeck
- Graphic Hub REST
- DataMap
- NDI
- File Handling
- Logging
- JSON
- Excel
- Callbacks
- Exposed Objects
- xHost
- Time
- Lib
- host
- EnumToInt / EnumToString
- XmlNamespaceManager
- Performance
- Garbage Collection
- SQL Sample
- SQLite Sample
- TcpSend
- HtmlAgility Example
- Main Script-only
- Template Script-only
- Payloads
- Common Callbacks
- Parameters
- Unreal
- Flowics
- Video
- Using async/await
General
Viz Arc's scripting has many classes and types that are exposed and accessible via code. The script's main class is called arc and it exposes all the functions that are capable of interacting with the remaining parts of Viz Arc as well as many helper functions. All of arc's functions can be accessed via scripting by calling them directly, since they are all exposed directly to the global script, or via the arc keyword.
The following samples and codes snippets are all written using the V8 JavaScript syntax:
Accessing Viz Arc Functions
// Getting a reference to an action called VersusTemplatevar versus = arc.GetAction("VersusTemplate")var versus = GetAction("VersusTemplate")Note: You can also find this section in Viz Arc by selecting the Help button in the script section when in edit mode.
Action
All actions in the current project can be accessed using the GetAction method, whose content can be manipulated. See Action Properties for more details.
BaseAction GetAction (string actionNameOrGUID)
Returns the first action found with the name provided. When a valid GUID is provided as a string, it returns the action found with the provided GUID.
BaseAction GetAction (string actionName, string tabName)
Returns the first action found with the name provided inside the action tab named tabName.
BaseAction GetActionByName (string actionName)
BaseAction GetActionByName (string actionName, string tabName)
BaseAction GetActionByUUID (Guid actionUUID)
Returns the first action found with the provided GUID.
BaseAction[] GetSelectedActions ( )
Returns an array containing all the actions that are selected on the action canvas
string[] GetActionsOfTab (string tabName, string actionType = "ALL")
Returns an array with the names of the actions inside the tab tabName, optionally filtered by action type. It does not descend into Group Actions. Use
GetActionsto retrieve action objects.
BaseAction[] GetActions (string actionType = "ALL")
Returns an array with all the actions of the entire project of type equal to the one provided in actionType input. Default value ("ALL") includes all actions.
BaseAction GetChildAction (string nameOrUUID)
Method available on Group Action objects: returns the child action with the given name or UUID, for example
GetAction("myGroup").GetChildAction("headline").
GetAction Example
// Getting a reference to an action explicitly by its name "VersusTemplate"var versus = GetActionByName("VersusTemplate")// Getting a reference using a GUIDvar versus = GetAction("e87a8031-a86b-4997-a169-c6f791920449")// Getting a reference to an action called VersusTemplatevar versus = GetAction("VersusTemplate")// Getting all NDI actionsvar nidActions = GetActions("NDI")// get the action "PrecisionKeyer" within the "INITIALIZE" group actionvar chromaAction = GetAction("INITIALIZE").GetChildAction("PrecisionKeyer")Playlist
Playback and Navigation
These methods control the currently loaded playlist and its selected row.
Note: The functions in this section (including the Coloring functions and GetTemplatePayload) are available in template scripts only. The Playback and Navigation functions above are available in both the main script and template scripts.
void ExecuteSelectedPlaylistRow ( )
Executes the selected row on the playlist.
void ExecuteSelectedPlaylistRowAndNext ( )
Executes the selected row on the playlist and changes selection to the next row.
void PreviewSelectedPlaylistRow ( )
Previews the selected row on the playlist.
BaseAction GetSelectedPlaylistRowAction ( )
Returns the action that's attached to the selected row on the playlist.
void SetSelectedPlaylistRow (params string[] path)
Tries to find the row at path (path should contain a string per depth level) and makes it the selected row.
void PlayPlaylistByName (string tabName)
Highlights the playlist with the name tabName, and plays it from the beginning.
void PlayPlaylistByIndex (int tabIndex)
Highlights the playlist with 0-based index tabIndex, and plays it from the beginning.
void StopPlaylist ( )
Stops the currently playing playlist.
void ChangePlaylistTab (string tabName)
Selects and highlights the playlist with the name tabName.
Playlist Example
// Selects the row at "StatsDisplayGroup/AwayTeam/Show" and then previews and executes it.SetSelectedPlaylistRow("StatsDisplayGroup", "AwayTeam", "Show")PreviewSelectedPlaylistRow()ExecuteSelectedPlaylistRowAndNext()Building and Managing Playlists
A script can build and maintain playlists autonomously: generate one payload item per data row, group them into subfolders, and regenerate or delete them on demand. All of these methods run on the UI thread and refresh the playlist tree automatically. The edits are not added to the undo stack (same behaviour as the REST/MCP playlist API).
Two kinds of item can be created. CreatePlaylistItem creates a payload item: a snapshot of a template's linked control-object values, captured with GetTemplatePayload (see the Payloads section). Selecting a payload item fires the template's OnSetPayload (isPreview = true) callback and executing it fires OnSetPayload (isPreview = false); if no OnSetPayload is implemented, Viz Arc auto-restores the linked parameter values. CreatePlaylistActionItem instead creates a normal (non-payload) action item that references a canvas action, behaving like an ordinary canvas-action playlist row.
Tabs
bool CreatePlaylistTab (string name)
bool CreatePlaylistTab (string name, bool selectByDefault)
Creates a playlist tab named name. If a tab with that name already exists no new tab is created. When selectByDefault is true, the existing tab is selected. Returns false when the name is empty.
bool SelectPlaylistTab (string name)
Switches to the existing tab named name. Returns false if no tab with that name is found.
Creating Items
string CreatePlaylistItem (string label, string payload, string path = "", string tabName = null, int callup = 0)
Adds a payload item with the given label and payload string. path is optional (empty string targets the tab root; folder names such as "Forwards" are created on demand). tabName is optional (null or empty targets the current tab, which is created if missing). Returns the new item's UUID string, or null on failure, so it can be removed later. The optional callup assigns a Trio-style callup code to the created item (0 = no callup code).
string CreatePlaylistActionItem ( )
string CreatePlaylistActionItem (action, string path = "", string tabName = null, int callup = 0)
Adds a normal (non-payload) item that references a canvas action rather than a stored payload. action identifies the action to reference and may be its name or UUID (string), an action object (such as
ThisActionor the result ofGetActionByName/GetActionByUUID), or omitted to use the current template's own action. path and tabName follow the same conventions as CreatePlaylistItem. Returns the new row's UUID string, or null on failure (action or tab not found). The optional callup assigns a Trio-style callup code to the created item (0 = no callup code).
Inspecting
string ListPlaylist (string tabName = null)
Returns a JSON listing of the tab named tabName (when omitted, the currently selected tab). Each entry contains
{ uuid, label, type, path, duration, callup }.
Removing
bool RemovePlaylistItem (string uuidOrLabel)
Removes one or more rows. The argument is auto-detected: a UUID removes that single row (searched across all tabs); otherwise it is treated as a payload-item label and every matching item is removed. Returns true on success, false otherwise.
bool RemovePlaylistItem (string label, string folder, string tabName = null)
Removes every payload item with the given label, scoped to folder within tabName (current tab when omitted). Returns true on success, false otherwise.
bool ClearPlaylistFolder (string folder, string tabName = null)
Empties the folder named folder (the folder itself is kept). tabName targets the current tab when omitted. Returns true on success, false otherwise.
bool ClearPlaylist (string tabName = null)
Empties the tab named tabName. When omitted, the currently selected tab.
Coloring
Override the color bar of an item or folder. By default a payload or action row's bar reflects its source action's color, and folders have no bar until one is set. In every method hexColor is "#RRGGBB" (or "#AARRGGBB" with alpha); pass an empty string or null to clear the override and revert to the action color. Color overrides are saved with the project. All of these methods return true on success, false otherwise.
bool SetPlaylistItemColor (string uuidOrLabel, string hexColor)
Sets the color bar of one or more rows. The first argument is auto-detected: a UUID colors that single row; otherwise it is treated as a payload-item label and every matching item is colored.
bool SetPlaylistItemColor (string label, string hexColor, string folder, string tabName = null)
As above, scoped to folder within tabName (current tab when omitted).
bool SetPlaylistFolderColor (string folder, string hexColor, string tabName = null)
Sets the color bar of the folder named folder. tabName targets the current tab when omitted.
Coloring Example
// Highlight a specific row red, all "Messi" rows green, and a folder blue.SetPlaylistItemColor(id, "#E03131")SetPlaylistItemColor("Lionel Messi", "#2F9E44")SetPlaylistFolderColor("Forwards", "#1971C2", "Match Day")// Clear an override and revert to the source action's color.SetPlaylistItemColor(id, "")Playlist Authoring Example
// `squad` would typically come from a linked parameter, a REST/HTTP call, or MQTT.var squad = [ { name: "Alisson", number: 1, position: "Goalkeepers" }, { name: "Virgil van Dijk", number: 4, position: "Defenders" }, { name: "Mohamed Salah", number: 11, position: "Forwards" }, // ...]function buildSquadPlaylist(){ var tab = "Match Day" CreatePlaylistTab(tab, false) // ensure the tab exists, don't switch to it ClearPlaylist(tab) // start clean so re-runs don't duplicate for (var i = 0; i < squad.length; i++) { var p = squad[i] // Populate the template's parameters (or linked control objects) for this // player, then snapshot the linked control-object values as the payload. SetParameterValue("playerName", p.name) SetParameterValue("shirtNo", p.number) var payload = GetTemplatePayload() // One item per player, filed under a per-position subfolder. CreatePlaylistItem(p.name, payload, p.position, tab) }}buildSquadPlaylist()Callup Code
int NextFreeCallupCode (int start = 1000)
Returns the next free callup code in the playlist, searching upwards from start.
bool SetPlaylistItemCallup (string idOrLabel, int code, string path = "", string tabName = null)
Assigns the callup code code to the playlist item identified by UUID or label. The optional folder path and tabName narrow the search. Returns true on success.
Control Object
arc provides an alternative way of getting a BaseControlObject from a ControlObject/Blueprint action.
BaseControlObject GetControlObject (ControlObjectAction action, string id)
Returns the control object with a specific ID from ControlObject action.
BaseControlObject GetControlObject (UnrealBlueprintAction action, string id)
Returns the variable with name id of the given Blueprint action (used by the Blueprint example below).
Getting a Specific ControlObject from a ControlObjectAction
// Get the ControlObject Actionvar MatchDayAction = GetAction("MatchdayTable")// Get Title ControlObject (ControlText) and change its valueGetControlObject(MatchDayAction, "Title").Value = "Sunday Fixtures"// Get the Blueprint Actionvar HeadlineBp = GetAction("HeadlineBp")// Get Title ControlObject (String Variable) and change its valueGetControlObject(HeadlineBp, "Title").Value = "Lorem Ipsum"MIDI
Attached and configured MIDI devices can be used to receive MIDI events using the OnMIDIEvent callback. It's also possible to send MIDI events to an attached device using the following methods:
bool SendMIDIControlMessage (string DeviceName, int Channel, int Number, int Value)
Sends a MIDI control message to a the device named DeviceName, using Channel, Number and Value.
bool SendMIDINoteMessage (string DeviceName, bool On, int Channel, int Note, int Velocity)
Sends a MIDI note message to a the device named DeviceName, using Channel, Note and Velocity. The parameter On determines whether the event is a note on or note off event.
Note: Both of the methods above return true on successful completion and false if not successful.
MIDI Sample
Global.OnButtonPressed = function (id){ SendMIDIControlMessage("Midi Fighter Twister", 1, 1, 127) // send control message to Midi Fighter Twister on channel 1, number 1, value 127 SendMIDINoteMessage("nanoPAD2", true, 1, 5, 100) // send note down event to nanoPAD2 device }Global.OnMIDIEvent = function (midiEvent){ // just print the midi event on the console Console.WriteLine("midi event |" + midiEvent.DeviceName + "| " + midiEvent.EventType + "\n" + midiEvent.ToString())}Art-Net DMX
A sample on how to use the OnDMXEvent callback in a template or global script.
Art-Net Script Sample
Global.OnDMXEvent = function (dmxEvent){ Console.WriteLine( "Universe " + dmxEvent.Universe + " first change at channel " + dmxEvent.firstDiff ) Console.WriteLine( "Channel 7 has changed: " + dmxEvent.HasChanged(7) ) Console.WriteLine( "Channel 7 value is: " + dmxEvent.DMXData[7])}You can enable or disable the DMX signals using the following methods
void EnableDMX ( )
Enables callbacks of the connected Art-Net devices to be sent to connected actions and script callbacks.void DisableDMX ( )
Disables callbacks of the connected Art-Net devices to be sent to connected actions and script callbacks.bool IsDMXEnabled ( )
Returns whether the Art-Net callbacks are enabled.
MQTT
Message Queuing Telemetry Transport is supported through the possibility to instantiate a MQTT client and send/receive messages
ArcMqttClient createMQTTClient (string server, int port, string protocolVersion = "3.1.1")
Creates an MQTT client connected to server:port. protocolVersion accepts
"3.1","3.1.1"(default) or"5.0"— use"5.0"when connecting to MQTT 5 brokers.
The returned client ArcMqttClient supports the following methods
void Subscribe (string topic, int qos = 0)
Subscribes the client to the given topic with the specified quality of service (default 0).void Unsubscribe (string topic)
Unsubscribes the client from the given topic.void sendMessage (string topic, string payload)
Sends a message payloadto topic.void Dispose ( )
Disconnects and deletes the client.
Whenever a message is received from a topic a client has subscribed to, the new data is set to the global DataMap using the topic as key and the payload as value. Payload data in JSON format is passed as a JSON object, anything else is passed as a string object.
MQTT Sample
var mqttClientGlobal.OnInit = function (){ mqttClient = createMQTTClient("localhost", 6548) mqttClient.Subscribe("hello/world/news") SubscribeDataMap("hello/world/news")}Global.OnDataMapValueChanged = function (varName){ if( varName == "hello/world/news" ) Console.WriteLine("breaking news alert: " + GetData(varName))}A sample server written in C# illustrating the server side code using the MQTTnet library.
MQTT Server Sample
using MQTTnet;using MQTTnet.Extensions.ManagedClient;using MQTTnet.Server;using System;using System.Threading;namespace testmqtt{ class Program { static void Main(string[] args) { var optionsBuilder = new MqttServerOptionsBuilder() .WithConnectionBacklog(100) .WithDefaultEndpointPort(6548); var mqttServer = new MqttFactory().CreateMqttServer(); mqttServer.StartAsync(optionsBuilder.Build()); int i = 0; MqttApplicationMessage message = null; while (true) { message = new MqttApplicationMessageBuilder() .WithTopic("hello/world/news") .WithPayload("Temperatures below " + i + " !") .WithExactlyOnceQoS() .Build(); mqttServer.PublishAsync(message); Thread.Sleep(1000); Console.WriteLine(i + ""); i--; } } }}RabbitMQ
RabbitMQ is an open-source message broker that enables Viz Arc and other applications to communicate asynchronously by sending and receiving messages through queues.
Create a client
ArcRabbitMqClient createRabbitMQClient(string host, int port = 5672, string username = ‘guest’, string password = ‘guest’, string virtualHost = '/')
Creates a RabbitMQ client connecting to host on port using credentials username and password while virtualHost is the virtual host of the broker instance.
The following methods are support on an instance of ArcRabbitMqClient:
void DeclareQueue(string queueName, bool durable = false, bool exclusive = false, bool autoDelete = false)
Creates queue if it doesn't exist.
void ConsumeQueue(string queueName, bool autoAck = true, bool declareQueue = true)
Starts consuming. Messages are pushed to the DataMap with queueName as key.
void StopConsuming(string queueName)
Stops consuming from the specified queue.
void PublishToQueue(string queueName, string message)
Publishes message directly to a queue.
void Publish(string exchange, string routingKey, string message)
Publishes to an exchange with routing key.
bool IsConnected ()
Returns true while the client is connected to the broker.
void Dispose()
Closes connection and releases resources.
Example usage:
var rmqClient = null;var QUEUE_NAME = "vizarc_demo_queue";Global.OnCreated = function() { // Create RabbitMQ client - connects to localhost with default credentials // Parameters: host, port (default 5672), username (default "guest"), // password (default "guest"), virtualHost (default "/") rmqClient = createRabbitMQClient("localhost", 5672, "guest", "guest", "/"); // Declare and start consuming from a queue // Messages will be pushed to the DataMap with queue name as the key rmqClient.ConsumeQueue(QUEUE_NAME); // Subscribe to DataMap to receive messages SubscribeDataMap(QUEUE_NAME); Console.WriteLine("RabbitMQ client connected and consuming from: " + QUEUE_NAME);}Global.OnDestroyed = function() { // Clean up when script stops if (rmqClient != null) { rmqClient.StopConsuming(QUEUE_NAME); rmqClient.Dispose(); rmqClient = null; } Console.WriteLine("RabbitMQ client disconnected");}// Called when DataMap variable changes (message received)Global.OnDataMapValueChanged = function(varName) { if (varName === QUEUE_NAME) { var message = GetData(QUEUE_NAME); Console.WriteLine("Received message: " + message); // Process the message here processMessage(message); }}function processMessage(message) { // Example: Parse JSON message and update a parameter try { var data = JSON.parse(message); if (data.action === "update") { SetParameterValue("myTextParam", data.value); } } catch (e) { Console.WriteLine("Message is not JSON: " + message); }}// Button click handler to publish a test messageGlobal.OnButtonPressed = function(param) { if (param === "btnPublish") { var testMessage = JSON.stringify({ action: "update", value: "Hello from VizArc!", timestamp: new Date().toISOString() }); // Publish to queue (uses default exchange with queue name as routing key) rmqClient.PublishToQueue(QUEUE_NAME, testMessage); Console.WriteLine("Published: " + testMessage); }}Object Tracker
The script exposes some useful functions that allows customization and remoting of the Object Tracker. For example, the StopTracker and TakeOutTracker function could be used to quickly remove tracking or On Air graphics.
int GetActiveTracker ( )
Gets the currently active tracker index (starting from 1).
int SetActiveTracker (int tracker)
Sets the currently active tracker index (starting from 1). Returns the active tracker index.
void TakeTracker ( )
Takes tracker On Air all trackers.
void TakeTracker (int trackerIndex)
Takes the tracker with the given index on air (1 = first tracker), without needing the action name.
void TakeOutTracker ( )
Takes tracker Off Air all trackers.
void TakeOutTracker (int trackerIndex)
Takes the tracker with the given index off air.
void PreviewTracker ( )
Previews all trackers.
void PreviewOutTracker ( )
Removes all trackers from preview.
void StopTracker ( )
Stops all trackers.
void StopTracker (int index)
Stops the tracker with index (starting from 1).
void ResetPointerOffset(int index)
Reset the pointer offset for tracker with index (starting from 1).
bool ActivateSimpleTracking (string trackingType, string filterType = "", int filterSize = -1)
Activates simple (non-DNN) tracking of the given type, optionally with a smoothing filter. Returns true on success.
bool ActivateDetectionAndTracking (string dnnModel, float confidence, string trackingType, string filterType = "", int filterSize = -1, int filterBBSize = -1)
Activates DNN-based detection and tracking using the model dnnModel and the minimum detection confidence. Returns true on success.
void ResetStandings ( )
Resets the tracker standings.
void SetAutoTracking (int mode, int size, bool retake)
Configures automatic tracking.
Viz Arena
The script exposes some useful functions concerning the Viz Arena integration.
bool DetectArenaCalibration ( )
Redetects the camera calibration (same as the D shortcut in Viz Arena).
bool ClearArenaCalibration ( )
Clears the camera calibration (same as the BACKSPACE shortcut in Viz Arena).
bool ClearArenaKeyer ( )
Clears the Keyer mask (same as the C shortcut in Viz Arena).
string[] GetArenaCameraList ( )
Returns a string-list of available cameras.
string GetCurrentArenaCamera ( )
Returns the name of the current camera.
int GetCurrentArenaCameraIndex ( )
Returns the zero based index of the current camera.
bool SetArenaCamera (int index)
Selects the Arena camera with the given index (see GetArenaCameraList). Returns true on success.
string GetCurrentArenaTimeCode ( )
Returns the current Viz Arena timecode.
bool IsArenaConnected ( )
Returns whether Viz Arena is running and connected to Viz Arc.
Parameter
All parameters are exposed to the global script and can be accessed via their unique ID.
arc provides an alternative way of getting them.
BaseParameter GetParameter (string id)
Gets the parameter identified by the unique id that was input.
It's also possible to get and set a parameter's value directly from arc.
dynamic GetParameterValue (string id)
Gets the value of the parameter identified by the unique id that was input. [dynamic] The returned value's type depends on the parameter type.
void SetParameterValue (string id, dynamic value)
Sets the value of the parameter identified by the unique id that was input. [dynamic] Input variable value can be of any type, see parameters for valid types.
In case you don't want the callback function OnParameterChanged to be triggered when changing a value using SetParameterValue, you can use SetParameterRawValue. This method does not trigger any calls to OnParameterChanged.
void SetParameterRawValue (string id, dynamic value)
Buttons are a special case in the sense that they don't hold a value, and therefore have a separate method for triggering their click.
void PushParameterButton (string id)
Triggers a pressed event on the button identified by the unique id that was input.
Note: Button presses trigger the global script's callback OnButtonPressed.
Note: Parameter value changes trigger the global script's callback OnParameterChanged.
Parameter Examples
// Setting the value of a bool parameter (id = ShowHighlights) to false// direct assigmentShowHighlights.Value = false// Get parameter via arc and then assign to ValueGetParameter("ShowHighlights").Value = false// Set Parameter value via arc without interacting with the actual parameterSetParameterValue("ShowHighlights", false)// Getting the value of a bool parameter (id = ShowHighlights)var highlightState = GetParameterValue("ShowHighlights")// Push LoadFixtures buttonPushParameterButton("LoadFixtures")Channel
arc grants access to Viz Arc profiles. This is useful whenever more precise control is required for communicating with the Engines.
ScriptingProfile GetSelectedProfile ( )
Returns the currently selected profile.
int GetChannelCount ( )
Returns the number of channels on the currently selected profile.
ScriptingChannel GetChannel (int index)
Returns the channel at the index position on the currently selected profile.
ScriptingChannel GetChannel (string channelName)
Returns the channel named channelName on the currently selected profile.
ScriptingChannel GetPreviewChannel ( )
Returns the preview channel of the currently selected profile.
ScriptingChannel GetProgramChannel ( )
Returns the program channel of the currently selected profile.
ScriptingChannel GetSelectedChannel ( )
In a template script it returns the currently selected channel of the Template Action.
In the global script it returns the program channel of the currently selected profile.
Channel Handling Examples
// Clear main layer on all channels using GetChannelCount() and GetChannel(int)for (var i = 0; i < GetChannelCount(); i++) { GetChannel(i).SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")} // Send message to VideoWallchannel via GetSelectedProfile () and GetChannel(string)GetChannel("VideoWall").SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")GetSelectedProfile().GetChannel("VideoWall").SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")Profile
The object returned by GetSelectedProfile():
string Name [Get] — The profile's name.
int NumChannels [Get] — The number of channels in the profile.
ScriptingChannel GetChannel (int index) / ScriptingChannel GetChannel (string name)
Returns a channel by index or name (also available through the indexer, e.g. profile[0]).
ScriptingEngine VizEditingEngine / UnrealEditingEngine / FlowicsEditingEngine
The profile's editing engines.
ScriptingChannel VizPreviewChannel / UnrealPreviewChannel / FlowicsPreviewChannel
The preview channel per engine type.
ScriptingChannel VizProgramChannel / UnrealProgramChannel / FlowicsProgramChannel
The program channel per engine type.
Engine
Individual engines are reached through a channel (GetChannel(...).GetEngine(...)) or the profile's editing-engine properties:
void SendCommands (object[] commands)
Sends multiple commands to this engine.
string SendSingleCommand (string command)
Sends a single command to this engine.
string QueryEngine (string command) / string QueryEngine (string command, int timeout)
Sends command and returns the engine's answer, optionally with a timeout in milliseconds.
async Task<string> QueryEngineAsync (string command) / QueryEngineAsync (string command, int timeout)
Awaitable versions of the above.
string GetFlowicsOutput ( )
Returns the Flowics output URL of this engine.
arc provides quick access functions for sending messages to specific channels/Engines.
void SendSingleCommand (string command, string channelName)
Sends command to all the Engines in the specified channel channelName.
void SendMultipleCommands (string[] commands, string channelName)
Sends all the input commands to all the Engines in the specified channel channelName.
string GetFromEngine (string command, string channelName)
Sends command to all the Engines in the specified channel channelName. Returns the answer to the sent command.
string GetFromVizEngine (string command)
Sends command to the currently selected profile's Viz editing Engine. Returns the answer to the sent command.
string GetFromUnrealEngine (string command)
Sends command to the currently selected profile's Unreal editing Engine. Returns the answer to the sent command.
string GetFromEngineAsync (string command, string channelName, int timeout = -1)
If timeout is specified and larger than 0, the method times out after timeout milliseconds if it does not receive an answer within that time.
string GetFromEngineAsync (string command, int timeout = -1)
Sends command to all the Engines in the specified selected channel of the template. Returns the answer to the sent command.
string GetFromVizEngineAsync (string command)
string GetFromUnrealEngineAsync (string command)
Viz Engine Communication
// Get scene from parameter and set it to Viz Engine main layerSendSingleCommand(GetParameterValue("MainSceneSelector"), "Main")// Clear Main, Back and Front layers on channelvar CleanCommands = ["RENDERER*MAIN_LAYER SET_OBJECT", "RENDERER*BACK_LAYER SET_OBJECT", "RENDERER*FRONT_LAYER SET_OBJECT"] SendMultipleCommands(CleanCommands, "Viz")// Query Viz channel and Viz editing engine for the currently loaded sceneGetFromEngine("SCENE SCENE*SCENE GET", "Viz")GetFromVizEngine("SCENE SCENE*SCENE GET")The async variants can be used only when using the JavaScript language and have the advantage that they do not lock up the UI.
Async Samples
Global.OnButtonPressed = async function (id){ if( id == "getVersionButton" ){ const answer = await GetFromEngineAsync("VERSION", "localviz") Console.WriteLine("Viz Version is: " + answer) }}Note: If you use await, the enclosing function needs to be async. You can add this attribute manually in case you use it within a Viz Arc callback.
arc provides quick access functions for sending messages to the configured Tracking Hub.
void SendSingleTHCommand (string command)
Sends command to the Tracking Hub (if configured and connected).
string GetFromTH (string command)
Sends command to the Tracking Hub (if configured and connected) and returns the answer.
string GetFromTHAsync (string command)
The asynchronous version of GetFromTH.
SMM Handling
void SendToSMM (string key, string value, bool doEscape)
Sends key-value pair to Shared Memory to the first channel of the current profile. doEscape specifies whether the value string is escaped.
void SendToSMM (string key, string value, bool doEscape, string channel)
Sends key-value pair to Shared Memory to all Engines contains in channel. doEscape specifies whether the value string is escaped.
void SendToSMM (string key, string value, bool doEscape, string channel, string destination)
destination can be either SYSTEM, COMMUNICATION or DISTRIBUTED
The shared memory updates are sent to the UDP or TCP port configured on the target Viz Engine; if both are configured, it is sent to the UDP port. The Viz Communication Shared Memory map is therefore utilized. You can read more on Shared Memory configuration in the Profiles section in the Viz Arc User Guide.
SMM Example
// Send to Viz Channel SMM the variable "Target1" with the value from TargetState SendToSMM("Target1", TargetState.Value, false, "Viz")// Send to Viz Channel SMM the variable "Target2" with the value "Hello World!". // The last parameter "DISTRIBUTED" indicates that the value will be propagated to all engines connected to the same Graphic HubSendToSMM("Target2", "Hello World!", false, "Viz", "DISTRIBUTED")GPI
The connected GPI state can be changed via the arc functionalities:
void SignalGpiChannel (int channelIndex, bool signalHigh)
Signals set the GPI channel at channelIndex to either high or low.
The following snippet presents a function that loads a scene to the "Main" channel and signals the GPI:
GPI Example
function LoadScene(){ // Get scene from parameter and set it to Viz Engine main layer SendSingleCommand(GetParameterValue("MainSceneSelector"), "Main") // Set gpi channel 2 to High SignalGpiChannel(2, true)}Note: GPI must be enabled on the config.
Viz Pilot
Viz Pilot data elements can be created from scripting using the method CreatePilotDataElement. There are two ways to invoke this method:
async bool CreatePilotDataElement (BaseAction action, string name)
Creates a Viz Pilot data element of action and name name. The function returns true on success.
The BaseAction method:
async bool CreatePilotDataElement (string name)
Creates a Viz Pilot data element with name name. The function returns true on success.
Global.OnButtonPressed = async function (id){ try{ if( id == "createpilotButton" ) { // use global method await CreatePilotDataElement(GetAction("loadSceneA"), "LoadSceneA") // use method defined on the BaseAction itself await GetAction("loadSceneA").CreatePilotDataElement("LoadSceneA_fromAction") } }catch(ex) { // error handle Console.WriteLine("ex " + ex + " " + ex.stack) }}Timer
void CreateTimer (string id)
Creates a timer that can be accessed via its unique id.
void CreateTimer (string id, int ms)
Starts a timer that can be accessed via its unique id and has a tick interval of ms.
void StartTimer (string id, int ms)
Gets the timer identified by id, sets the tick interval to ms and starts it.
void StopTimer (string id)
Gets the timer identified by id and stops it.
The following example creates a timer on the OnInit callback, makes use of two buttons to start/stop the timer and writes to the console whenever the timer ticks:
Timer Example
// Timer idvar heartBeatTimerId = "HeartBeat"Global.OnInit = function (){ // Create timer with id heartBeatTimerId CreateTimer(heartBeatTimerId)}Global.OnButtonPressed = function (id){ if(id == "TimerStart") StartTimer(heartBeatTimerId, 1000) else if(id == "TimerStop") StopTimer(heartBeatTimerId)}// Script callback for timer ticksGlobal.OnTimer = function (id){ Console.WriteLine("Timer Tick " + id)}Note: Whenever a timer ticks the global script's callback OnTimer is called.
JavaScript Timer Functions
Viz Arc provides browser-style timer functions that allow you to execute code after a delay or at regular intervals. These functions mimic the standard JavaScript timer API found in web browsers, making it familiar for developers with web development experience.
Overview
The timer functions allow you to:
Execute code once after a specified delay (
setTimeout).Execute code repeatedly at fixed intervals (
setInterval).Cancel pending or repeating timers (
clearTimeout,clearInterval).
All timer functions return a unique timer ID that can be used to cancel the timer before it executes.
setTimeout
Executes a function once after a specified delay.
Syntax:
int setTimeout(function callback, int delay)Parameters:
callback: The function to execute after the delaydelay: Time in milliseconds to wait before executing the function
Returns:
int: A unique timer ID that can be used withclearTimeout()
Example - Basic Usage:
Global.OnButtonPressed = function (id){ if (id == "delayedAction") { Console.WriteLine("Action will execute in 3 seconds...") setTimeout(function() { Console.WriteLine("3 seconds have passed!") SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT Scene1", "Main") }, 3000) }}Example - Using Named Functions:
function showGraphic(){ Console.WriteLine("Displaying graphic") GetSelectedChannel().SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT SCENE*some/scene/l3rd") SetData("lastUpdate", Date().toString())}Global.OnButtonPressed = function (id){ if (id == "delayShow") { setTimeout(showGraphic, 5000) // Show graphic after 5 seconds }}Example - Storing Timer ID for Cancellation:
var pendingTimerId = nullGlobal.OnButtonPressed = function (id){ if (id == "scheduleUpdate") { // Schedule an update for 10 seconds from now pendingTimerId = setTimeout(function() { Console.WriteLine("Executing scheduled update") GetParameter("StatusText").Value = "Updated" }, 10000) Console.WriteLine("Update scheduled with timer ID: " + pendingTimerId) } else if (id == "cancelUpdate") { if (pendingTimerId != null) { clearTimeout(pendingTimerId) Console.WriteLine("Scheduled update cancelled") pendingTimerId = null } }}clearTimeout
Cancels a timer created with setTimeout before it executes.
Syntax:
void clearTimeout(int timerId)Parameters:
timerId: The timer ID returned bysetTimeout()
Example - Cancelling a Scheduled Action:
var countdownTimer = nullfunction startCountdown(){ Console.WriteLine("Graphics will load in 10 seconds...") countdownTimer = setTimeout(function() { GetSelectedChannel().SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT SCENE*Countdown") Console.WriteLine("Graphics set!") }, 10000)}function cancelCountdown(){ if (countdownTimer != null) { clearTimeout(countdownTimer) Console.WriteLine("Countdown cancelled") countdownTimer = null }}Global.OnButtonPressed = function (id){ if (id == "btnStart") startCountdown() else if (id == "btnCancel") cancelCountdown()}setInterval
Executes a function repeatedly at a fixed time interval until cancelled.
Syntax:
int setInterval(function callback, int interval)Parameters:
callback: The function to execute repeatedly.interval: Time in milliseconds between each execution.
Returns:
int: A unique interval ID that can be used withclearInterval().
Example - Updating a Clock:
var clockIntervalId = nullfunction updateClock(){ var currentTime = new Date().toLocaleTimeString() SetParameterValue("ClockDisplay", currentTime) SetData("currentTime", currentTime)}Global.OnButtonPressed = function (id){ if (id == "startClock") { // Update clock every second clockIntervalId = setInterval(updateClock, 1000) Console.WriteLine("Clock started") } else if (id == "stopClock") { if (clockIntervalId != null) { clearInterval(clockIntervalId) Console.WriteLine("Clock stopped") clockIntervalId = null } }}Example - Periodic Status Check:
var statusCheckId = nullfunction checkEngineStatus(){ var version = GetFromEngine("VERSION", "Main") Console.WriteLine("Engine Status Check: " + version) // Update status display SetParameterValue("EngineStatus", "Online - " + version)}Global.OnCreated = function(){ // Check engine status every 3 seconds statusCheckId = setInterval(checkEngineStatus, 3000)}Example - Animation Loop:
var animationId = nullvar counter = 0function animateCounter(){ counter++ SetParameterValue("CounterValue", counter) // Stop after reaching 100 if (counter >= 100) { clearInterval(animationId) Console.WriteLine("Animation complete") animationId = null }}Global.OnButtonPressed = function (id){ if (id == "startAnimation") { counter = 0 animationId = setInterval(animateCounter, 50) // Update every 50ms }}clearInterval
Cancels a repeating timer created with setInterval.
Syntax:
void clearInterval(int intervalId)Parameters:
intervalId: The interval ID returned bysetInterval()
Example - Starting and Stopping a Refresh Loop:
var refreshId = nullfunction refreshData(){ Console.WriteLine("Refreshing data from API...") // Fetch and update data here var timestamp = Date().toString() SetData("lastRefresh", timestamp)}Global.OnButtonPressed = function (id){ if (id == "btnStartRefresh") { if (refreshId == null) { refreshData() // Execute immediately refreshId = setInterval(refreshData, 5000) // Then every 5 seconds Console.WriteLine("Auto-refresh enabled") } } else if (id == "btnStopRefresh") { if (refreshId != null) { clearInterval(refreshId) refreshId = null Console.WriteLine("Auto-refresh disabled") } }}Best Practices
Always Store Timer IDs
// Good - can be cancelled latervar timerId = setTimeout(myFunction, 1000)// Avoid - cannot be cancelledsetTimeout(myFunction, 1000)Avoid Memory Leaks
var updateInterval = nullGlobal.OnButtonPressed = function (id){ if (id == "startUpdates") { // Clear existing interval before creating a new one if (updateInterval != null) clearInterval(updateInterval) updateInterval = setInterval(updateFunction, 1000) }}Handle Long-Running Intervals
var pollCount = 0var pollId = nullfunction pollAPI(){ pollCount++ // Implement a maximum number of attempts if (pollCount > 100) { clearInterval(pollId) Console.WriteLine("Polling stopped after 100 attempts") return } // Your polling logic here Console.WriteLine("Polling... attempt " + pollCount)}pollId = setInterval(pollAPI, 100)Complete Example - Countdown Timer
var countdownValue = 10var countdownId = nullfunction countdown(){ if (countdownValue > 0) { SetParameterValue("CountdownDisplay", countdownValue.toString()) Console.WriteLine("Countdown: " + countdownValue) countdownValue-- } else { // Countdown finished clearInterval(countdownId) countdownId = null SetParameterValue("CountdownDisplay", "GO!") Console.WriteLine("Countdown complete!") // Execute action after countdown SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT LaunchGraphic", "Main") }}Global.OnButtonPressed = function (id){ if (id == "btnStartCountdown") { countdownValue = 10 countdown() // Show initial value immediately countdownId = setInterval(countdown, 1000) // Then update every second } else if (id == "btnStopCountdown") { if (countdownId != null) { clearInterval(countdownId) countdownId = null Console.WriteLine("Countdown stopped") } } else if (id == "btnResetCountdown") { if (countdownId != null) { clearInterval(countdownId) countdownId = null } countdownValue = 10 SetParameterValue("CountdownDisplay", countdownValue.toString()) }}Performance Considerations
Warning: Too many timers or short intervals can cause UI freezing and performance issues.
Recommended Intervals
// ❌ BADsetInterval(heavyOperation, 10)// ✅ GOODsetInterval(lightUpdate, 100) // Light: 100ms minimumsetInterval(apiCall, 1000) // Heavy: 1 second minimum setInterval(polling, 5000) // Polling: 5+ secondsBest Practices
Limit Active Timers (< 15 per template)
// ❌ Multiple timersfor (var i = 0; i < 10; i++) setInterval(update, 1000)// ✅ Single timervar i = 0setInterval(function() { update(i++ % 10) }, 1000)Use setTimeout for Slow Operations
// ❌ Overlapping callssetInterval(slowAPICall, 2000) // Takes 3 seconds!// ✅ Wait for completionfunction poll() { slowAPICall() setTimeout(poll, 2000)}Quick Checklist
✅ Intervals ≥ 100ms (1000ms+ for heavy operations)
✅ Keep total timers under 15
✅ Callbacks faster than interval duration
Notes
These functions mimic the standard JavaScript timer API found in web browsers, making them familiar to web developers
All timers are automatically cleaned up when the script is stopped or reloaded
Timer callbacks are executed on the UI thread for safe interaction with Viz Arc parameters and UI elements
Delays and intervals are specified in milliseconds (1000ms = 1 second)
If an error occurs in a
setIntervalcallback, the interval is automatically stopped to prevent repeated errorsUnlike in browsers, additional arguments after the delay are not forwarded to the callback, and the delay argument is required.
StreamDeck
Any connected StreamDeck that is configured to be used exclusively with arc, can have its buttons customized using one of the following methods:
void SetStreamdeckKey (int key, string label, int fontSize)
Baseline version, sets streamdeck key at key index image to a black square with label text of fontSize size.
void SetStreamdeckKey (int key, string label, int fontSize, string imageFullPath)
Same as the baseline version but instead of a black block it sets a local image (at imageFullPath) as background. imageFullPath can be either a local file system path or a Graphic Hub path.
void SetStreamdeckKey (int key, string label, int fontSize, int r, int g, int b)
Same as the baseline version but instead of black it uses an RGB color as background.
void SetStreamdeckKey (int key, string label, int fontSize, int r, int g, int b, string imageName)
Same as baseline version using background color r, g, b and imageName on top of the background color (in case the image contains an alpha channel).
void SetStreamdeckKey (int key, string label, int fontSize, string horAlignment, string vertAlignment, string textAlignment, int r, int g, int b, string imageName)
Same as the previous version, where text is horAlignment aligned horizontally, vertically by vertAlignment and the text itself is centerd through textAlignment.
horAlignment can be either "Left", "Center" or "Right"
vertAlignment can be either "Top", "Center" or "Bottom"
textAlignment can be either "Left", "Center" or "Right"
Any key can have its contents cleared with the following method:
void ClearStreamdeckKey (int key)
Clears the content of the Streamdeck key at key index
StreamDeck Key Configuration Example
function SetupStreamDeck(){ // Key 0: Black background, size 20 "Clear" text SetStreamdeckKey(0, "Clear", 20) // Key 1: Image background, size 20 "Load AR" text SetStreamdeckKey(1, "Load AR", 20, "D:/Soccer/Images/ARThumbnail.png") // Key 2: Blue background, size 20 "Continue" text SetStreamdeckKey(2, "Continue", 20, 0, 0, 255) // Key 3: Gray background, using headshot from Graphic Hub (image may contain an alpha channel) SetStreamdeckKey(3, " ", 20, 100, 100, 100, "IMAGE*/Default/MasterImages/headshot_0123") // Key 4: Gray background, using headshot from Graphic Hub (image may contain an alpha channel), Text "John Doe" is top left aligned SetStreamdeckKey(4, "John Doe", 20, "Left", "Top", "Left", 100, 100, 100, "IMAGE*/Default/MasterImages/headshot_0123")} Global.OnInit = function () { // Clean first 3 keys ClearStreamdeckKey(0) ClearStreamdeckKey(1) ClearStreamdeckKey(2) SetupStreamDeck()}Another sample that prints some useful information using the external StreamDeck plugin.
function printSDEvenyInfo(sdEvent){ // print all the available information for a StreamDeck event Console.WriteLine("StreamDeck Event Info:") Console.WriteLine("Event Type: " + sdEvent.EventType) Console.WriteLine("Device Index: " + sdEvent.DeviceIndex) Console.WriteLine("Device ID: " + sdEvent.Id ) Console.WriteLine("Column: " + sdEvent.XKey ) Console.WriteLine("Row: " + sdEvent.YKey ) Console.WriteLine("Payload: " + sdEvent.Payload ) // if it's a dial or touch event print additional info // for StreamDeck + devices only if( sdEvent.hasOwnProperty("Ticks") ) Console.WriteLine("Ticks: " + sdEvent.Ticks ) if( sdEvent.hasOwnProperty("TapPosX") ) Console.WriteLine("TapPosX: " + sdEvent.TapPosX ) if( sdEvent.hasOwnProperty("TapPosY") ) Console.WriteLine("TapPosY: " + sdEvent.TapPosY )}Global.OnStreamDeckTouchTap = function (sdEvent){ printSDEvenyInfo(sdEvent)}Global.OnStreamDeckDialRotate = function (sdEvent){ printSDEvenyInfo(sdEvent)}Global.OnStreamDeckDialDown = function (sdEvent){ printSDEvenyInfo(sdEvent)}Global.OnStreamDeckDialUp = function (sdEvent){ printSDEvenyInfo(sdEvent)}Global.OnStreamDeckKeyDown = function (sdEvent){ printSDEvenyInfo(sdEvent)}Global.OnStreamDeckKeyUp = function (sdEvent){ printSDEvenyInfo(sdEvent)}Graphic Hub REST
arc provides some methods that allow to retrieve information about the current Graphic Hub REST server in use. It is meant to help using the Graphic Hub REST interface directly.
string GetGHHost ( )
Returns the Graphic Hub REST host name (for example, localhost or 10.81.44.71).
string GetGHPort ( )
Returns the Graphic Hub REST port (for example,
19398).
string GetGHConnectionString ( )
Returns the complete connection string based on the configured Host and Port (for example, http://localhost:
19398).
string GetGHUser ( )
Returns the Graphic Hub REST user name (for example, Guest or Admin).
string GetGHAuthenticationValue ( )
Returns the base64 authentication string which is a combination of the user name and password (for example, QWRtaW46Vml6RGI=).
bool ImportArchive (string path)
Import a via archive through the REST service. Beware that all assets in the via override the content’s of the Graphic Hub. Returns true on success and false on failure.
async Task<bool> ImportArchiveAsync (string path)
Async version of the above method.
Below is a code sample that fetches all the image names of a given Graphic Hub path using the GetGHConnectionString and GetGHAuthenticationValue functions.
Sample
function getFolderId( path ){ let folderId = "" let request = new XMLHttpRequest() request.onreadystatechange = function() { if (request.readyState == 4 && request.status == 200 ) { //Console.WriteLine("respones: " + request.responseText) xmlDoc = new XmlDocument() xmlDoc.LoadXml(request.responseText) //Console.WriteLine("nodes " + xmlDoc.ChildNodes.Count) // create namespace manager nsmgr = new XmlNamespaceManager(xmlDoc.NameTable) // add namespace nsmgr.AddNamespace("x", "http://www.w3.org/2005/Atom") // search for x:model root = xmlDoc.DocumentElement folderId=root.SelectSingleNode("/x:feed/x:entry/x:id", nsmgr).InnerXml.split(':')[2] Console.WriteLine("folder id " + folderId) } } request.open("GET", GetGHConnectionString()+"/translator/?path="+path, true) request.setRequestHeader("Authorization", "Basic " + GetGHAuthenticationValue()) request.send(); // fetch the images using the folder uuid GetImagesOfFolder(folderId)}function GetImagesOfFolder(folderId){ let request = new XMLHttpRequest() request.onreadystatechange = function() { if (request.readyState == 4 && request.status == 200 ) { //Console.WriteLine("respones: " + request.responseText) xmlDoc = new XmlDocument() xmlDoc.LoadXml(request.responseText) //Console.WriteLine("nodes " + xmlDoc.ChildNodes.Count) // create namespace manager nsmgr = new XmlNamespaceManager(xmlDoc.NameTable) // add namespace nsmgr.AddNamespace("x", "http://www.w3.org/2005/Atom") // search for nodes 'entry' root = xmlDoc.DocumentElement imageNodes=root.SelectNodes("/x:feed/x:entry", nsmgr) //Console.WriteLine("nodes " + imageNodes.Count) let imageList = [] for( node of imageNodes ) { Console.WriteLine("image " + node.SelectSingleNode("./x:title", nsmgr).InnerXml) imageList.push(node.SelectSingleNode("./x:title", nsmgr).InnerXml) } // set the dropdown // imagesDD.SetItems(imageList) } } request.open("GET", GetGHConnectionString()+"/files/" + folderId + "/?term=IMAGE", true) request.setRequestHeader("Authorization", "Basic " + GetGHAuthenticationValue()) request.send()}Other functions relative to the Graphic Hub:
async Task<string[]> GetImages(path)
Returns a string list of images in the Graphic Hub.
async function fetchImages(path){ Console.WriteLine("fetching images in " + path) const results = await GetImages(path).then(results => { dropdown_0.SetItems(results) })}Global.OnButtonPressed = function (id){ if( id == "button_0" ) { dropdown_0.Clear() fetchImages("sports/soccer/headshots") }}The above code snippet populates a dropdown with the image names contained in the Graphic Hub path sport/soccer/headshots.
DataMap
arc provides an interface (get and set) for interacting with Viz Arc's DataMap:
dynamic GetData (string varName)
Returns the value belonging to the variable named varName. [dynamic] Returned value depends on what was set to varName.
void SetData (string varName, dynamic value)
Inserts (or overwrites if varName already exists) the key:value pair into Viz Arc's DataMap. [dynamic] Input value can be of any type.
void SetDataAsync (string varName, dynamic value)
Same as SetData, but returns immediately and applies the change asynchronously. Useful when setting many keys from time-critical code.
bool HasData (string varName)
Returns true if varName exists in the DataMap.
bool DeleteDataMapKey(string varName)
Removes a variable from the DataMap. Returns true if the key existed and was deleted.
void SubscribeDataMap (string variableName)
Subscribes to a specific key (Empty string subscribes to all changes). The subbed variables feedback triggers the script callback "OnDataMapValueChanged".
void UnsubscribeDataMap (string variableName)
Unsubscribes from a specific key (Empty string unsubscribes to all changes).
string[] GetDataKeys ( )
Returns a complete list of all DataMap key entries.
DataMap Example
Global.OnInit = function (){ // make sure OnDataMapValueChanged is called when "someData" changes SubscribeDataMap("someData") // use blank string to subscrive to all DataMap changes //SubscribeDataMap("") // create a timer that triggers every second CreateTimer("aTimer") StartTimer("aTimer", 1000)}// Callback for DataMap changesGlobal.OnDataMapValueChanged = function (varName){ if(varName == "someData") UpdateSomeData(GetData(varName))}function UpdateSomeData( theData ){ // do something here Console.WriteLine( "new data " + theData )}Global.OnTimer = function (id){ // generate some fresh data using the current time for testing // such that OnDataMapValueChanged gets called if( id == "aTimer" ) SetData("someData", Date.now())}function printDataMap(){ var keys = GetDataKeys() for( k of keys ) Console.WriteLine(k + " = " + GetData(k) )}Note: Whenever a DataMap variable changes the global script's callback OnDataMapValueChanged is called.
NDI
arc provides an interface to handle metadata feedback from NDI sources.
string[] GetNDISourceList ( )
Returns an array with all the names of the available NDI sources.
string[] GetNDIPTZSourceList ( )
Returns an array with all the names of the available NDI sources with PTZ control capabilities.
bool SubscribeNdiSourceMetadata (string source)
Subscribes to the metadata feedback on the NDI source identified by the provided source input. The feedback is sent to the datamap with key equal to the source name. Returns true on success, false otherwise.
bool UnsubscribeNdiSourceMetadata (string source)
Unsubscribes the NDI feedback. Returns true on success, false otherwise.
bool SendNDIMetadata (string name, string XMLString)
Sends a XMLString to a source identified by name. Returns true on success, false otherwise.
DataMap Example
Global.OnInit = function (){ // Get a list of available NDI sources (can take some time to update) var sources = GetNDISourceList() // subscribe to metadata changes on a ndi stream SubscribeNdiSourceMetadata("NEWTEKPTZ (Channel 1)") // metadata will be written into the DataMap, so register to the DataMap changes also SubscribeDataMap("NEWTEKPTZ (Channel 1)")}Global.OnDataMapValueChanged = function (varName){ Console.WriteLine(varName + " changed") // NDI metadata is typically in xml format Console.WriteLine(GetData(varName).ToString())}Global.OnParameterChanged = function (id){ if( id == "sendMetadata") { SendNDIMetadata("NEWTEKPTZ (Channel 1)", "<?xml version='1.0' encoding='UTF-8'?><camera_control><command group_id='0' parameter_id='3' value='0.43'></camera_control>") }}File Handling
string ReadTextFile (string filename, string encoding = "UTF8")
Returns a encoding encoded string containing the whole content of the text file.
bool WriteTextFile (string FullPath, string data, string encoding = "UTF8")
Writes a file at FullPath with its content equal to the encoded input data.
string GetApplicationDirectory ( )
Returns the directory the Viz Arc executable runs from.
Valid encodings: "UTF8", "ASCII", "BigEndianUnicode", "Default" [System defined encoding], "UTF32", "UTF7"
File Handling Example
// Get the StartList file content from the directory defined by the Directory parameter "WorkingDir"ReadTextFile( WorkingDir.Value + "\\StartList.json")// Write the results to the directory defined by the Directory parameter "WorkingDir"WriteTextFile( WorkingDir.Value + "\\RaceResults.json", results)Logging
bool AddLog (string fileName, string content)
Appends content to fileName, and returns true on success, false otherwise. If the file fileName does not exist, it is created.
// register data map changes somewhere (e.g. SubscribeDataMap(""))Global.OnDataMapValueChanged = function (varName){ AddLog("c:/tmp/templateLog.txt", "getting data " + varName + " = " + GetData(varName))}The produced log file content contains entries as the example below:
2025/07/08 19:20:34.1389|getting data TIMECODE = 02:55:59:43
JSON
dynamic ParseJson (string data)
Deserializes the input data and returns a JSON object if successful.
On the returned JSON object you can access the members directly using their name. Use the "ToString()" method on any of the objects to convert them to strings.
var json = ParseJson("{time: '1994-11-05T13:15:30Z', title: 'Viz Arc', subtitle: 'Vizrt', messageId: 1}")Console.WriteLine("the whole json " + json.ToString())Console.WriteLine("the title is " + json.title.ToString())When using the V8 Scripting Engine the built-in JSON.parse and JSON.stringify methods can be used
var json = JSON.parse('{"time": "1994-11-05T13:15:30Z", "title": "Viz Arc", "subtitle": "Vizrt", "messageId": 1}')Console.WriteLine("the whole json " + JSON.stringify(json))Console.WriteLine("the title is " + json.title)Excel
bool convertXLSToCSV (string excelFilePath, string csvOutputFile, string separator = "\t", int worksheetNumber = 1)
Converts an existing .xls file excelFilePath to a comma separated CSV file csvOutputFile usign separator (default tab separator) and using worksheet number worksheetNumber (1 default being the first worksheet in the Excel file).
Returns true on successful conversion, false otherwise.
string convertXLSToCSVString (string excelFilePath, string separator = "\t", int worksheetNumber = 1)
Converts an existing .xls file excelFilePath to a comma separated CSV string using separator (default tab separator) and using worksheet number worksheetNumber (1 default being the first worksheet in the Excel file).
On successful conversion the function returns the CSV output as a string.
void convertXLSToCSVDataMap (string excelFilePath, string dataMapPrefix, string separator = "\t", int fromSheet = 1, int toSheet = -1)
Converts the worksheets of the Excel file excelFilePath and writes each worksheet's content as CSV to the DataMap key
dataMapPrefix<index>(1-based worksheet index). The worksheet's name is written to the keydataMapPrefix_name_<index>. Use fromSheet/toSheet to limit the range (-1 = all worksheets).
let separator = ";"// convert excel to CSV file, use ; as separator and read the second sheetconvertXLSToCSV("c:/tmp/ExcelData.xlsx", "c:/tmp/ExcelData.csv", separator, 2)// read the whole csv file into a stringvar fileContent = ReadTextFile("c:/tmp/ExcelData.csv")var EntryArr = fileContent.split("\n") // First line is for the headers, ignore itfor(i = 0; i < EntryArr.length; i++){ // split the row var spl = EntryArr[i].split(separator) if( spl.length <= 1 ) continue; Console.WriteLine("row " + i + ":") // print colums one by one separated by a whitespace for( entry of spl ) Console.Write( entry.trim() + " " ) Console.WriteLine("")}// another writing all worksheets to the DataMap, use separator ","convertXLSToCSVDataMap("c:/tmp/ExcelData.xlsx", "excelData_", ",")How the resulting DataMap might look like after calling convertXLSToCSVDataMap when the excel file contains just one worksheet.
Callbacks
OnParameterChanged (string parameterID)
Called whenever a parameter (except button and table) changes. parameterID is the ID of the parameter that triggered the callback.
OnButtonPressed (string buttonName)
Called when a parameter button is pressed. buttonName is the ID of the button that triggered the callback.
OnMiddleButtonPressed (string buttonName)
Called when a button is pressed with the middle mouse button. buttonName is the ID of the button that triggered the callback.
OnRightButtonPressed (string buttonName)
Called when a button is pressed with the right mouse button. buttonName is the ID of the button that triggered the callback.
OnButtonToggled (id, checked)
Called whenever a Toggle Button parameter changes state. id is the parameter name, checked the new state.
OnTimer (string timerID)
Called when a timer ticks (completes a cycle). timerID is the ID of the timer that triggered the callback.
OnDataMapValueChanged (string varName)
Called whenever a DataMap variable changes. varName is the ID of the variable that was changed.
OnStreamDeckKey (int key)
Called whenever a StreamDeck button is pressed. key indicates the index of the pressed button.
This callback is used in conjunction with the internal Stream Deck integration
OnCompanionKey (companionEvent)
Called whenever a key event is received from Bitfocus Companion. companionEvent exposes Payload and DeviceName.
OnMonogramEvent (jsonEvent)
Called whenever an event is received from a Monogram controller. jsonEvent contains the event as a JSON string.
The following StreamDeck callbacks are used with the external Stream Deck integration:
OnStreamDeckKeyUp (sdEvent)
Called whenever a Stream Deck button has been released.
sdEvent contains the following fields:
string EventType (the event type, for example, "keyUp")
string Id (the unique ID of the device)
string DeviceIndex (the index of the Stream Deck device that generated the event)
string DeviceName (the name of the Stream Deck device that generated the event)
int XKey (the column index of the key)
int YKey (the row index of the key)
string Payload (the user defined payload)
OnStreamDeckKeyDown (sdEvent)
Called whenever a Stream Deck dial has been pressed.
sdEvent contains the same fields as OnStreamDeckKeyUp
OnStreamDeckDialUp (sdEvent)
Called whenever a Stream Deck dial has been released.
OnStreamDeckDialDown (sdEvent)
OnStreamDeckDialRotate (sdEvent)
Called whenever a Stream Deck dial has been rotated;
Tickscontains the amount and direction of the rotation.sdEvent contains the same fields as OnStreamDeckKeyUp and additionally:
int Ticks positive number for clockwise rotation and negative for anticlockwise rotation. Minimum value is 1 and increases when doing fast movementes.
OnStreamDeckTouchTap (sdEvent)
Called whenever the Stream Deck touch strip has been tapped;
TapPosX/TapPosYcontain the tap position.sdEvent contains the same fields as OnStreamDeckKeyUp and additionally:
int TapPosX number from 0 to 200 (on Stream Deck + device) representing the horizontal touch position
int TapPosY number from 0 to 100 (on Stream Deck + device) representing the vertical touch position
OnMIDIEvent (midiEvent)
Called whenever a midi event is registered on one of the attached and configured midi devices.
midiEvent contains the following fields:
string DeviceName (the name of the device triggering the midi event.
string EventType (either "ControlChange", "NoteOn" or "NoteOff").
int Channel (the control channel of the event).
int Number (the control number of the event).
int Value (the value of the event, in the range [0..127]).
int Note (the note of the event in case EventType is NoteOn or NoteOff).
int Velocity (the velocity of note event in case EventType is NoteOn or NoteOff).
OnDMXEvent (dmxEvent)
Called whenever a dmx lighting value changes
dmxEvent contians the followinf fields:
short Universe (the Univers ehtat changed)
byte[] DMXData (the entire 512 byte long data array)
byte[] change (a 512 byte long array containing information about channel changes)
int firstDiff (the index of the first channel that changed)
bool HasChanged(int index)
Call this function to check whether a certain channel has changed
Table Callbacks
OnTableColumnsChanged (string tableID)
Called whenever a table parameter's columns change in number. tableID is the ID of the table that triggered the callback.
OnTableRowsChanged (string tableID)
Called whenever a table parameter's rows change in number. tableID is the ID of the table that triggered the callback.
OnTableCellValueChanged (string tableID, int row, int column, BaseBlock cell)
Called whenever a table parameter's cell changes value. tableID is the ID of the table that triggered the callback. row and column indicate the position of the cell within the caller table parameter. cell is the cell object that was changed. Users can interact directly with it. When Trigger on live changes is enabled on the table property, this callback is called also while editing the cell, if not the callback is called when keyboard focus is lost on the edited cell.
Video Output Callbacks
OnVideoMouseLeftButtonDown (Point point)
Invoked when the left mouse button is pressed on the preview output. point.X and point.Y are normalized coordinates in the range of [-0.5…0.5] where [0,0] is the center of the screen.
OnVideoMouseRightButtonDown (Point point)
Invoked when the right mouse button is pressed on the preview output. point.X and point.Y are normalized coordinates in the range of [-0.5…0.5] where [0,0] is the center of the screen.
OnVideoMouseMove (Point point)
Invoked when the right mouse moves on the preview output. point.X and point.Y are normalized coordinates in the range of [-0.5…0.5] where [0,0] is the center of the screen.
OnVideoMouseWheel (double delta)
Invoked when the mouse wheel is turned on the preview output. delta is a floating point typically being -120/120 depending on the direction of the wheel turn and the hardware connected.
OnVideoKeyDown (char charKey, uint rawKey, KeyEventArgs eventArgs)
Invoked when a keyboard down event has taken place on the preview output. charKey contains the actual character of the pressed key, rawKey is the numeric representation of the pressed key and eventArgs is a System.Windows.Input.KeyEventArgs instance from the operating system representing the raw event information.
Exposed Objects
Console
void Write (string message)
Writes the message to the scripting console.
void WriteLine (string message)
Writes the message to the scripting console followed by a new line.
Info: When Viz Arc’s log level is set to TRACE, the strings sent to Write and WriteLine are also logged in the global log file.
MessageBox
void Show (string message)
Shows a message box with its content equal to message.
void Show (string message, string title)
Shows a message box with titled title and with its content equal to message.
// Log an error and show a message to the userConsole.WriteLine("Unable to load data")MessageBox.Show("Unable to load data", "Load Error")XmlDocument
XmlDocument allows you to read XML files or strings and aggregate data using XPath. Read more about XMLDocument and other classes here.
// create XmlDocument and load a xml from discxmlDoc = new XmlDocument()xmlDoc.Load("C:/tmp/TestData.xml")Console.WriteLine("nodes " + xmlDoc.ChildNodes.Count) // create namespace managernsmgr = new XmlNamespaceManager(xmlDoc.NameTable)// add namespacensmgr.AddNamespace("x", "http://www.contoso.com/books")// search for book nodes under the books noderoot = xmlDoc.DocumentElementnodeList=root.SelectNodes("/x:books/x:book", nsmgr)Console.WriteLine("books " + nodeList.Count)for( var book of nodeList ) Console.WriteLine("ISBN: " + book.GetAttribute("ISBN") + " title: " + book.SelectSingleNode("./x:title", nsmgr).InnerXml)The content of the sample test file C:/tmp/TestData.xml might look like this:
<?xml version="1.0" encoding="utf-8"?><books xmlns="http://www.contoso.com/books"> <book genre="novel" ISBN="1-861001-57-8" publicationdate="1823-01-28"> <title>Pride And Prejudice</title> <price>24.95</price> </book> <book genre="novel" ISBN="1-861002-30-1" publicationdate="1985-01-01"> <title>The Handmaid's Tale</title> <price>29.95</price> </book> <book genre="novel" ISBN="1-861001-45-3" publicationdate="1811-01-01"> <title>Sense and Sensibility</title> <price>19.95</price> </book></books>XMLHttpRequest
XMLHttpRequest implements the standard XMLHttpRequest interface and is the recommended way of performing HTTP requests from scripts.
Methods
void open (string method, string url, bool async)
Initializes a request. method is the HTTP verb ("GET", "POST", "PUT", "DELETE", …). With async = true (recommended) send returns immediately and completion is reported through onreadystatechange; with async = false the script blocks until the response has arrived.
void open (string method, string url, bool async, string user, string password)
Same as above, additionally passing credentials for HTTP authentication.
void setRequestHeader (string header, string value)
Adds an HTTP request header with the respective value, e.g. Content-Type or Authorization. Must be called after open and before send.
void send ()
Sends the request without a body (typical for GET).
void send (body)
Sends the request with a request body, e.g. a JSON string for POST/PUT requests (set the Content-Type header accordingly).
void abort ()
Cancels the current request.
string getResponseHeader (string header)
Returns the value of a single response header.
string getAllResponseHeaders ()
Returns all response headers as a single CRLF-separated string.
Properties
onreadystatechange [Get, Set]
Assign a function that is called every time readyState changes; check for readyState === 4 to process the finished response.
int readyState [Get]
The state of the request: 0 = uninitialized (before open), 1 = opened, 2 = headers received, 3 = loading (receiving), 4 = done.
int status [Get]
The HTTP status code of the response (e.g. 200, 404), available once the response headers have been received.
string statusText [Get]
The HTTP status text of the response (e.g. "OK").
string responseText [Get]
The response body as a string. For JSON APIs, parse it with JSON.parse(request.responseText).
responseXML [Get]
The response parsed as an XML DOM document (when the response is XML); supports DOM methods such as selectNodes and selectSingleNode, e.g. request.responseXML.selectNodes("//item").
responseBody [Get]
The raw response body as a byte array (useful for binary responses).
The exposed XMLHttpRequest implements the standard members:
open (method, url, async) / open (method, url, async, user, password)
send ( ) / send (body) — Sends the request, optionally with a body.
abort ( ) — Aborts a running request.
setRequestHeader (header, value), getResponseHeader (header), getAllResponseHeaders ( )
onreadystatechange, readyState, status, statusText
responseText, responseXML, responseBody
POST Example
var request = new XMLHttpRequest() request.onreadystatechange = function () { if (request.readyState === 4) { if (request.status === 200 || request.status === 201) { var result = JSON.parse(request.responseText) Console.WriteLine("Created with id " + result.id) } else { Console.WriteLine("Request failed: " + request.status + " " + request.statusText) } }}request.open("POST", "https://jsonplaceholder.typicode.com/posts", true)request.setRequestHeader("Content-Type", "application/json")request.send(JSON.stringify({ title: "Hello", body: "From Viz Arc", userId: 1 }))Prevent Caching
It is possible that requests through XMLHttpRequest get cached and the results of the queries might seem outdated. In order to prevent caching you can add a random number as parameter of the request.
request.open("GET", "https://jsonplaceholder.typicode.com/users?dummy="+Date.now(), true)
In this case a dummy parameter is assigned with the current EPOCH date in milliseconds.
xlAppType
This type allows you to read Excel sheets directly.
Note: This object only works if there is a local Excel installation on the same machine where Viz Arc is running.
FSO
The FSO object allows you to read, create and write files.
OpenTextFile (filename, [ iomode, [ create, [ format ]]])
iomode can be one of the following: IOMode.ForReading, IOMode.ForWriting, IOMode.ForAppending
format can be one of:
Tristate.TristateUseDefault(system default encoding, UTF-8),Tristate.TristateTrue(Unicode/UTF-16),Tristate.TristateFalse(ASCII, the default).
CreateTextFile (string fileName, bool overwrite = true, bool unicode = false) — Creates a new text file and returns a text stream for writing.
bool FileExists (string path) — Returns true when the file exists.
DeleteFile (string path) — Deletes the file.
The text stream returned by OpenTextFile/CreateTextFileexposes:
string ReadAll ()
Reads the entire file content.
Write (string text)
Writes text to the stream.
Close ()
Closes the stream.
Reading a UTF8 Encoded Text File
var file = new FSO()var stream = file.OpenTextFile("d:/testexport.txt")// orvar stream = file.OpenTextFile("d:/testexport.txt", IOMode.ForReading, false, Tristate.TristateTrue)Console.WriteLine(stream.ReadAll())xHost
The xHost object gives you access to virtually any .NET resource.
V8 Script Sample
var List = xHost.type('System.Collections.Generic.List')var DayOfWeek = xHost.type('System.DayOfWeek')var week = xHost.newObj(List(DayOfWeek), 7)week.Add(DayOfWeek.Sunday)You can even import entire assemblies:
V8 Enumerate Files in Directory
var clr = xHost.lib('mscorlib', 'System', 'System.Core', 'System.IO')dropdown_0.Clear()var dir = clr.System.IO.Directorydropdown_0.SetItems(dir.GetFiles('c:\\tmp'))// another sample that starts an external process "calc.exe"var proc = xHost.lib('System.Diagnostics.Process')proc.System.Diagnostics.Process.Start("calc.exe")In the example above, a UI dropdown element named dropdown_0 is populated with a file list contained in c:\tmp using .NET System.IO.Directory class instance.
Another example is how to convert a XML into JSON using the Newtonsoft library:
// get the library handlevar NewtonsoftLib = xHost.lib('Newtonsoft.Json')// get a reference to the JsonConvert classvar JsonConvert = NewtonsoftLib.Newtonsoft.Json.JsonConvertfunction convertXMLToJSON(fileName){ // error checking omitted for clarity // read xml document from disc: let xmlDoc = new XmlDocument() xmlDoc.Load(fileName) // set the raw XML data into the DataMap SetData("infoXML", xmlDoc.InnerXml) // use C# Newtonsoft XML serializer let jsonOut = JsonConvert.SerializeXmlNode(xmlDoc) // set the converted json into the DataMap SetData("infoJson", jsonOut)}Time
Time (also time) exposes the .NET DateTime type, e.g. Time.Now, Time.UtcNow, Time.Parse(...).
Lib
Lib (also lib) exposes the .NET mscorlib and System.Core type collections, e.g. new Lib.System.Text.StringBuilder() — a built-in alternative to xHost.lib(...) for the most common types.
host
host (also Host) exposes the ClearScript HostFunctions helpers, e.g. host.newArr(...), host.cast(...).
EnumToInt / EnumToString
EnumToInt(enumValue) and EnumToString(enumValue) convert .NET enum values to an int or string.
XmlNamespaceManager
XmlNamespaceManager is exposed alongside XmlDocument for namespace-aware XPath queries (see the XmlDocument example above, which already uses it).
Performance
The performance object provides access to performance-related information.
now ( )
Returns a high-resolution floating point value of the milliseconds elapsed since the script engine was started (see
timeOrigin). Ideal for measuring durations; for an EPOCH timestamp useDate.now()instead.
timeOrigin [Get] — The script engine's start time as milliseconds since the EPOCH (January 1, 1970 UTC);
timeOrigin + now()yields the current EPOCH time in high resolution.sleep (milliseconds, precise)
Sleep for a certain amount of milliseconds. Set precise to true when a high precision timer is required.
let timeA = Performance.now()Performance.sleep(500, true) // high perf sleep half second// do something elselet timeB = Performance.now()Console.WriteLine("timeA " + timeA)Console.WriteLine("timeB " + timeB)Console.WriteLine("time difference " + (timeB - timeA) + " ms")Console.WriteLine("timeB EPOCH " + (timeB + Performance.timeOrigin))Garbage Collection
Especially for long running scripts it might be useful to force calling the garbage collector from script.
void ForceGarbageCollection( bool collectHostItems )
Calls the .NET garbage collector and frees unreferenced memory. Set collectHostItems to true for a more aggressive cleanup including the collection of script internal objects.
Garbage collection usually is triggered automatically. In some cases it might be useful to force garbage collection to control memory usage. Note that the garbage is always collected when stopping a script or when loading a new project.
SQL Sample
If you know the assembly name of a specific type, you can instantiate it using xHost.type(name, assemblyName) method.
var queryString = "SELECT * FROM someTable"var connetionString = "Server=192.168.1.42,1433;UID=aUserID;PWD=SomePassword;"// get types using xHost.typevar SqlConnection = xHost.type('System.Data.SqlClient.SqlConnection', 'System.Data.SqlClient')var SqlCommand = xHost.type('System.Data.SqlClient.SqlCommand', 'System.Data.SqlClient')var SqlDataReader = xHost.type('System.Data.SqlClient.SqlDataReader', 'System.Data.SqlClient')connection = new SqlConnection(connetionString)connection.Open()var command = new SqlCommand(queryString, connection)var reader = command.ExecuteReader()// do something with the datawhile (reader.Read()){ // iterate over the result and print the result on the console Console.WriteLine(reader.GetString(0))} connection.Close()SQLite Sample
Another sample that uses the xHost.type function is the usage of a simple SQLite database. It is required that the SQLite libraries/DLLs are in the search path of the system or in the same directory as the Viz Arc executable.
var SQLiteConnection = xHost.type('System.Data.SQLite.SQLiteConnection', 'System.Data.SQLite')// those two below are not needed for this sample as they dont get instantiated explicitylvar SQLiteDataReader = xHost.type('System.Data.SQLite.SQLiteDataReader', 'System.Data.SQLite')var SQLiteCommand = xHost.type('System.Data.SQLite.SQLiteCommand', 'System.Data.SQLite')function ReadData(conn){ // create q query sqlite_cmd = conn.CreateCommand() sqlite_cmd.CommandText = "SELECT Name FROM Artist LIMIT 10;" // read first 10 artists of the table // execute the query sqlite_datareader = sqlite_cmd.ExecuteReader(); while (sqlite_datareader.Read()) { // iterate over the result and print the result on the console Console.WriteLine(sqlite_datareader.GetString(0)); }}function testSQLiteDB(){ // create a new connection specifying the database file name and the version // sample database can be found here https://github.com/lerocha/chinook-database conn = new SQLiteConnection("Data Source=C:\\tmp\\Chinook.db;Version=3;") try { // Open the connection: conn.Open() // read some data ReadData(conn) // close the connection conn.Close() } catch (ex) { Console.WriteLine("error in SQLite query " + ex) }}Global.OnInit = function (){ testSQLiteDB()}TcpSend
The TcpSendAsync method, is used to send a short message to any host on any port of the network.
Task<string> TcpSendAsync (string hostname, int port, string command, int timeoutInMs = 1000)
Send command to hostname on port. If the parameter timeoutInMs is not specified, a default timeout of 1 second is used.
Global.OnButtonPressed = async function (id){ if( id == "sendTcp"){ let response = await TcpSendAsync("192.168.1.22", 1234, "say something\0", 5000) Console.WriteLine("response from client " + response) }}HtmlAgility Example
The classes HtmlDocument and HtmlWeb are exposed by the HtmlAgility library and enable parsing and data extraction of html pages.
//sample to use HtmlDocument class from HtmlAgility var doc = new HtmlDocument() doc.Load("c:/tmp/HtmlAgilityTest.html") for (var table of doc.DocumentNode.SelectNodes("//table")) { Console.WriteLine("Found: " + table.Id) for (var row of table.SelectNodes("tr")) { for (var cell of row.SelectNodes("th|td")) Console.Write(cell.InnerText + " ") Console.WriteLine("") } } // sample to use HtmlWeb class from HtmlAgility var html = "http://html-agility-pack.net/" var web = new HtmlWeb() var htmlDoc = web.Load(html) var node = htmlDoc.DocumentNode.SelectSingleNode("//head/title") Console.WriteLine("Node Name: " + node.Name + "\n" + node.OuterHtml)The contents of the file from the sample above c:/tmp/HtmlAgilityTest.html:
HTML Sample with Table
<!DOCTYPE html><html><style> table, th, td { border: 1px solid black; }</style><body> <h2>A HTML table to test HTML Agility</h2> <table style="width:100%" id="dataTable"> <tr> <th>Name</th> <th>Number</th> <th>Country</th> </tr> <tr> <td>Athlete A</td> <td>42</td> <td>Italy</td> </tr> <tr> <td>Athlete B</td> <td>34</td> <td>Japan</td> </tr> </table> <p>Here is some more text</p></body></html>Read more about HtmlAgility here.
Main Script-only
There are functionalities that are specific to Viz Arc's main script:
Canvas Tabs Handling
void SetActionsSelectedTab (string tabName )
Looks for a tab named tabName and sets it as active.
void SetActionsSelectedTab (int tabIndex)
Sets the Action selected tab to the tab at tabIndex index.
string GetActionsSelectedTabName ( )
Returns the currently selected tab's name.
int GetActionsSelectedTabIndex ( )
Returns the index of the currently selected action canvas tab (-1 when no canvas is available).
string[] GetActionsTabs ( )
Returns a string array with all tab names.
Action Template Handling
Arc's main scripts allows the user to interact with template actions on the action canvas.
void PreviewSelectedTemplate ( )
Previews the currently selected template action.
void ExecuteSelectedTemplate ( )
Executes the currently selected template action.
void UpdateSelectedTemplate ( )
Updates the currently selected template action.
void ContinueSelectedTemplate ( )
Continues the currently selected template action.
void StillPreviewSelectedTemplate ( )
Generates a still preview of the currently selected template action.
Note: The method presented only works when one and only one action (template action) is selected on the action canvas.
Callbacks
PreActionExecute (string actionName)
Called whenever an is executed and before the actual execution occurs.
actionName is the name of the action that is being executed.
PosActionExecute (string actionName)
Called whenever an is executed and after the actual execution occurs.
OnInit ( )
Called when the main script is started (User clicks on the Start button).
Template Script-only
The template script is a specific version that is used on the template designer and on the template action.
Action/Designer Handling
void ExecuteTemplate ( )
Executes the owner template action or loaded template in the designer.
void ContinueTemplate ( )
Continues the owner template action or loaded template in the designer.
void OutTemplate ( )
Takes out the owner template action or loaded template in the designer.
void UpdateTemplate ( )
Updates the owner template action or loaded template in the designer.
void UpdateTemplate (string COs = null)
Updates the owner template action or loaded template in the designer. The parameter COs is a space separated list of Control Object ID's that shall be updated. For large templates containing a big amount of ControlObjects this is a very efficient alternative whenever only a small part in the scene needs to be updated. For example, UpdateTemplate("currentScore totalScore") updates only the two ControlObjects with id "currentScore" and "totalScore".
void UpdateTemplate ("BP_Name.VariableName")
Updates the owner template action or loaded template in the designer. This method can be used if the scene is in Unreal Engine. For large templates containing a large amount of variables, this is a very efficient alternative when only a variable in the blueprint needs to be updated.
void UpdateTemplate ("BP_Name", ["VariableName1", "VariableName2", ecc...])
Updates the owner template action or loaded template in the designer. This method can be used if the scene is in Unreal Engine. For large templates containing a large amount of variables, this is a very efficient alternative when only a few variables in the blueprint need to be updated.
void PreviewTemplate ( )
Previews the owner template action or loaded template in the designer.
void PreviewExecuteTemplate ( )
Executes the owner template action or loaded template in the designer to the preview channel.
void PreviewContinueTemplate ( )
Continues the template's animation on the preview channel.
void PreviewOutTemplate ( )
Takes the template out on the preview channel.
void PreviewUpdateTemplate (string COs = null)
Updates the owner template action or loaded template in the designer to the preview channel. The parameter COs is a space separated list of Control Object ID's that shall be updated. For large templates containing a big amount of ControlObjects this is a very efficient alternative whenever only a small part in the scene needs to be updated. For example, UpdateTemplate("currentScore totalScore") updates only the two ControlObjects with id "currentScore" and "totalScore".
bool IsActionTemplateSelected ( )
Returns true when this template is currently selected on the action canvas.
string GetSavedBy( ), string GetSavedOn( ), string GetVersion( ), string GetSavedAt( )
Return the template's save metadata (author, host, Viz Arc version and save time).
Properties
BaseAction ThisAction
Returns the script accessor of this template. ThisAction might be null when using the template editor.
if( ThisAction ){ // set the action's name ThisAction.Name = "Hello" // set the action's tooltip description ThisAction.Description = "Hello Description"}Payloads
A payload is a snapshot of a template's data — its linked-parameter / control-object values — stored as a string. A payload can be dragged onto a playlist as a payload item, so one template action can produce many playlist entries that each replay a different saved state. Payloads are also how the MSE (Media Sequencer) and the REST API push values into a template.
Two payload string formats are auto-applied by Arc, detected by the first character: JSON (starts with {) is a flat map of controlObjectId → value and is the normal Arc format; VDF XML (starts with <) is the Vizrt Data Format used for MSE integration. A payload is not limited to these, however: a template that implements its own OnSetPayload can store and interpret a payload in any format it likes (see Custom Payloads).
{ "imageLeft": "VIZ/Images/logo.png", "title": "Hello World", "score": 3 }<payload xmlns="http://www.vizrt.com/types" model="modelUri"> <field name="title"><value>Hello World</value></field></payload>Capturing a Payload
string GetTemplatePayload ( )
Captures the current values of all of the template's linked control objects and returns them as a JSON payload string. The keys are control object IDs (the linked control object's
objectID), not parameter names, and it recurses into panel children.
void SetPayload (string payload)
Stores payload (a JSON string) on the template's drag badge, so it becomes the payload of the playlist item created when the badge is dragged onto a playlist.
void SetPayloadLabel (string label)
Sets the human-readable label shown on the drag badge and on the resulting playlist item.
void SetPayloadColor (string hexColor)
Sets the color used for the payload's playlist row, e.g.
"#FF4400".
string GetPayloadColor ( )
Returns the payload's row color.
string GetLabelFromControlObjects (string ids)
Builds a label automatically from the current values of the named control objects, joined with slashes. ids is a space-separated list of control object IDs — e.g.
GetLabelFromControlObjects("title score")returns"Hello World/3".
Capturing Example
// Capture the current values of all linked control objects as a JSON payload string.var payload = GetTemplatePayload() // -> '{"imageLeft":"...","title":"..."}'// Store the payload and a label on the template's drag badge; these become the// payload and label of the playlist item created when the badge is dragged out.SetPayload(payload)SetPayloadLabel("Slide 1 - Hello World")// Or build the label automatically from selected control object values (slash-joined).SetPayloadLabel(GetLabelFromControlObjects("title score")) // -> "Hello World/3"Applying a Payload
void SetTemplatePayload (string payload)
Applies a JSON payload to the template's linked parameters. Unlike the auto-apply path used when a playlist row fires, this does let OnParameterChanged callbacks fire (it is the inverse of GetTemplatePayload).
bool SavePayloadToBoundRow ( )
Saves the current editor values back to the playlist row the template editor was opened from. Returns true on success.
Applying Example
// Apply a JSON payload to the linked parameters. Unlike the auto-apply path,// this lets OnParameterChanged callbacks fire.SetTemplatePayload('{"title":"Updated"}')The OnSetPayload Callback
When a playlist payload item is previewed or executed, Arc calls the template’s OnSetPayload callback (a Global callback assigned in the template script):
Global.OnSetPayload = function(payload, isPreview) { // payload : the stored payload string (JSON or VDF XML) // isPreview : true -> the row was selected/previewed (do NOT go on air) // false -> the row is being executed (execute follows immediately) var data = JSON.parse(payload) SetParameterValue("titleParam", data.title) // apply however you like}Resolution order when a payload item fires:
If the script declares OnSetPayload, it is called and is fully responsible for applying the payload.
Otherwise, if the action installed a custom (native) payload handler, that handles it.
Otherwise Arc auto-applies the payload to the linked parameters (JSON or VDF), with OnParameterChanged callbacks suppressed.
So if you only need the standard “restore linked parameter values” behaviour you do not need to implement OnSetPayload at all — leave it out and Arc restores the state automatically.
Two methods allow you to use the built-in default handler within the OnSetPayload callback:
void BaseSetPayload ( )
Applies Viz Arc's default payload-restore behavior to the payload currently being applied. Call it from within OnSetPayload when you want the default handling in addition to (or after) your custom logic.
void BaseSetPayload (string payload)
Same as above, applying the given payload string instead.
Custom Payloads
A payload is just an opaque string as far as the playlist is concerned — it does not have to be a control-object JSON map or VDF XML. When a template implements its own OnSetPayload, that handler receives the stored payload string verbatim and is fully responsible for interpreting it, so the payload can be in any format you choose (a custom token, CSV, a URL, your own JSON shape, and so on). The built-in JSON / VDF auto-detection only governs Arc's auto-apply path, which is used when no OnSetPayload is declared.
Because the payload content is entirely under script control, the mechanism is not tied to Viz templates or VDF. It works the same way for Flowics templates (and any other template type): store whatever string the template needs with SetPayload, and parse it in OnSetPayload when the row is previewed or executed.
Custom Payload Example
// Store any custom string you like as the payload - here a simple "key=value" line.SetPayload("matchId=42;home=GSW;away=NYK")SetPayloadLabel("GSW vs NYK")// Interpret it yourself when the playlist row is previewed/executed. The format is// entirely your own; Arc does not try to auto-apply it because OnSetPayload is declared.Global.OnSetPayload = function(payload, isPreview) { var parts = {} payload.split(";").forEach(function(kv) { var p = kv.split("=") parts[p[0]] = p[1] }) SetParameterValue("homeTeam", parts.home) SetParameterValue("awayTeam", parts.away)}MSE / VDF Payloads
string GetMSEVdfPayload (string modelUri)
Builds an MSE-compatible VDF XML payload from the current control object values. modelUri is the MSE model URI. Returns the
<payload>XML string.
string GetCurrentPayloadVdf ( )
Builds and returns a VDF payload document from the template's current parameter values.
bool SetVdfPayload (string vdfXml)
Applies a VDF XML payload to the template's linked parameters. Returns true on success, false otherwise.
MSE / VDF Example
// Build MSE-compatible VDF XML from the current control object values.var vdf = GetMSEVdfPayload("modelUri")// Apply a VDF XML payload to the linked parameters.SetVdfPayload(vdf)Notes
Payloads operate on the template's linked parameters / control objects.
GetTemplatePayload keys are control object IDs (the linked control object's
objectID), not parameter names; it recurses into panel children.Preview vs execute:
isPreview === truemeans selected/cued — apply values but put nothing on air;isPreview === falseis followed immediately by the action's execute.Auto-apply suppresses callbacks (OnParameterChanged does not fire), whereas SetTemplatePayload does fire them — choose accordingly.
Format auto-detection applies to Arc's auto-apply path only: a payload starting with
{is treated as JSON,<as VDF XML, and anything else is ignored. A template that implements OnSetPayload receives the raw payload string and may use any format (see Custom Payloads).Payloads are not Viz- or VDF-specific; custom payloads work in Flowics templates and any other template type.
The REST API can also carry payloads (for example a
vdfPayloadargument when opening a template, and a playlistpayloadRowendpoint) — see the REST API reference, which is outside script scope.
Control Object Handling
The template script allows the user to interact with the template's control objects, only supported for Viz and Flowics templates.
void SetControlObject (string objectID, dynamic value)
Sets the control object with id equal to objectID's value to value. The set object's value is sent on template execute/update.
ControlObject ID's set by this methods which have not been present in the payload during template creation, are added dynamically.
Note: SetControlObject only works on control objects that aren't already linked to UI parameters.
bool HasControlObject (string objectID)
Returns true when the objectId has been assigned wither through the UI or through code using the SetControlObject method, otherwise it returns false.
string GetLinkedControlObject (string parameterName)
Returns the ID of the control object the given parameter is linked to (empty when unlinked).
void SetLayerAlternative (string layerName, string value)
Sets the alternative to be used for the Transition Logic layer layerName when building combo payloads.
string GetLayerAlternative (string layerName)
Returns the alternative currently set for the given layer.
void ClearLayerAlternative (string layerName)
Clears the alternative for the given layer.
Template Channels Handling
The template script allows the user to change the program output channel.
void SetSelectedChannel (string name)
Sets the selected program output channel to name.
void SetSelectedChannel (ScriptingChannel channel)
Sets the template's selected channel from a channel object (e.g. obtained through GetSelectedProfile().GetChannel(...)).
ScriptingChannel GetSelectedChannel ( )
Returns the currently selected program channel of the template action.
ScriptingChannel
The ScriptingChannel class is used for finer control on the Engines contained in the channel.
Properties
Name
The channel's name.
Count
The number of Engines in the channel.
Methods
void SendSingleCommand (string command)
Sends command to all the Engines in the channel.
void SendMultipleCommands (string[] commands)
Sends all the input commands to all the Engines in the channel.
void SendToSMM (string key, string value, bool doEscape)
Sends key-value pair to Shared Memory to all Engines contained in the channel. doEscape specifies whether the value string is escaped.
void SendToSMM (string key, string value, bool doEscape, string destination)
destination can be either SYSTEM, COMMUNICATION or DISTRIBUTED
void SendToSMM (string key, string value)
Two-argument form of SendToSMM, the value is escaped by default.
ScriptingEngine GetEngine (int index) / ScriptingEngine GetEngine (string name)
Returns an individual Engine of the channel by index or name (also available through the indexer, e.g.
channel[0]). See the Engine section for the members of the returned object.
Template Scene Handling
The template script allows the user to set the scene that should be loaded when executing.
void SetSceneFullpath (string fullpath = null)
The input fullpath is the value that is sent to the Engine when executing the template. When no full path is provided the user config value is removed and the original attached scene is used.
string GetBaseContainerPath ( )
Returns the current base container path where the root control object is located.
bool SetBaseContainerPath (string basePath)
Sets the base container path where the root control object is located. This might be useful to redirect the destination of the ContolObjects to a different container in the same scene.
string GetDirector ( )
Gets the current director executed on Execute or on Continue.
bool SetDirector (string dir)
Sets the director executed on Execute or on Continue.
Template Action Configuration
bool IsCommandHeaderVisible
Indicates whether the CommandHeader should be visible on the template action.
bool UpdateOnSelected
When this flag is set, the script callbacks are only triggered when the template action is selected on the action canvas (blue border).
Callbacks
OnCreated ( )
Called when the template script is executed (when the template action is created and when the template opened on the designer is started).
OnDestroyed ( )
Called when template is being stopped/destroyed. Can be used for cleanup, save state, stopping/canceling timers.
OnShow ( )
Called when the template is shown (when the template action's pop-up is opened, when the action becomes embedded and when the template opened on the designer is started).
OnExecute ( )
Called when the template is executed.
OnPreviewExecute ( )
Called when the template is executed to the preview channel.
OnContinue ( )
Called when the template is continued.
OnPreviewContinue ( )
Called when the template is continued to the preview channel.
OnUpdate ( )
Called when the template is updated.
OnPreviewUpdate ( )
Called when the template is updated to the preview channel.
OnOut ( )
Called when the template is taken out.
OnPreviewOut ( )
Called when the template is taken out on the preview channel.
OnPreview ( )
Called when the template is previewed.
Note: The OnDestroyed callback has a maximum execution time of five seconds. If it exceeds this, the template is forcefully stopped.
Common Callbacks
Callbacks that can be used in the global script and template scripts
OnVideoMouseLeftButtonDown (point)
Called when the user pressed the left mouse button on the video output.
point.X normalized value in the range [-0.5, 0.5]
point.Y normalized value in the range [-0.5, 0.5]
OnVideoMouseRightButtonDown (point)
Called when the user pressed the right mouse button on the video output.
OnVideoMouseMove (point)
Called when the user moved the mouse on the video output.
OnVideoMouseWheel (delta)
Called when the user rolled the mouse wheel on the video output.
delta is a floating point value, typical values are -120.0 for mouse wheel down and 120.0 for mouse wheel up.
OnTrackerAction (string action)
Called on certain Object Tracker events. the action parameter determines the type of event:
take: Triggered when Object Tracker is taken On Air.
takeout: Triggered when Object Tracker is taken Off Air.
preview: Triggered when Object Tracker preview is taken.
previewout: Triggered when Object Tracker preview is taken out.
newTracker <index>: Triggered whenever a new object has been selected for tracking. index is 1 based.
lostTracker <index>: Triggered whenever a tracked object has lost tracking. index is 1 based.
Sample Usage of Object Tracker Script API
Global.OnTrackerAction = function (action){ Console.WriteLine("tracker action " + action ) if( action == "take" ) GetAction("DATA").Execute() else if( action.startsWith("newTracker" ) ){ // we want to take off air whatever is On Air when we select a new tracked object TakeOutTracker() Console.WriteLine("OFF AIR" ) }}OnArenaPosition (double screenX, double screenY, double worldX, double worldY, double worldZ)
Called when the user clicks on the Viz Arena view with the positioning tool.
screenX and screenY are the screen coordinates of the mouse click. The lower left corner of the arena screen is the origin (0,0).
wolrdX, worldY and worldZ are Viz Engine world coordinates, the units (default meters) are the same as for the selected Viz Arena project.
Parameters
Parameters are the base components of Viz Arc's scripting. A list of all existing parameters types and their associated properties is presented below.
Base Parameters Functionality
The following properties and methods are shared among all parameters
string Label [Get, Set]
Gets/sets the label that is displayed on the UI.
bool IsEnabled [Get, Set]
Gets/sets the enabled status of the parameter. Disabled parameters cannot be interacted with and do not trigger events.
bool IsVisible [Get, Set]
Sets whether the parameter is visible. Invisible parameters are visible (displayed as grayed out) only while editing (and scripts are not running).
double X [Get, Set]
Gets/sets the horizontal position of the parameter on the canvas.
double Y [Get, Set]
Gets/sets the vertical position of the parameter on the canvas.
double Width [Get, Set]
Gets/sets the width of the parameter.
double Height [Get, Set]
Gets/sets the height of the parameter.
void SetColor (byte r, byte g, byte b, byte a = 255)
Sets the parameter's color to the input RGBA color.
string Color
Gets/sets the parameter's selected color in Hex format, for example, #FF0A0A8C (#RRGGBBAA).
int ColorR
Gets/sets the parameter's selected red color value in the range [0, 255].
int ColorG
Gets/sets the parameter's selected green color value in the range [0, 255].
int ColorB
Gets/sets the parameter's selected blue color value in the range [0, 255].
int ColorA
Gets/sets the parameter's selected alpha value in the range [0, 255].
string Tooltip [Get, Set]
Gets/sets the tooltip of the UI element.
string LinkedCO [Get]
The name of the associated ControlObject (Template Scripting only).
void UpdateDataLink()
Forces an explicit evaluation of the DataLink expression associated with this parameter.
int ZIndex [Get, Set]
Gets/sets the parameter's z-order on the canvas.
string FontColor [Get, Set]
Gets/sets the parameter's font color as hex string (setting it enables the custom font color).
bool UseCustomFontColor [Get, Set]
Enables/disables the custom font color.
bool Bold / bool Italic / bool Underline [Get, Set]
Gets/sets the font style flags.
string FontStyle [Get, Set]
Gets/sets the font style as a string of flags.
int FontSize [Get, Set]
Gets/sets the font size (clamped to 1–100).
string LinkedDataKey [Get, Set]
Gets/sets the DataMap key the parameter is linked to (see UpdateDataLink).
string LinkedDataQuery [Get, Set]
Gets/sets the query/filter applied to the linked data.
A sample use of the LinkedCO property:
Global.OnParameterChanged = function (id){ // get linked ControlObject id associated to parameter 'id'. It is null if it's not linked to any CO. let linkedCO = GetParameter(id).LinkedCO if( linkedCO ) { Console.WriteLine("Changed: " + id + ", Linked Control Object ID: " + linkedCO) // live update the template UpdateTemplate(linkedCO) }}Layout
The layout parameters allow the user to organize and improve the usability of a script/template.
Panel
BaseParameter [ ] Children [Get]
Returns an array with all of the panel's children.
BaseParameter GetParameter (string parameterID)
Tries to find a child with id equal to parameterID. Returns it if successful.
Tabs
string Value [Get, Set]
Set: Attempts to find a tab with its name equal to the input. If found, sets it as selected tab.
Get: Returns the name of the selected tab.
bool AllowReordering
Whether a user can reorder the tabs.
int SelectedIndex [Get, Set]
Gets/sets the index of the selected tab.
Info
Gets/sets the info text that displays on the parameter.
Label
TextColor
string TextColor [Get, Set]
Gets/sets the labels text color in Hex format, for example, #FF0A0A8C (#RRGGBBAA).
Dialogs
Color
int R [Get]
Gets the value of the red component in the range [0, 255].int G [Get]
Gets the value of the green component in the range [0, 255].int B [Get]
Gets the value of the blue component in the range [0, 255].int A [Get]
Gets the value of the alpha component in the range [0, 255].double RPercent [Get]
Gets the value of the red component in the range [0, 1].double GPercent [Get]
Gets the value of the green component in the range [0, 1].double BPercent [Get]
Gets the value of the blue component in the range [0, 1].double APercent [Get]
Gets the value of the alpha component in the range [0, 1].void SetR (int R)
Sets the red component in the range [0, 255].void SetG (int G)
Sets the green component in the range [0, 255].void SetB (int B)
Sets the blue component in the range [0, 255].void SetA (int A)
Sets the alpha component in the range [0, 255].void SetRGB (int R, int G, int B)
Sets the red, green and blue components in the range [0, 255].void SetRGBA (int R, int G, int B, int A)
Sets the red, green, blue and alpha components in the range [0, 255].void SetRPercent (double R)
Sets the red component in the range [0, 1].void SetGPercent (double G)
Sets the green component in the range [0, 1].void SetBPercent (double B)
Sets the blue component in the range [0, 1].void SetAPercent (double A)
Sets the alpha component in the range [0, 1].void SetRGBPercent (double R, double G, double B)
Sets the red, green and blue components in the range [0, 1].void SetRGBAPercent (double R, double G, double B, double A)
Sets the red, green, blue and alpha components in the range [0, 1].
DateTime
The DateTime parameter provides comprehensive date and time selection with extensive scripting capabilities including component accessors, formatting helpers, Unix timestamp support, and range constraints.
Gets/sets the date/time as ISO 8601 string (for example, "2025-01-15T14:30:00").
string MinDate [Get, Set]
Gets/sets the minimum selectable date (ISO format).
string MaxDate [Get, Set]
Gets/sets the maximum selectable date (ISO format).
bool EnableTime [Get, Set]
Gets/sets whether time selection is enabled (not just date).
bool ShowSeconds [Get, Set]
Gets/sets whether seconds are shown in the time picker.
Component Accessors (Read-Only)
int Year [Get]
Gets the four-digit year (for example, 2025).
int Month [Get]
Gets the month (1-12).
int Day [Get]
Gets the day of month (1-31).
int Hour [Get]
Gets the hour (0-23).
int Minute [Get]
Gets the minute (0-59).
int Second [Get]
Gets the second (0-59).
Methods
DateTime GetDateTime()
Gets the value as a .NET DateTime object.
void SetDateTime(DateTime dt)
Sets the value from a .NET DateTime object.
void SetDate(int year, int month, int day)
Sets the date portion while preserving the time.
void SetTime(int hour, int minute, int second = 0)
Sets the time portion while preserving the date.
long GetUnixTimestamp()
Gets the value as Unix timestamp (seconds since January 1, 1970).
void SetFromUnixTimestamp(long timestamp)
Sets the value from a Unix timestamp.
string GetDateString()
Gets a formatted date string.
string GetTimeString()
Gets a formatted time string.
string GetDateTimeString()
Gets a formatted date and time string.
Examples
Basic Date/Time Access:
Global.OnCreated = function() { // Set initial value to now eventDateTime.SetDateTime(new Date())}Global.OnParameterChanged = function(id) { if (id === "eventDateTime") { // Access individual components Console.WriteLine("Year: " + eventDateTime.Year) Console.WriteLine("Month: " + eventDateTime.Month) Console.WriteLine("Day: " + eventDateTime.Day) Console.WriteLine("Hour: " + eventDateTime.Hour) Console.WriteLine("Minute: " + eventDateTime.Minute) Console.WriteLine("Second: " + eventDateTime.Second) // Get ISO string Console.WriteLine("ISO: " + eventDateTime.Value) }}Set Date and Time Separately:
Global.OnCreated = function() { // Set date to January 15, 2025 (preserves current time) eventDateTime.SetDate(2025, 1, 15) // Set time to 14:30:00 (preserves current date) eventDateTime.SetTime(14, 30, 0)}Unix Timestamp Conversion:
Global.OnCreated = function() { // Set from Unix timestamp let timestamp = 1704067200 // Jan 1, 2024 00:00:00 UTC eventDateTime.SetFromUnixTimestamp(timestamp) Console.WriteLine("Set to: " + eventDateTime.GetDateTimeString())}function getTimestamp() { // Get current value as Unix timestamp let ts = eventDateTime.GetUnixTimestamp() Console.WriteLine("Unix timestamp: " + ts) // Send to external system SetData("eventTimestamp", ts)}function syncWithServer() { // Receive timestamp from server let serverTimestamp = arc.GetData("serverTime") if (serverTimestamp) eventDateTime.SetFromUnixTimestamp(serverTimestamp)}Countdown Timer:
let countdownInterval = null;Global.OnCreated = function() { // Set target date targetDateTime.SetDate(2025, 12, 31) targetDateTime.SetTime(23, 59, 59) // Start countdown countdownInterval = setInterval(function() { updateCountdown(); }, 1000)}Global.OnDestroyed = function() { if (countdownInterval) clearInterval(countdownInterval);}function updateCountdown() { let now = new Date() let target = new Date(targetDateTime.Value) let diff = target - now // milliseconds if (diff <= 0) { countdownText.Value = "EVENT STARTED!" clearInterval(countdownInterval) return } // Convert to days, hours, minutes, seconds let days = Math.floor(diff / (1000 * 60 * 60 * 24)) let hours = Math.floor((diff % (1000 * 60 * 60 * 24)) / (1000 * 60 * 60)) let minutes = Math.floor((diff % (1000 * 60 * 60)) / (1000 * 60)) let seconds = Math.floor((diff % (1000 * 60)) / 1000) countdownText.Value = days + "d " + hours + "h " + minutes + "m " + seconds + "s"}Date Arithmetic:
function addDays(days) { let current = new Date(eventDateTime.Value) current.setDate(current.getDate() + days) eventDateTime.SetDateTime(current)}function addHours(hours) { let current = new Date(eventDateTime.Value) current.setHours(current.getHours() + hours) eventDateTime.SetDateTime(current)}Global.OnButtonPressed = function(id) { if (id === "addOneDay") addDays(1) else if (id === "addOneHour") addHours(1) else if (id === "setToNow") eventDateTime.SetDateTime(new Date()) else if (id === "setToMidnight") eventDateTime.SetTime(0, 0, 0)}Working with JavaScript Date Objects:
Global.OnCreated = function() { // DateTime parameter value is ISO string, compatible with JS Date let jsDate = new Date(eventDateTime.Value) Console.WriteLine("JavaScript Date: " + jsDate) // Set from JavaScript Date let tomorrow = new Date() tomorrow.setDate(tomorrow.getDate() + 1) eventDateTime.Value = tomorrow.toISOString()}Note: The Value property always uses ISO 8601 format ("2025-01-15T14:30:00"), which is compatible with JavaScript's Date constructor and most APIs.
Note: DateTime values are stored without explicit timezone information. If you need timezone-aware dates, handle timezone conversion in your script.
Note: Year, Month, Day, Hour, Minute, and Second properties are read-only. Use SetDate() or SetTime() methods to modify them.
Directory
Gets/sets the selected directories fullpath.
Set: The input value must be a valid directory in the file system.
File
Gets/sets the selected file's fullpath.
bool WatchFile [Get, Set]
Enable/disable the watchfile feature.
bool ReadRawContent [Get, Set]
Set to true if the raw file content should be read into the DataMap. Set to false if it is an excel or csv file.
string Separator [Get, Set]
The separator when reading a csv file. Default is “,”.
string Sheet [Get, Set]
The name of the excel sheet to be read.
string StartCell [Get, Set]
The name of the start cell to read the content from (for example, “B5”).
string EndCell [Get, Set]
The name of the end cell to read the content from (for example, “H11”).
bool HasHeaders [Get, Set]
Indicates whether or not the first row of the table content is a header row.
bool ConvertToJson [Get, Set]
Whether to convert the content of the file into a json format.
string DataMapTarget [Get, set]
The name of the key to be used in the DataMap to send the content of the file to.
void ReloadFile()
Forces to read the content of the file. Might be used when WatchFile is disabled.
Asset
Get: Returns the selected asset's full path.
Set: The input path needs to be valid. The image is loaded asynchronously.
string Prefix [Get, Set]
The prefix to be added to the Value when sent to the engine.
string Postfix [Get, Set]
The postfix to be added to the Value when sent to the engine.
async void SetImage (string name)
An awaitable method to set an image name.
void EraseImage( )
Clears the current image (assigning null to
Valuehas no effect — use this instead).
Note: Valid input values are: Graphic Hub items (Image, Geom, Material), Media service links (http://...) or local file system files.
WebView
This component lets you view a web page.
Gets/sets the URL of the web page to be visualized.
void Reload ()
Reloads the current page.
void GoBack ()
Navigates back in history.
void GoForward ()
Navigates forward in history.
void ExecuteJavascript (string method)
Invokes method on the currently loaded web page.
void ExecuteJavascript (string method, params object[] args)
Invokes method with args as arguments on the currently loaded web page.
Note: The browser used for rendering is based on CEF. It might not play all video codecs.
A sample html file that might be loaded in a WebView:
<!DOCTYPE html><html><body><button onclick="DataMapButton()">Set Data Map</button><input type="text" id="someText" oninput="wroteSomeText()"><p id="demo"></p><script>function DataMapButton() { let text = document.getElementById("someText").value; // set the data map variable 'fromWebPage' to the entered value arc.SetData("fromWebPage", text);}function wroteSomeText() { let text = document.getElementById("someText").value; document.getElementById("demo").innerHTML = "You wrote: " + text; // interact with arc and set the parameter "text_0" to the value just entered arc.SetParameterValue("text_0", text);}function someFunction1(){ alert("You invoked someFunction1!")}function someFunction2(para1, para2){ alert("You invoked someFunction2 with arguments: " + para1 + " " + para2)}</script></body></html>Note the arc object which gets injected and gives access to all scripting methods available in Viz Arc. For example, arc.SetData("matchResult", "0:1") sets a variable on the DataMap.
A Viz Arc template interacting with the html page above after clicking the Execute Method 2 button:
The code of the Viz Arc template might look like this, note the ExecuteJavascript methods that allow you to interact with the web page.
Global.OnButtonPressed = function (id){ switch( id ) { case "reloadBrowser": webview_0.Reload() break case "backBrowser": webview_0.GoBack() break case "forwardBrowser": webview_0.GoFoward() break case "exe1": webview_0.ExecuteJavascript("someFunction1") break case "exe2": webview_0.ExecuteJavascript("someFunction2", "one", "two") break }}Bool
bool Value [Get, Set]
Gets/sets the parameter's bool value.
Button
void Click ( )
Triggers a click event on the button parameter.
string BackgroundImage
Gets/sets the path to the background image. It can be either a local file path (for example, c:/tmp/someimage.png) a Graphic Hub path (for example, IMAGE*/project/A/imageButton) or a URL (for example, http://storage.internal/image.jpg).
string ImageMargin
Gets/sets the margins in pixels of the background image. Specify either one, two or four comma separated margins. A value of
5applies a margin of 5 pixels in all directions, a value of5, 3applies a margin of 5 pixels on the left and right and a margin of 3 at the top and bottom. A value of1, 2, 3, 4applies the respective margins in the order left, top, right and bottom.
string DirectorPath
Gets/sets the Stage Director to be executed on click. For example, $Director$SubDirector
string DirectorExecute
Gets/sets the type of action type to execute on click. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
string ActionExecute
Gets/sets the name or UUID of the action to be executed on click.
bool TakeEngineSnapshotSync (width = -1, height = -1, withAlpha = true, timeoutMS = 5000)
Takes a snapshot from Viz Engine. Viz Engine is selected from the currently selected channel or in template designer it is taken from the Viz Editing Engine. This command works only with Viz Engine.
width of the snapshot in pixels.
-1uses the button's current width.0captures the full frame width.height of the snapshot in pixels.
-1uses the button's current height.0captures the full frame height.withAlpha
true, captures with alpha channel. Whenfalse, captures without alpha.timeout in milliseconds for the snapshot operation.
async <bool> TakeEngineSnapshot( width = -1, height = -1, withAlpha = true, timeoutMS = 5000 )
awaitable method of the TakeEngineSnapshotSync.
void ClearSnapshot()
Clears the snapshot background image and resets all related properties to their default values.
Toggle Button
Alias for IsChecked.
void SetCheckedColor (byte r, byte g, byte b, byte a = 255)
Sets the toggle's color to the input RGBA color when the toggle is in it's checked state.
string CheckedColor
Gets/sets the toggle's color in Hex format, for example, #FF0A0A8C (#RRGGBBAA) when the toggle is in it's checked state.
int CheckedColorR
Gets/sets the toggle's red color value in the range [0, 255] when the toggle is in it's checked state.
int CheckedColorG
Gets/sets the toggle's green color value in the range [0, 255] when the toggle is in it's checked state.
int CheckedColorB
Gets/sets the toggle's blue color value in the range [0, 255] when the toggle is in it's checked state.
int CheckedColorA
Gets/sets the toggle's alpha value in the range [0, 255] when the toggle is in it's checked state.
string CheckedLabel
Gets/sets the label text displayed when the button is in the checked state.
string CheckedImage [Get, Set]
Gets/sets the background image shown while the button is checked.
string ImageMargin
bool IsChecked
Gets/sets the toggle button's state to checked or unchecked.
string ContainerPath
Gets/sets the Viz scene container path (for example, $object$ALL$left) to be used when VisibilityCheckd/VisibilityUncheckd or KeyChecked/KeyUnchecked actions are set.
string DirectorPath
Gets/sets the Stage Director path (for example, $Director$SubDirector)to be executed when DirectorCheckd/DirectorUnchecked actions are set.
string ActionChecked
The action name or uuid to be executed when the toggle button gets checked.
string ActionUnchecked
The action name or uuid to be executed when the toggle button gets unchecked.
string VisibilityChecked
Gets/sets the visibility of the container specified in ContainerPath when the toggle button gets checked. Possible values are <nothing>, ON or OFF.
string VisibilityUnchecked
Gets/sets the visibility of the container specified in ContainerPath when the toggle button gets unchecked. Possible values are <nothing>, ON or OFF
string DirectorChecked
Gets/sets the action to be executed on the director specified in DirectorPath when the toggle gets checked. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
string DirectorUnchecked
Gets/sets the action to be executed on the director specified in DirectorPath when the toggle gets unchecked. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
string KeyChecked
Gets/sets the key action of the container specified in ContainerPath when the toggle button gets checked. Possible values are <nothing>, ACTIVE, INACTIVE, COMBINE WITH BG ON, COMBINE WITH BG OFF.
string KeyUnchecked
Gets/sets the key action of the container specified in ContainerPath when the toggle button gets un checked. Possible values are <nothing>, ACTIVE, INACTIVE, COMBINE WITH BG ON, COMBINE WITH BG OFF.
string OverlayID
Gets/sets the Flowics overlay ID to control automatically when the button is toggled. Only works with Flowics templates.
Double / Double Slider
double Value [Get, Set]
Gets/sets the parameter's double value.
double MinValue [Get, Set]
Gets/sets the parameter's minimum double value. Input value needs to be lower than the current MaxValue.
double MaxValue [Get, Set]
Gets/sets the parameter's maximum double value. Input value needs to be higher than the current MinValue.
bool ShowReset [Get, Set]
Enable or disable the reset to the default button on the UI.
Double Slider only:
double MinRange [Get, Set]
Gets/sets the parameter's minimum range double value.
double MaxRange [Get, Set]
Gets/sets the parameter's maximum range double value.
bool RangeEnabled [Get, Set]
If true, forces the slider to remain within the specified Min/Max range.
Dropdown / Radio
object Value [Get, Set]
Gets/sets the selected entry on the dropdown. By default gets/sets the selected option's text. When the parameter's Value As Index option is enabled, gets/sets the zero-based index of the selected option instead (numbers assigned to it select by index).
Gets/sets the selected index of the dropdown.
string SelectedText [Get]
Always returns the selected option's text, regardless of the Value As Index mode.
int Count [Get]
Gets the number of entries on the dropdown.
int IndexOf (string option)
Looks for an entry equal to option. Returns its index if found, -1 otherwise.
void Insert (int index, string option)
Inserts an entry with value option at index position. index needs to be between 0 and Count.
void Add (string option)
Adds an entry with value option atthe end of the entry list.
void Remove (string option)
Looks for an entry equal to option. Removes it if found.
void RemoveAt (int index)
Removes the entry at position index. index needs to be between 0 and Count.
void SetItems (string[] entries)
Sets the dropdown's entry list to the input entries.
string Get (int index)
Returns the entry located at index position. index needs to be between 0 and Count.
string parameter[ int index ]
Array accessor for entries. Returns the entry located at index position.
void Clear ( )
Removes all entries from the dropdown.
Radio only:
string CheckedColor [Get, Set]
Gets/sets the color of the checked radio option as hex string.
void SetCheckedColor (int r, int g, int b, int a = 255)
Sets the checked color by components (0–255).
Int / Int Slider
int Value [Get, Set]
Gets/sets the parameter's int value.
int MinValue [Get, Set]
Gets/sets the parameter's minimum int value. Input value needs to be lower than the current MaxValue.
int MaxValue [Get, Set]
Gets/sets the parameter's maximum int value. Input value needs to be higher than the current MinValue.
MultiText / Text
Gets/sets the parameter's text value.
Triplet
double X [Get, Set]
Gets/sets the parameter's X double value.
double Y [Get, Set]
Gets/sets the parameter's Y double value.
double Z [Get, Set]
Gets/sets the parameter's Z double value.
double DefaultX [Get, Set]
Gets/sets the default parameter’s X value.
double DefaultY [Get, Set]
Gets/sets the default parameter’s Y value.
double DefaultZ [Get, Set]
Gets/sets the default parameter’s Z value.
bool XEnabled [Get, Set]
Gets/sets the enabled status of the X value.
bool YEnabled [Get, Set]
Gets/sets the enabled status of the Y value.
bool Z Enabled [Get, Set]
Gets/sets the enabled status of the Z value.
bool AllowProportional [Get, Set]
Gets/sets whether the user can toggle the proportional lock.
bool IsProportional [Get, Set]
Gets/sets the state of the proportional lock.
Table
Properties
string Value [Get]
Gets an string containing the table content in a XML format (much like ControlList).
int MinimumRows [Get, Set]
Gets/sets the parameter's minimum number of rows. Input value needs to be lower than the current MaximumRows.
int MaximumRows [Get, Set]
Gets/sets the parameter's maximum number of rows. Input value needs to be higher than the current MinimumRows.
int MinimumColumns [Get, Set]
Gets/sets the parameter's minimum number of columns. Input value needs to be lower than the current MaximumColumns.
int MaximumColumns [Get, Set]
Gets/sets the parameter's maximum number of columns. Input value needs to be higher than the current MinimumColumns.
int RowCount [Get]
Gets the current number of rows on the table.
int RowHeight [Get, Set]
Gets/sets the row height in pixels.
int ColumnCount [Get]
Gets the current number of columns on the table.
int SelectedRow [Get]
Gets the currently selected row. In case of multi-selection it returns the first selected row. If no row is selected,
-1is returned.
int SelectedIndex [Get]
An alias for SelectedRow.
bool ShowRowNumbers [Get, Set]
Shows/hides the row-number column.
bool MatchHeaders [Get, Set]
Tries to match headers of the incoming data, with the names of the column header names of the table.
bool MatchDataColumns [Get, Set]
Creates and matches columns of the table according to incoming data.
bool MatchDataRows [Get, Set]
Creates and matches as many rows in the table as there are in the incoming data.
bool TransposeData [Get, Set]
Swaps rows and columns, when set to true.
bool TriggerOnAllChanges [Get, Set]
Triggers the OnTableCellValueChanged callback when set to true, for when a table cell value has been changed by user input.
bool CanUserChangeNumberRows / CanUserReorderRows / CanUserResizeRows / CanUserChangeNumberColumns / CanUserReorderColumns / CanUserResizeColumns [Get, Set]
Enable/disable the corresponding user interactions in the operator UI.
Methods
Cell Handling
BaseCell Accessor [int row, int column ] [Get]
Gets the cell located at row-indexed row and column-indexed column.
BaseCell GetCell (int row, int column)
void SetCellValue (int row, int col, dynamic value)
Sets the cell’s value (located at [row, column]) to value. [dynamic] value can either be a string or have a type that is compatible with the target cell.
string GetCellValue (int row, int col)
Gets the cell’s (located at [row, column]) string value representation.
void SetFromArray (string[] values)
Fills the table from a string array.
void ClearColumnValues (int columnIndex)
Resets all the cell’s values in columnIndex column.
void ClearRowValues (int rowIndex)
Resets all the cell’s values in rowIndex row.
void ClearAllValues ( )
Resets all the cell’s values.
void Clear ( )
Removes all the content (all columns and rows are deleted).
Columns Handling
Inserting a column from code requires the user to specify the type of column that needs to be created, the valid column types are:
bool: Column with BoolCell
string: Column with StringCell
int: Column with IntCell
ivec2: Column with IntDupletCell
ivec3: Column with IntTripletCell
double: Column with DoubleCell
dvec2: Column with DoubleDupletCell
dvec3: Column with DoubleTripletCell
asset: Column with AssetCell
dropdown: Column with dropdown items
All column interactions take into consideration the maximum and minimum number of columns of the table
void AddColumn (string columnType)
void AddColumn (string columnType, string name)
Adds a column of type columnType named name if specified, otherwise the default is used.
void AddColumn(string columnType, string controlObjectId, string displayName)
Adds a column of type columnType named displayName. The controlObjectId is the internal name used for ControlObject mapping.
void AddMultipleColumn (int count, string columnType)
Adds count columns of columnType type.
void InsertColumn (int index, string columnType)
void InsertColumn (int index, string columnType, string name)
Inserts a column at index index of columnType type named name if specified, otherwise the default is used.
void InsertColumn(int index, string columnType, string controlObjectId, string displayName)
Inserts a column at index index of columnType type named displayName. The controlObjectId is the internal name used for ControlObject mapping.
void InsertMultipleColumn (int index, string columnType, int count)
Inserts count columns at index index of columnType type.
void RemoveColumnAt (int index)
Removes column at index index.
void MoveColumn (int targetIndex, int newPosition)
Moves column from targetIndex position to newPosition.
void ClearColumns ( )
Removes all columns.
double GetColumnWidth (int index)
Returns the column width in pixels of column.
void SetColumnWidth (int index, double width)
Sets the column width in pixels of column with index index.
string GetColumnName (int index)
Returns the column label.
void SetColumnName (int index, string name)
Sets the column label to name of column with index index.
void SetColumnDisplayName (int index, string name) / string GetColumnDisplayName (int index)
Sets/gets the column's display label (SetColumnName/GetColumnName are aliases).
void SetColumnControlObjectID(int index, string controlObjectId)
Sets the column's internal ControlObject ID used for mapping in case it is bound to a Viz Engine’s ControlList object.
int GetColumnIndexByName (string name)
Returns the index of the first column matching name. Returns -1 otherwise.
int GetColumnIndexByControlObjectID(string name)
Returns the index of the first column matching the control object name. Returns -1 otherwise. This can be used for ControlList generated tables in Viz Templates.
string GetColumnControlObjectID(int index)
In case the table is bound to a Viz Engine’s ControlList object, this function returns the id associated to the colum’s ControlObject.
void SetColumnReadOnly (int index, bool isReadOnly)
void SetColumnReadOnly (string name, bool isReadOnly)
Sets a column to be read only or not.
bool GetColumnReadOnly (int column)
bool GetColumnReadOnly (string name)
Returns whether a column is read only.
void SetColumnEditorOnly (int index, bool editorOnly)
void SetColumnEditorOnly (string name, bool editorOnly)
bool GetColumnEditorOnly (int column)
DropDown Handling
void SetDropdownOptions (int column, string [] options)
Set dropdown items for an entire column (column must be of type 'dropdown')
string[] GetDropdownOptions (int column)
Returns a list of dropdown options for column.
void AddDropdownOption (int column, string option)
Appends option to all dropdowns in column.
void RemoveDropdownOption (int column, string option)
Removed the first occurence of option from all dropdowns in column.
void ClearDropdownOptions (int column)
Clears all dropdowns in column.
void SetCellDropdownOptions (int row, int column, string [] options)
Set dropdown items in specific cell (column must be of type 'dropdown')
string[] GetCellDropdownOptions (int row, int column)
Returns an array of the items of the dropdown in row/column.
void ClearCellDropdownOptions (int row, int column)
Clears the items of the items of the dropdown in row/column
Rows Handling
All row interactions take into consideration the maximum and minimum number of rows of the table
void SetNumberRows (int count)
Adds/removes rows until the table’s RowCount is equal to count.
void AddRow ( )
Adds a Row to the table.
void AddMultipleRow (int count)
Adds count rows to the table.
void InsertRow (int index)
Inserts a row at index position to the table.
void InsertMultipleRow (int index, int count)
Inserts count rows at index position to the table.
void RemoveRowAt (int index)
Removes row at index position.
void MoveRow (int targetIndex, int newPosition)
Moves row from targetIndex position to newPosition.
void ClearRows ( )
Removes all rows.
Table Parameter Example
// Open the cvs file with the starters, parse the content and add all riders to the RaceTable (TableParameter)function LoadRaceTable(){ // Setup columns from UI, Comment if already done manually //RaceTable.Clear() //RaceTable.AddColumn( "string", "Horse") //RaceTable.AddColumn( "string", "Trainer") //RaceTable.AddColumn( "string", "Jockey") //RaceTable.AddColumn( "string", "Owner") //RaceTable.AddColumn( "string", "Colors") //RaceTable.AddColumn( "string", "Horse CN") //RaceTable.AddColumn( "asset", "Silk") // Clear rows RaceTable.ClearRows() var i = 0 var FileContent = arc.ReadTextFile("D:/Horses/Starter.csv") var EntryArr = FileContent.split("\n") // First line is for the headers, ignore it for(i = 1; i < EntryArr.length; i++) { // Split the rider content var splitContent = EntryArr[i].split(",") // CVS file has great amount of data but we only want to display certain stuff RaceTable.AddRow() RaceTable.GetCell(i-1, 0).Value = splitContent [19] RaceTable.GetCell(i-1, 1).Value = splitContent [22] RaceTable.GetCell(i-1, 2).Value = splitContent [25] RaceTable.GetCell(i-1, 3).Value = splitContent [27] RaceTable.GetCell(i-1, 4).Value = splitContent [34] RaceTable.GetCell(i-1, 5).Value = splitContent [20] // image assets need to be assigned using the SetCellValue method RaceTable.SetCellValue(i-1, 6, splitContent[21]) }}OCR
The OCR parameter reads text from regions of an NDI video source (only NDI sources are supported; the source and the regions are configured in the parameter's UI). Each recognized value is written to the DataMap under the key <shared memory prefix><region name>, where scripts can consume it through the DataMap functions and the OnDataMapValueChanged callback.
bool Tracking [Get, Set]
Starts/stops the OCR analysis.
void RefreshVideoSources ( )
Refreshes the list of available video sources.
Unreal
These are helper functions to invoke BluePrint functions:
void InvokeBPFunction (string blueprintName, string functionName, params object[] arg)
Invokes the function functionName on the Blueprint blueprintName, with a variable number of parameters (typically strings and/or numbers).
void InvokeBPFunction (string blueprintName, string functionName)
Invokes the function functionName on the Blueprint blueprintName, without any arguments.
The methods are invoked on all Unreal Engines of the template’s currently selected channel.
Global.OnExecute = function (){ // before executing the template, update some data on the Blueprint invoking updateData InvokeBPFunction("BP_main", "updateData", "Hello", "World", 42.0, 3) // change the appearance of the car InvokeBPFunction("BP_CarManager_Blue", "Change Car", 1, true, "This is the new car model");}Flowics
Overview
Flowics templates can programmatically control individual overlays through scripting. These methods only work with Flowics-type templates.
Available Methods
void ShowOverlay(string ids)
Show one or more overlays. Parameter is space-separated overlay IDs (for example, n10717 n10718).
void HideOverlay(string ids)
Hide one or more overlays. Parameter is space-separated overlay IDs.
void SetOverlayState(string id, string state)
Set overlay state for a single overlay. State can be
in,out, oridle.
void SetOverlayStates(string states)
Set multiple overlay states using prefix notation. Use + to show, - to hide (for example, +n10717 -n10718).
void ShowAllOverlays()
Show all overlays in the template.
void HideAllOverlays()
Hide all overlays in the template.
void GotoFirst(string overlayId, string controlId)
Navigates to the first item in a Flowics list item.
overlayId - Overlay ID (for example, n10717)
controlId - Control ID within the overlay control (for example, list-1, carousel-main)
void GotoNext(string overlayId, string controlId)
Navigates to the next item in a Flowics control.
void GotoPrev(string overlayId, string controlId)
Navigates to the previous item in a Flowics control.
void GotoItem(string overlayId, string controlId, string path, string value)
Navigates to a specific item in a Flowics list based on a field value match.
path - Path to the field to match (for example, id, name)
value - Value to search for in the specified field
void FlowicsSetTimer(string timerId, string timerValue)
Sets a Flowics timer/stopwatch to a specific value without starting it (paused state).
timerId - The global data provider ID for the timer
timerValue - The timer value to start from (for example, "00:00:00" or milliseconds)
void FlowicsSetTimerAndPlay(string timerId, string timerValue)
Sets a Flowics timer/stopwatch to a specific value and starts playing.
void FlowicsStartTimer(string timerId, string timerValue)
An alias for above’s FlowicsSetTimerAndPlay.
void FlowicsSetTimerAndPlayRange(string timerId, string timerValue, string timerStart, string timerEnd)
Sets a Flowics timer/stopwatch with a range (start/stop values) and starts playing.
timerValue - The current clock value
timerStart - The start value for the range
timerEnd - The stop value for the range (timer stops when reached)
void FlowicsPauseTimer(string timerId)
Pauses a Flowics timer/stopwatch.
void FlowicsPlayTimer(string timerId)
Plays/resumes a Flowics timer/stopwatch.
void FlowicsSetTimerAndPause (string timerId, string timerValue)
Sets a Flowics timer/stopwatch to a specific value and pauses it.
void FlowicsResumeTimer(string timerId)
Alias for FlowicsPlayTimer.
void FlowicsResetTimer(string timerId)
Resets a Flowics timer/stopwatch to its initial value.
Examples
Basic Overlay Control
function OnButtonPressed(id) { if (id=== "showLowerThird") { // Show single overlay ShowOverlay("n10717") } else if (id=== "hideLowerThird") { // Hide single overlay HideOverlay("n10717") }}Multiple Overlays
function showGraphicsPackage() { // Show multiple overlays at once (space-separated) ShowOverlay("n10717 n10718 n10719")}function hideGraphicsPackage() { HideOverlay("n10717 n10718 n10719")}Set Overlay State
function controlOverlay(overlayId, action) { if (action === "in") { SetOverlayState(overlayId, "in") } else if (action === "out") { SetOverlayState(overlayId, "out") } else if (action === "idle") { SetOverlayState(overlayId, "idle") }}Batch State Changes
function updateOverlayStates() { // Use prefix notation: + = show, - = hide // This shows n10717 and n10719, hides n10718 SetOverlayStates("+n10717 -n10718 +n10719")}Show/Hide All
Global.OnExecute = function (){ // Show all overlays when template goes on-air ShowAllOverlays()}Global.OnOut = function () { // Hide all overlays when template goes off-air HideAllOverlays()}ToggleButton Integration
Toggle buttons can automatically control Flowics overlays by setting the OverlayID property:
function ShowBreakingNews() { // Link toggle button to Flowics overlay myToggle.OverlayID = "n10717"; // Now toggling the button automatically shows/hides the overlay myToggle.IsChecked = true; // Shows overlay}Note: These methods only work with Flowics templates. Calling them on Viz or Unreal templates has no effect.
Video
Set the video and PTZ source.
void SetVideoSource (string name)
Sets the name of the preview source window.
void SetNDIPTZVideoControl (string ptzControl)
Sets the name of the NDI PTZ control overlay source.
void SetFlowicsOutput (string URL)
Sets the global Flowics output URL.
Using async/await
Some methods are declared async, meaning the method might be time consuming (for example, while waiting for an answer from a server). To avoid locking up the UI, one can await an async method, such that Viz Arc can continue to process other events like user interaction. The async method might be processed on a different thread.
The following example shows how to retrieve the version of the first engine of the active channel on a template:
Global.OnButtonPressed = async function (id){ if( id == "getFromEngineButton"){ let answer = await GetFromEngineAsync("VERSION", 3000) Console.WriteLine("engine version is " + answer) }}Note that it is mandatory to declare the calling functions as async, when using await. The async keyword can be safely added to any Viz Arc callback, as shown with OnButtonPressed.
Using try/catch
It is highly recommended to use a try/catch block around awaited methods, otherwise, eventual errors are not detected
